2wd and 4wd wheel bearing - Dakota Durango Forum
post #1 of 4 Old 07-21-2011, 08:01 AM Thread Starter
tek
tek's Avatar
Vehicle: 2003 durango
Modifications: K&N cai,magnaflow cat back, full subwoofer system
Garage
i was wondering if i could put 4wd front wheel bearing in a 2wd truck as this is going to be a drive way job i cant press a 2wd bearing in but if i can put the 4wd hub assembly in there it will be a lot easier thank you in advance
tek is offline
post #2 of 4 Old 07-21-2011, 06:04 PM
emjohn4
Vehicle: '02 Dak 3.9 / '02 Dur 4.7
You cannot put a 4wd hub assembly onto a 2wd truck.
Bearings are different.
I have two extra hub/bearing assemblies. If you want them, they are $30 + shipping to you.
emjohn4 is offline
post #3 of 4 Old 07-21-2011, 06:20 PM
t vago
t vago's Avatar
Vehicle: 2000 Dodge Dakota SLT QC
Quoted: 12 Post(s)
Am I missing something? My truck's front bearings just slid onto their spindles. Removed the wheel, removed the brake hardware, removed a huge nut from the spindle, and the bearing just slid off. (Don't re-use the huge nut, though)
2000 Dakota SLT QC- 4.7L V8, 545RFE transmission, Polished/Ported Cylinder Heads, Bosch +4 Plugs, HO Cams, Mopar beehive valvesprings, bwdakrt 65 mm Throttle Body, Fuel Delivery mod, Magnaflow Hi-flow cat, Dynomax Cat-back, Trans-Go Shift Kit, JGC Fan conversion, no engine-driven fan, Ceramic front brake pads, Power Slot Cryo rotors, Goodridge S/S brake hoses, 2004 Mopar fuel injectors, JBA Ceramic coated headers, intake heater, Toyota MR2 EHPS Pump
2001 Durango SLT- Next-Gen Corsair 4.7L V8, 545RFE transmission, 12-hole 24 lb fuel injectors, Fuel Delivery mod, JGC Fan conversion, no engine-driven fan, 65 mm throttle body, Toyota MR2 EHPS Pump
2005 Magnum- 3.5L V6, NSG370 6-speed manual transmission, 2.87 rear end, Bosch +4 Plugs, Billet Technology Catch Can, Stop Tech S/S brake hoses, JBA Ceramic coated headers, intake heater
t vago is offline
post #4 of 4 Old 07-21-2011, 06:49 PM
emjohn4
I think I know what it is...
You can buy just the bearings (cheaper) or the hub/bearing assembly (more expensive). I think the bearing by itself is about $20/side, while the assembly can cost up to $150+ at an AutoZone (or similar).
Sounds like when you replaced yours - you purchased the hub/bearing assembly. This is the more common method to replace the bearings, since you don't have to press them into/onto the hubs.
emjohn4 is offline
