1999 - 3.9L No Oil pressure at warm idle - Dakota Durango Forum
2.5L/3.7L/3.9L Engines Questions regarding the I4 and V6 Engines
post #1 of 9 Old 07-05-2011, 02:15 AM Thread Starter
Dust0800
Vehicle: 1999, Dakota, Sport
Hey guys,
Just bought a 1999 Dakota Sport, 3.9L. Got it on the road and after 15 minutes of driving the oil pressure Gage went from 40psi to 0 as I came to a stop sign. The truck had been sitting for a few months when I bought it and the oil is a nasty nasty dark color. (was already planning to do an oil change when I got home). I've heard to change/clean the oil pressure sender and do an engine flush however I am wondering if the truck is ok to drive. The oil pressure shoots back up to 40 when I'm on the gas and only drops when I brake for a corner etc.
Anyone else had this happen to them? Any tips to getting the sender off without buying the special socket?
Thanks, Dusty
Dust0800 is offline
post #2 of 9 Old 07-05-2011, 03:10 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
put a manual gauge on it before you do anything....it's possible pick-up screen could be plugged
Little Blue Guy is offline
post #3 of 9 Old 08-04-2011, 02:13 AM
zeuglodon
Vehicle: 1997 Dakota Club Cab 4x4
Oil pump and/or bearings are worn and the oil is too thin when warm to build pressure. Change the oil using a higher viscosity oil like 10w-40 and add a viscosity enhancing product like STP Oil Treatment.
zeuglodon is offline
post #4 of 9 Old 08-30-2011, 02:20 AM
tommy_tow
Vehicle: 2007 Dodge Dakota 4x4
Modifications: Custom dual exhaust
ive been having the same problem on my 97 3.9l. put a manual guage and it showed the same. dropped the pan to check the screen... nothin.. replaced the pump while i was there and im still havin the same problem. guess now ill have to try the higher viscosity oil
tommy_tow is offline
post #5 of 9 Old 08-30-2011, 02:40 AM
Blue93Dakota
408,R3,Indy Heads,Twin66s
Blue93Dakota's Avatar
Vehicle: 93 CC 2wd
Modifications: Bone Stock... check fQuick in signature
Garage
Agree with the manual gauge. It may just be the sending unit.
"Never argue with an idiot, he will drag you down to his level and beat you with experience." -Unknown
Joe
'04 Altlantic Blue Durango Limited 4X4 Hemi
20" Chrome Ram Wheels
'04 Bright Silver Durango Limited 4X4 Hemi
Blue '93 CC Dak MS3XEFI 408 R3 Indy Heads Twin Turbos
My fQuick (Mods)
R3 Twin Turbo Build
MS3EFI
Link to current pic
513-Motorsports-LLC
Blue93Dakota is offline
post #6 of 9 Old 08-31-2011, 06:44 PM
tommy_tow
still nothin changed with the thicker oil... now what?
post #7 of 9 Old 08-31-2011, 07:00 PM
dakota 2.5L
Vehicle: 1998 dodge dakota sport
Modifications: stock k&n a/f --stock jeep 4.0L tb. --accell mopar/jeep ign.coil w/ apt wire---accell 8.mm ign.wires red---e3 spark plugs---brass dist/cap & rotor---royal purple max ez p/s fluid,synchromax manual trans fluid-max gear diff gear oil fluid - banks torq
Garage
Why not just change the rod bearings only? To boost oil pressure?. Its bin-done before. Just match the size you have now install it with "stp" or asy-lube and let it idle for 30mim's then up to 2000rpm's 5-10mim's God bless and good luck.
dakota 2.5L is offline
post #8 of 9 Old 08-31-2011, 11:02 PM
Blue93Dakota
Vehicle: 93 CC 2wd
Garage
As mentioned before, but a manual gauge on it and see if it really is dropping pressure.
Joe
My fQuick (Mods)
R3 Twin Turbo Build
MS3EFI
Link to current pic
513-Motorsports-LLC
post #9 of 9 Old 09-13-2011, 02:38 AM
ol' grouch
ol' grouch
Vehicle: 1992 Dakota, 2001 Ram
Garage
Originally Posted by Dust0800 View Post
Hey guys,
Thanks, Dusty
A lot depends on how many miles the engine has. If it's 100K or more, you may have worn bearings. Especially if the previous owner was slack about oil changes. Now, the original timing chains on a lot of Detroit iron had a plastic like coating so when you looked at it new, it was smooth as silk and quiet. The polymer gets old and comes apart. I've fished a bunch of this out of the oil pickup screen in the past.
Now is the time to check your engine's condition. What kind of shape is the timing chain in? If it's worn, replacing the timing chain will sometimes help a little. That could also be where the garbage in your pickup came from. While you have the pan down, replace the oil pump. You want a high VOLUME pump. This will compensate for worn bushings and bearings. DO NOT put a high pressure pump on it as it will blow your bearings out and shorten the life of your engine quick.
I'll bet a new pump will give you the 10 psi per 1000 rpm you need.
ol' grouch is offline
