Another Durango seats in a Dakota thread - Dakota Durango Forum
Interior Parts Seats, Dash Parts, Gauges, other Interior Parts
post #1 of 14 Old 04-04-2011, 05:45 AM Thread Starter
BigTommy83
SPOOOOON!
BigTommy83's Avatar
Vehicle: 2001 Dodge Dakota R/T
Modifications: Spintech, Superchips, Hotchkis
I picked up some durango leather seats for the CC. The seat bolts don't line up, as I have found. Even though I've read many times they just "bolt in".
I will probably swap my old passenger side brackets to the new seat, but what about the driver side. It is now a power seat. Have you guys been drilling a new hole for the rear of the brackets or do you make a new bracket that goes from the original holes to the durango bracket?
Kinda like this:
this is a pic of concorde seats in a neon, but the bracket design could apply
BigTommy83 is offline
post #2 of 14 Old 04-08-2011, 02:37 AM Thread Starter
BigTommy83
SPOOOOON!
BigTommy83's Avatar
No one has run into this with all the seat swap threads I have found?
post #3 of 14 Old 04-08-2011, 06:58 AM
clint282cc
clint282cc's Avatar
Vehicle: 99 RC 318 dakota
what is this picture showing us??? i dont understand your problem... take pictures OF YOUR OWN SEAT and show where the holes dont line up.
408 with r/t heads and nitro boosters
let her eat... from the bottle to the throttle!
99 blue dakota sport, 99 black r/t, 01 durango r/t, 96 xj
clint282cc is offline
post #4 of 14 Old 04-09-2011, 12:37 AM
knel92
knel92's Avatar
Vehicle: 1999 Dodge Dakota
Modifications: herculiner truck bed liner, MSD street fire wire set, Bosch 4 prong iridium spark plugs, Spectre cold air intake, Flowtech shorty headers
are you you trying to put 4th gen seats into a 3rd gen, i could see that not bolting up, but if not i dont understand how they dont line up, they are just about the same seat
knel92 is offline
post #5 of 14 Old 04-09-2011, 02:52 AM Thread Starter
BigTommy83
SPOOOOON!
BigTommy83's Avatar
The Front seat bracket bolts line up and bolt in but the rear of the brackets don't line up. Has anyone ran into this before and what have you guys done? Drilled new holes or make a bracket?
The truck is a 2001 and the donor I was told was an 03.
post #6 of 14 Old 04-14-2011, 07:20 AM Thread Starter
BigTommy83
SPOOOOON!
BigTommy83's Avatar
No one has ran into this problem before?
post #7 of 14 Old 04-27-2011, 02:48 AM
91eflx
Vehicle: 2004 rc dakota 97 rc dako
ive got the same problem with 99 rango seats in a 97 rc dak
91eflx is offline
post #8 of 14 Old 04-27-2011, 04:19 AM
BuiltRango
I miss my dur
BuiltRango's Avatar
Vehicle: 1999 IB CC R/T
Exact same problem here when I tried putting rango seats from my wrecked 99 into the 99 CC Dak. Still trying to figure a solution.
BuiltRango is offline
post #9 of 14 Old 04-27-2011, 12:32 PM
Jarheadoo7
don't feed the bears
Jarheadoo7's Avatar
Vehicle: 2001 Dakota
i like the bracket idea.. it looks clean and sturdy
Jarheadoo7 is offline
post #10 of 14 Old 04-28-2011, 01:18 AM
91eflx
i figure i will cut the brackets off the 97's seadts and weld them on the durango rails
91eflx is offline
post #11 of 14 Old 04-28-2011, 01:39 AM
ramayer
ramayer's Avatar
Vehicle: 1999 durango (5.2L)
make the brackets...the truck was designed to have the seats bolt in that location, therefore there have been extra supports welded in there to hold in case of an accident. if you drill new holes you could be drilling through a spot weld for that support as weakening that area. you may not care but the next person to own it may, or the person you hit after flying through the windshield. be safe and design a sturdy bracket, not just cutting off the tabs from one track and welding to another....if it doesnt look good it probably isn't safe
mods: Functional ram air hood, 17" rt rims, 3" Magnaflow cat back, Eddy shorty headers,JBA y-pipe, RHS indy heads, 1.6 RR, comp cam .480 lift, MP valve springs, Comp cams double roller timing set, modified kegger intake, TB by Dwight, Grille craft inserts, Infinity Reference speakers all around with 10" Infinity sub in custom fibreglass enclosure, flip down DVD.
ramayer is offline
post #12 of 14 Old 05-08-2011, 05:31 PM
Spokota
Spokota's Avatar
Vehicle: 04 dakota 4x4 quad cab
Modifications: Custom headache rack w/attachments, Rhino lined, Sound proofed interior, Clarion sound System, White Gauges with Blue LEDs.
Garage
You could take a small flat bar and drill 2 holes in it. 1 to line up with the bracket and one to line up with the hole in the floor.
But, being a metal fabricator.... i would slice between the rails and the bolt down tabs, bolt the tabs to the floor, tack it place, remove it form the truck, weld it up and paint it.
If you weld it on two oposing sides it will be just as strong and safe as those factory plug welds.
Spokota 04 Quad Cab 4x4 4.7L
Custom Spider Web Headache rack w/attachments, Rhino Lined, Tinted Glass, Running Boards W/Lights, Stripped of Badges, Sound Proofed Interior, Clarion Sound System, White Gauges W/Blue LEDs.
Spokota is offline
post #13 of 14 Old 05-08-2011, 07:01 PM
jmaack727
"][" {[]} {[]} ][_
jmaack727's Avatar
Vehicle: 2 of em.
What I would do is grind the rivets off the rear original dakota rails and the new rango rails. The use some strong bolts and take the dakota rear end pieces and bolt to the rear of the durango rails. Problem solved.
Also as many people who say durango seats bolt right in do not know what they are talking about. A club cab and RC seats are different from durango seats.
jmaack727 is offline
post #14 of 14 Old 07-31-2011, 08:08 PM
designo614
I can tell you that in my 02 Dakota quad, I did just bolt in Durango seats from the same model year, a nice upgrade. I was wondering if seats from a later generation Durango would bolt in to my Dak, but I'm guessing not-
designo614 is offline
