Help with code P0551 - Dakota Durango Forum
post #1 of 10 Old 04-02-2011, 09:57 PM Thread Starter
Pugsy
Pugsy's Avatar
Vehicle: 02Dakota Sport CC 4.7 2wd
Engine light came on this afternoon and I pulled code P0551 - "Power Steering Switch Failure Incorrect input state detected for the power steering switch circuit. PL: High pressure seen at high speed."
What's this code mean? I've recently posted a thread on a mysterious power steering leak I can't find, it's dripping from by the transmission, (and no, it's not tranny fluid, I've had to top up the power steering fluid)
Can anyone help with this code? There's no obvious driveability issues with the steering.
Thx!
2002 Dakota Sport Ext Cab - 2wd, 4.7L, 5 sp manual
2000 Durango SLT - 4wd, 4.7L, auto
Pugsy is offline
post #2 of 10 Old 04-03-2011, 01:48 AM
Racer505
Vehicle: 2000 Dodge Durango
I have the same problem so i can't wait to hear the answer also
Racer505 is offline
post #3 of 10 Old 04-03-2011, 06:11 AM
jimdawg_2024
jimdawg_2024's Avatar
Vehicle: 2000 Dodge Durango SLT
The power steering switch is located on the steel line thats coming off the pump. It is located in the space between the battery and the engine. As far as seeing the leak down at the tranny, maybe its just running its way down to there. The only switch on that system should be the one at the pump.
4.7, auto, Pro Zen dual intake, 40 series flowmaster, Thunderbolt Cat, digital media HU, 31x10.50 Definity Dakotas, roof basket with 4 KC's and 2 6x9 off road lights, custom toggle switch plate, Projector headlights w/halo's, aftermarket fogs w/halo's...
5 DOOR WHORE #206
Many mods to come...
jimdawg_2024 is offline
post #4 of 10 Old 05-03-2011, 04:40 AM Thread Starter
Pugsy
Pugsy's Avatar
Ok...so finally got around to checking into this and researching some other forums. Many have said that the sensor goes bad and somehow leaks through the sensor into the wiring harness. So I unpluged the wire from the sensor and there was some fluid in where the connection takes place, but I'm lost at how the fluid somehow makes its way into the wiring harnes and goes uphill magically, then drips down by my tranny and onto the garage floor. I don't see any signs of dripping at the connection so not sure how it migrates into the wiring harness. I only had to top up the power steering fluid once and it seems to be full still so not sure if it's still leaking, yet I still get the code.
Nonetheless, I will order a new sensor and change it out to see if this gets rid of the code that keeps popping up when I'm at highway speed.
Will keep ya's posted.
Pugsy is offline
post #5 of 10 Old 05-03-2011, 04:53 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
yer power steering is pushing the fluid through the pressure switch and through the wire harness......
replace the switch and clean the wire harness as best as possible
Little Blue Guy is offline
post #6 of 10 Old 05-13-2011, 06:43 PM Thread Starter
Pugsy
Pugsy's Avatar
Ok so I put a new pressure sensor switch on and still gettting fluid through it. Is my system making too much pressure that a new one will still leak?
Pugsy is offline
post #7 of 10 Old 05-14-2011, 12:03 AM
BlueD
Vehicle: 2002 Durango SLT 5.9L
Are you using. ATF+4 fluid?
BlueD is offline
post #8 of 10 Old 05-14-2011, 12:35 AM Thread Starter
Pugsy
Pugsy's Avatar
No I just have regular power steering fluid. Durango's didn't call for ATF+4 until late 2001 model year up until then the fluid from the dealer that the manual calls for is just called "power steering fluid". Not sure what's different from 2000 to 2002...pump and rack seem the same??
Pugsy is offline
post #9 of 10 Old 05-14-2011, 12:46 AM
BlueD
My understanding is the Durango used ATF+3 up to ~2000. ATF+3 isn't really available anymore but ATF+4 is compatible. I'm not sure how detrimental the wrong fluid is for ps pumps but I know it will destroy a Durango tranny.
BlueD is offline
post #10 of 10 Old 08-07-2014, 01:37 AM
Earthgal
Earthgal's Avatar
Garage
Got the same code today shortly after being on the interstate at 70 mph. Here we go with another trip to the dealership, right? I heard this switch is something they have to change or leads to other problems. Is that the case?
We don't stop playing because we grow old. We grow old because we stop playing!
Earthgal is offline
