03 Durango SXT 4.7 - Dakota Durango Forum
post #1 of 12 Old 09-24-2011, 06:44 AM Thread Starter
rpmcclafferty
Vehicle: 2003 Dodge Durango SXT
03 Durango SXT 4.7
My Durango is acting crazy....on startup it will idle at like 2000 RPM's, and after it drops down, it will still idle erratically between 700 and 1800 RPM's. While driving, it bucks and sometimes feels like it doesnt want to shift gear. The bucking isnt all the time, but its a lot of the time. when it does it on the highway, it will sometimes cut out and die at highway speeds. The CEL isn't on all the time, but it seems to run worse when the light is off. When the light comes on, its a little better. I haven't changed the o2's yet, but was wondering if they would cause this problem. My wife drives it most of the time with my kids in it, so I need this problem to go away....any help would be GREATLY appreciated. Thanks
Ryan
rpmcclafferty is offline
post #2 of 12 Old 09-24-2011, 01:57 PM
Anthony
Yes it's a lowered 4X4
Anthony's Avatar
Vehicle: 2000 Dakota CC Sport
Send a message via MSN to Anthony
IAC might need replacing. But first, give the IAC sensor a cleaning which is the black sensor located on the throttle body.
EDIT: The TPS sensor could also be the problem too, which is located on top of the IAC sensor
Anthony is offline
post #3 of 12 Old 09-24-2011, 02:04 PM
Durango Bill
Vehicle: 2001 durango
CEL is on ? what are the codes...
Durango Bill is offline
post #4 of 12 Old 09-25-2011, 06:42 AM Thread Starter
rpmcclafferty
Not sure of the codes yet, i bought a code reader today. The CEL is on sometimes, then it goes off, and thats when the truck is running real bad, once the CEL is off. Then it will stall a few times on the highway and it has to sit for a minute before it can be restarted, most of the time the CEL comes on after i restart it and it will run a little better, but you can still tell something is wrong.
post #5 of 12 Old 09-25-2011, 03:09 PM
durango2001
5 Door Whore #215
durango2001's Avatar
Vehicle: 01 Durango, 02 dakota r/t
you dont need a code reader to check codes just turn the key on and off
5 Door Whore #215
durango2001 is offline
post #6 of 12 Old 09-25-2011, 03:20 PM
durango2001
5 Door Whore #215
5 Door Whore #215
post #7 of 12 Old 09-25-2011, 08:02 PM
s10corey
Vehicle: 2001 Dodge Dakota
Modifications: 3 inch lift, 33's, Hemi swap with 5 speed manual
The first thing I would do is clean the battery terminals. Dodges do wierd things with low or high voltage. Then, I would clean the inside of the throttle body. Check the codes, write them down, then clear the codes and drive it and see if any come back, before spending money on any sensors.
2001 Dakota 4X4, 5.7 Hemi 5 speed manual swap Electron blue pearl, 3" body lift. 2001 Dakota 4X4, 4.7 5 Speed, mostly stock. 1996 Chevy S-10, 6" drop 4.3 auto. Various Nissan/Datsuns.
s10corey is offline
post #8 of 12 Old 09-30-2011, 03:02 AM Thread Starter
rpmcclafferty
I've already cleaned the throttle body, changed the IAC Valve, and the TPS.....I pulled the codes and they are P121 and P068. This thing is driving me crazy.
post #9 of 12 Old 09-30-2011, 03:14 AM Thread Starter
rpmcclafferty
Ok, so after a quick search on the forum, and through Google. 121 is the TPS, and 068 is MAF reading not consistent with TPS......whatever that means. maybe i'll replace the TPS again, and if that doesnt help, i'll look for the MAF, does this truck have a MAF? My 95 Thunderbird has a MAF Sensor near the air box, what is the sensor on this truck that is inside the airbox?
post #10 of 12 Old 09-30-2011, 05:47 AM
TazRango
Jersey Boy
TazRango's Avatar
Quoted: 243 Post(s)
Our trucks use a MAP, not MAF. It's on the front of the intake manifold
Use torrents? Already got two copyright strikes with your ISP? Got a slow upload connection? You need an offshore SEEDBOX! Includes a FREE VPN Endpoint in France, The Netherlands, or Canada (allows you to watch Netflix titles not available in the US!!).
CLICK--> DediSeedbox.com - 1Gbps backbone, up to 1TB storage, unlimited traffic, unlimited concurrent torrents, Secure FTP, VPN, and HTTPS access to files <--CLICK
Originally Posted by Big_Texxan View Post
fuck it, Im going to convert those to HID and stick them in my heads, fogs, tails, double heads, and my butt so I make a halo while shitting. It would be like a holy shit, and maybe one around my penis for that illuminating experience a girl has hahahaahahahaah
"How many times is Biden gonna say something stupid?" -Barack Obama (2008) ▼▼▼▼
"And Neal Smith, an old butt buddy, are you here Neal?" -Joe Biden (2/12/15)
TazRango is offline
post #11 of 12 Old 09-30-2011, 05:25 PM
caulk04
Vehicle: none
The sensor you're seeing in the airhat is the IAT (intake air temp) sensor. 5/8" round-ish, two wires.
Are you sure the TB is clean? It's easy to miss junk that has collected in the IAC ports.
caulk04 is offline
post #12 of 12 Old 05-07-2012, 03:58 AM Thread Starter
rpmcclafferty
So for 6 months I have have changed almost everything I can possibly think of, cleaned the hell out of the throttle body, changed fluids, added additives and I can not figure out why my truck is acting so flaky. Its not as bad as it was, but the truck stalls or comes near to stalling every time I come to a stop, then stutters when I pull out, after that it runs fine....if it doesn't stall it will idle irratically and sputter, but I give it some gas and its fine...can anyone offer any insight on this problem? Its driving me nuts....
2003 Durango SXT
