cheap/free 360 mods - Dakota Durango Forum
General Parts Inquiries Can't find it in any other category?
post #1 of 9 Old 06-23-2011, 10:11 PM Thread Starter
97dakkid
145 DB Club
97dakkid's Avatar
Vehicle: 1997 dodge dakota slt
Modifications: System, Flo Pro muffler, 33" tires
cheap/free 360 mods
I know its been posted time and time again and yes I have searched and searched and couldnt find much of anything so Im gonna ask it here. What cheap or free mods should I be looking at doing to the 360 magnum in my Ram to get a lil more power out of it.
1997 Dodge Dakota SLT 318 5 speed, aFe Stage 2 cold air, Airaid TB spacer, Stant 180 Superstat, magnaflow muffler, 3" body lift, 33x12.50r15 Grabber AT2, HID headlights, euro headlights and tails, billet gas door, and 2000+ lb overload springs...it never ends
Originally Posted by Big_Texxan View Post
Yo dawg, heard you like big ole tires so we put flares on your flares on your flares so you could flare up some tires
97dakkid is offline
post #2 of 9 Old 06-23-2011, 11:54 PM
Misfit
We Are 138
Misfit's Avatar
Vehicle: 98 Dakota V6 & 03 Cobra
Modifications: CAI,Xhaust,Flux Capacitor
Quoted: 20 Post(s)
Garage
Well, what all is currently done?
You could make a cheap cold air intake, cut the cats off,
Misfit is offline
post #3 of 9 Old 06-24-2011, 01:43 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 190 Post(s)
Home ported TB, mod the intake manifold, home made CAI(although the stock ram one isn't that bad compared to what they shoved in ther Dakotas). 180 t-stat. Slot the crank position sensor and advance your timing. Relocate the IAT sensor to the intake tube and not in the manifold. Tune up with NGK spark plugs and a brass contact cap/rotor set. TPS sensor mod(Hog out the screw holes and set it at .7VDC in the idle position when measured on the center contact)
hskrRT is offline
post #4 of 9 Old 06-24-2011, 06:57 AM Thread Starter
97dakkid
145 DB Club
97dakkid's Avatar
All I have done is whats in my sig I still have the cat, but its burned out so Im not gonna pull it out. Ill take all that to mind though and start with the easiest mods and work my way up from those. Then after I have all the free/cheap mods done Ill start on more exspensive ones to go with or replace cheap mods. =P
97dakkid is offline
post #5 of 9 Old 06-24-2011, 11:52 AM
70Cuda383
Don't be "That Guy"
70Cuda383's Avatar
moving the intake air temp sensor does nothing but waste fuel. you need more air, not more fuel, to make more power. once the engine gets more air, the O2 sensors will give you more fuel to keep your AFRs on target.
you could open up your intake manifold runners for higher RPM power, but all these "cheap free mods" aren't going to get you very much power.
best thing you can do is to get a tuner, bump the timing the right way, raise your shift points/redline rpm, to get more hp, and then match that with an intake and headers, and you'll pick up an easy 30-40 hp for probably $600.
70Cuda383 is offline
post #6 of 9 Old 06-24-2011, 12:59 PM
kennygene
kennygene's Avatar
Vehicle: 2001 Dodge Dakota Sport
Modifications: exhaust
Quoted: 2 Post(s)
Garage
very well said^^
2001 Dakota Sport 4x4 4.7 5 spd
2004 Ram SRT 10 RC 6spd 2010 Mopar Nationals 1st Place Viper Truck
2003 Dakota Quad 4x4 5 spd
kennygene is offline
post #7 of 9 Old 06-24-2011, 02:59 PM
SinCity R/T
That's my stapler.
SinCity R/T's Avatar
Vehicle: 2003 408ci Dakota R/T
Garage
Send a message via AIM to SinCity R/T
SinCity R/T is offline
post #8 of 9 Old 06-24-2011, 04:33 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 190 Post(s)
A cooler intake temp reading will also make the PCM give slightly more timing because the PCM retards timing as temps increase to try and keep detonation nfrom happening. And the PCM will always adjust the fuel based on input from the O2s once it goes into closed loop operation so you won't use more fuel unless you are WOT.
hskrRT is offline
post #9 of 9 Old 06-25-2011, 06:45 AM Thread Starter
97dakkid
145 DB Club
97dakkid's Avatar
Thanks guys tons of stuff to experiment with in those threads! =)
97dakkid is offline
