How to set the timing on 99 Rango - Dakota Durango Forum
post #1 of 1 Old 07-26-2011, 09:00 PM Thread Starter
MBM71
Vehicle: 1999 Dodge Durango
Hello all, I have 99 Durango 5.2 4x4. I had the transmission rebuilt and I put it back in. The Durango ran fine before pulling the tranny. Now all sorts of problems have been wrong with it. at first i couldn't get fire or gas I replaced the crankshaft sensor, then i got fire but gas seemed to be a problem fuel pump runs and there is pressure on the rail, I drop the gas tank thinking maybe bad gas or water might be in the tank it but it wasn't . I replaced the Idle control valve, TPS, and The PCM, also a new battery. I borrowed an auto scanner it showed crankshaft sensor and P0301 bad i replaced crankshaft sensor again. P0301 is #1 misfiring so apparently the Durango has jumped timing. there is loss of powere,backfiring, and spitting and sputtering when i press the gas. how do i fix or adjust the timing on the durango? Or does anyone have another suggestion that might cause the symptoms i am experiencing.
MBM71 is offline
