| Register | Home | Forum Extras | Website Features | Garage | Calendar | Search | Today's Posts | Mark Forums Read | Auto Loans |
| 4.7L/4.7L HO/4.7L Gen II Engines Questions regarding the 4.7L V8 engine |
Thread Tools | Rate Thread | Display Modes |
#1
Engine noise on startup goes away after a few seconds... HELP!
Hello Everyone!
I have got a noise on Startup that last for a few seconds on my 2001 Durango 4x4 w/ 4.7 engine, at first I thought it was my exhaust manifolds leaking or making a noise, well I replaced both exhaust manifolds and put new Remflex gaskets on, I took off the belt to see if the noise went away, to eliminate the water pump, pulleys, fan, etc, the noise was still there So, I am back to the drawing board I have swiched oil filters, I was using Mopar filters, then I went to the Napa Gold Filter still no change in the noise it all I was running Mobil 1 5w30, then switched to Pennzoil Ultra 5w30 still no change, I downloaded a sound clip for you all to hear, ==== Thanks for your help!============ http://s669.photobucket.com/albums/v...0709130337.mp4
__________________
Gotta have it!! ![]() 2001 DODGE DAKOTA QUAD 4.7 4X4 |
| Sponsored Links | ||
Advertisement | ||
#2
Are you talking a loud clatter for a brief second at start up? Almost sounds like timing chain noise to me...but I don't know why it would go away so quickly. Maybe a tensioner is bleeding down? I really don't know...
__________________
![]() Hey, does this smell like chloroform to you?
#3
Thanks, yeah its driving me crazy trying to figure out what it is, so timing chains tensioners can make the same noise? its drives fine and all, just wish I knew what it was!
__________________
#4
would changing the oil to 10w30 get rid of the noise?
__________________
#5
doubt it would but you can try
#6
I tryed switching to the 10w30 it did not help, I am beginning to think its in the filters anti-drainback valve, I use the Napa gold any one else have this problem? thanx
__________________
#7
The audio is so compressed I can't pick out any weird sounds excepts a couple faint knocks on start up. Is that what you're talking about is the knocking noise? I don't see how a new oil filter can make an engine noisy, its gotta be an internal problem.
__________________
Every great idea I have gets me in trouble. |
#8
__________________
#9
Bump!
__________________
#10
Lifter clatter at start up then oil gets to them and quiets down.
__________________
01 QC 4.7L-Superchips,4.10's,e-fan,bbk 70mm tb,CAI,magnaflow w/3in stainless side exit exhaust no cats,100shot,20x10's, 2/3 drop,Billet grille+bumper inserts,cadence 10's,autotek 1000watt amp,Alpine cdplayer,Painted Stuff68 Chevy Truck -355,lime green tire burner |
#11
Bad muffler bearings.
__________________
Member of the engine rebuild club, HO Cams, 68mm TB by Dwight, SuperChips, Bilstein shocks, 5-45rfe Jeep TCM mod. ... and I clean the windows pretty often. |
#12
The 4.7 is OHC.. It doesn't have lifters..
It has hydraulic lash adjusters.. But that sounds like what it is. My truck had a similar noise, which went away after I flushed the engine.I forget where I saw the recipe, but I've used it (about 30,000 miles ago) and this stuff works like industrial engine draino - the crap that comes out looks like oil that's been in service for 60,000 miles. You will need 3 cheapo oil filters (they'll only be run for 30 minutes each), one of your normal oil filters, two gallons of kerosene, one large bottle of Marvel Mystery Oil, seven quarts of cheapo 10w30, and 6 quarts of your favorite 5w30 or 0w30 oil.
All "oil starvation" noises should be gone at this point.
__________________
![]() Quote:
#13
ahh yes. i wasnt thinking. im used to my ls series motors where it's a given chevy thing.
Ahh muffler bearings yes! check blinker fluid also.. may lead to noise
__________________
#14
__________________
#15
__________________
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | Rate This Thread |
