How to remove lower ball joints ?? - Dakota Durango Forum
General Parts Inquiries Can't find it in any other category?
post #1 of 11 Old 07-26-2011, 08:32 PM Thread Starter
cmoney23
cmoney23's Avatar
Vehicle: 2000 dakota R/T
Modifications: 00' R/T, Roll pan, Tailgate handle relocator, Halo HL, white face gauges, SRT hood, Side exit exhaust, neons, Gauge pod w/ soon to be gauges, Euro tails
gotta 2000 dakota. Lower ball joints are riveted in. I tried getting just one rivet out 1st to see if i was gonna be able to get it. I grinded down the tip rivet and tried to hammer it out. Well didnt work. Do i have to grind down the top rivet and bottom rivet then try to pound it out? Or am i gonna even be able to pound it out with a hammer?
cmoney23 is offline
post #2 of 11 Old 07-26-2011, 11:25 PM
chaos2767
chaos2767's Avatar
Vehicle: 1999 dakota CC R/T
I just grinded down the top of the rivet and used a 8 lbs hammer! Its such a PIA!
chaos2767 is offline
post #3 of 11 Old 07-26-2011, 11:27 PM
AmberFireDaK
AmberFireDaK's Avatar
Vehicle: 2000 Dakota R/T
Quoted: 2 Post(s)
Send a message via MSN to AmberFireDaK
Cut an X in the head of the rivet and use an air punch... or hammer and punch. Grinding the head all the way down causes a lot of heat, the heat makes the rivet expand and makes it harder to knock out
- Justin
AmberFireDaK is offline
post #4 of 11 Old 07-26-2011, 11:41 PM
rrob5382
rrob5382's Avatar
Vehicle: 98 Durango SLT 5.2L 4x4
Quoted: 25 Post(s)
Gotta replace mine soon, lucky for me they were replaced before so no need to grind down any rivets!
rrob5382 is offline
post #5 of 11 Old 07-27-2011, 12:14 AM Thread Starter
cmoney23
cmoney23's Avatar
So i should be able to knock them out by just grinding the head off? Or by cutting and X then knocking out. No need to grind the bottom part off too?
cmoney23 is offline
post #6 of 11 Old 07-27-2011, 12:20 AM
chaos2767
chaos2767's Avatar
Grind an X and knock em out with a big hammer!
post #7 of 11 Old 07-27-2011, 12:44 AM
AmberFireDaK
Quoted: 2 Post(s)
you don't have to touch the bottom
- Justin
post #8 of 11 Old 07-27-2011, 02:02 AM
emjohn4
Vehicle: '02 Dak 3.9 / '02 Dur 4.7
I found it was easier to remove the lower control arm, and drill them out.
Grinding, cutting an x and punching, and drilling all work. Regardless of method chosen...it's just a pain in the rear. Give yourself a long day to change them the first time.
emjohn4 is offline
post #9 of 11 Old 07-27-2011, 04:37 AM Thread Starter
cmoney23
cmoney23's Avatar
Should the lower control arm be off before using the big hammer? Or are you using the big hammer while the lower control arm is still attached? What im getting to is will all that hard hitting hurt the contol arm in any way if it were still attached?
cmoney23 is offline
post #10 of 11 Old 07-27-2011, 09:15 AM
IWA2002
IWA2002's Avatar
Vehicle: 2002 DODGE DURANGO
I used Cobalt drill bits.. and just drilled them out
IWA2002 is offline
post #11 of 11 Old 07-27-2011, 04:31 PM
ScojoDak
Dakota for Life!
ScojoDak's Avatar
Vehicle: 98 Dakota R/T
Your best friend.......
Dakota for Life!
If you haven't lived for something, you'll die for nothing.
ScojoDak is offline
