How long for computer reset? - Dodge Durango Forum and Dodge Dakota Forums
  #1
Old 02-01-2006, 03:00 AM
BlackDak's Avatar
BlackDak BlackDak is offline
Vehicle: 01 Flat Black X-AWD V8 QC
Reputation: 16 BlackDak is just getting started
I had some emission work done and they had to disconnect the battery to reset the computer. They said I need to come back in a few days to make sure the computers all reset.
Is there a specific procedure for resetting everything or what?
  #2
Old 02-01-2006, 03:06 AM
moparsz's Avatar
moparsz moparsz is offline
1150+ 1/4 mile passes
Vehicle: 2002 Dakota 4.7
Reputation: 65 moparsz has a spectacular aura about
Garage
Send a message via AIM to moparsz
It should reset it as soon as you disconnect the battery
__________________
Best pass 2002 Dodge Dakota : 13.512 @ 101.860 MPH and 1/8 E.T. 8.709 @ 81.43mph
Drag Track http://www.youtube.com/watch?v=LCNQhtcXkKE
New Years Eve Burnout http://www.youtube.com/watch?v=oVAQ4...lay&playnext=1
www.AIRRAM.com Discounted Performance Parts with FREE SHIPPING!
  #3
Old 02-01-2006, 03:11 AM
DAKSPORT1PA's Avatar
DAKSPORT1PA DAKSPORT1PA is offline
T.J.
Vehicle: 2001 Dakota Quad Cab
Reputation: 419 DAKSPORT1PA is a splendid one to beholdDAKSPORT1PA is a splendid one to beholdDAKSPORT1PA is a splendid one to beholdDAKSPORT1PA is a splendid one to beholdDAKSPORT1PA is a splendid one to behold
Send a message via AIM to DAKSPORT1PA
The longest I've ever waited before hooking it back up was like 15 sec. when reseting the computer and it worked right away.
__________________
"I reject your reality and substitute my own!"
  #4
Old 02-01-2006, 03:12 AM
2k2dakotaman 2k2dakotaman is offline
Ridin Dirty
Vehicle: Dakota
Reputation: 10 2k2dakotaman is just getting started
Send a message via AIM to 2k2dakotaman
same here bro bout 20 min longest i waited sounds like something fishy
__________________
2002 Dakota R/T, Red, 255/50/R17 chrome R/T wheels,B&G Flashed ,Flowmaster,Round Element Filter, M1 Intake, F&B TB52mm, SS Grill Inserts,AutoLite Plugs,Msd Wires,2 Peice diamond headlighs and corners....more to come
  #5
Old 02-01-2006, 04:19 AM
BlackDak's Avatar
Sorry guys, I may have worded it wrong.
I disconnected my battery the other day to work on something. I reconnected it and was at the emissions testing station in about 20 minutes. They immediately asked if my truck had been serviced recently. Apparantly the different computers/sensors/whatever need some driving time before tey are reporting correctly. Thier computer was not getting any readings from the computers on the truck.
I drove for a couple days and went back. The scanner went fine, but it failed anyway.
After it was worked on at the shop today, they told me again that I would need to drive it a couple days and come back so that they can hook up the scanner and make sure all the computers are reading correctly before I go back to the testing station.
I am wondering how long I really have to wait (tabs go bad tonight, so driving around for a couple days will be risky) or if there is a certain procedure that the computer needs to see in order to reset or whatever.
  #6
Old 02-01-2006, 04:22 AM
Badws6 Badws6 is offline
Vehicle: 2001 Durango5.9 RT
Reputation: 10 Badws6 is just getting started
On my Trans AM after the bat died they told me to drive at least 80 miles
But that is in CA
__________________
2001 Durango 5.9 RT
1997 Trans AM WS6 sold
2000 Grand Prix GTP sold
2008 RAM Big Horn 4.7
pictures here: Badws6
  #7
Old 02-01-2006, 05:25 AM
dave2003's Avatar
dave2003 dave2003 is online now
Site Supporter
Vehicle: 2000 Dakota Sport CC
Reputation: 50 dave2003 has a spectacular aura about
I've always reset the computer by disconnecting the neg battery cable and turning my ignition to the ON position and holding it for 10 seconds and then hooking the battery back up. I've never heard of it takin longer.
__________________
2000 Dakota CC 3.9L 5SPD Man
180* T-Stat, 360 Power Shot IntakeZ, bwdakrt modded V6 TB, Superchips 3715, HS 1.7 RR's , Black Magic 180 Extreme Fan (Clutch fan kicked to the curb!), Taylor 8mm Wires, NGK FR5-1's, EBC Sport Rotors & Hawk Pads, Infinity Reference 6020CS & 6022SI, AMI Locking Fuel Door, Diamond Clear Corners with O*NEX 6000K HID's.
  #8
Old 02-01-2006, 06:46 AM
BlackDak's Avatar
The thing is, when you erase the memory from the computer, it has to go through a relearn process. I guess it takes a little while for the computers to relearn all the settings and readings and whatnot. It takes some driving around for them to figure out where the settings need to be.
Until then, I guess a scanner will not receive a signal from the computer, which is what the emissions testing place found the first time I went through.
  #9
Old 02-01-2006, 11:26 AM
Neil's Avatar
Neil Neil is offline
Vehicle: 99 Durango
Reputation: 24 Neil is just getting started
When you reset the computer, there are certain mappings that are relearned after driving. I belive it may be around 75 miles.
Many areas during emissions testing plug into the OBDII port. I have read posts on several forums where people were turned away and told to come back in 100 miles. The computer reads that it had been reset by a flag or how many miles since reset. Im not shure what it indicates by they can tell.
__________________
  #10
Old 02-01-2006, 06:13 PM
BlackDak's Avatar
That is pretty much what I needed to know.
You may not post new threads
You may not post replies
