Easiest way to change a head light bulb - Dakota Durango Forum
Lights Parts Info Links : Clear Corners * Headlights * Headlight Covers * Tail Lights * Tail Light Covers
post #1 of 11 Old 04-01-2011, 10:46 PM Thread Starter
SMielke
Vehicle: 2002 Dodge Dakota Sport
Modifications: Straight Piped
I just spent the last hour changing my driver side bulb. I reached by the battery and done it that way, is there and easier way?
Reg Cab 4x4 4.7 v8 with straight pipes Auto.
SMielke is offline
post #2 of 11 Old 04-01-2011, 11:51 PM
SinCity R/T
That's my stapler.
SinCity R/T's Avatar
Vehicle: 2003 408ci Dakota R/T
Garage
Send a message via AIM to SinCity R/T
My hands are too big to reach in through the openings in the back - found it easier (although not necessarily less time consuming) to swap the bulb from the front - remove the torx screw so you can slide out the corner lens, etc.
SinCity R/T
2003 White Club Cab R/T
SinCity R/T is offline
post #3 of 11 Old 04-02-2011, 01:10 AM Thread Starter
SMielke
I tried doing that way but I didn't have the right size tork wrench so I squeezed my hand back there to change it. I need to pick up some more. Do you know what size it is, I tried 10 and 15 the 10 was too small and the 15 was too big.
SMielke is offline
post #4 of 11 Old 04-02-2011, 02:23 AM
DakotaLivLrg
Swap Meet Moderator
DakotaLivLrg's Avatar
Vehicle: 1999 Dakota R/T
Modifications: My truck
Send a message via AIM to DakotaLivLrg Send a message via MSN to DakotaLivLrg
yeah this ^^^
I have large hands and too much crap in the way like my viper fan controler and MSD igntion on the driver side ..haha
and sorry I don't know what size the torx is .. its really small for the coner and then it should be bolts for the headlight
Scott aka DJ Six 4...SSRage for life. The original Dak-Dur postwhore thread....Dog #38 - Pinky Dog
Originally Posted by Nolan View Post
ps If you are a Royal Purple user, you really need to use the matching Violet scented compressed air in your tires for maximum fuel mileage!
DakotaLivLrg is offline
post #5 of 11 Old 04-02-2011, 02:26 AM
emjohn4
Vehicle: '02 Dak 3.9 / '02 Dur 4.7
The torx is a T10 on both my trucks.
emjohn4 is offline
post #6 of 11 Old 04-02-2011, 02:28 AM
Josh_101
Josh_101's Avatar
Vehicle: 04 Dakota QC 4x4 SLT
There's three bolts holding the whole headlight assembly to the truck that shouldn't be hard at all to get to. My small hands can easily get to the bottom-middle bolt from under the truck. A small ratchet with a small extension and a 10mm socket easily gets to the front ones. I just replaced my headlight bulbs yesterday and it wasen't hard to do.
2013 Mustang 3.7 v6 * Performance Pack * Gotta Have It Green * Electronics/Comfort Package * Black Painted Roof * Roush Chin Spoiler & matching Ground Effects * GT Hood * GT Fog Lights * ROUSH Springs 1" drop * BMR Panhard Bar * JLT CIA * Redline Hood Struts * MPT Tuned * SVE Drifts 19x9.5
Near future mods: * MGW Race Spec shifter * Wilwood AERO6/4 brake kit w/14" rotors & green powder coated calipers
2004 Dakota CQ 4x4 4.7 *SOLD*
Josh_101 is offline
post #7 of 11 Old 04-02-2011, 03:09 AM
suprchgd99rango
Pre-Teen Giggle Brigade
suprchgd99rango's Avatar
Vehicle: 99 dakota r/t
Send a message via AIM to suprchgd99rango
i have fat hands and can change a bulb no problem.......
Originally Posted by Hustlajustin View Post
Dont put the Pussy on a Pedestal! J/K it is the best, now that I think about it, its like a snuggie for my penis
suprchgd99rango is offline
post #8 of 11 Old 04-02-2011, 03:18 AM Thread Starter
SMielke
I'll get pics tomorrow of it but the entire housing is torxs and the one between the light is bigger then a T10. I eventually want to change the entire thing anyway I want the Eagle Eye ones off of ebay.
SMielke is offline
post #9 of 11 Old 04-03-2011, 08:07 PM
acr242004
acr242004's Avatar
Vehicle: 04 Dodge Dakota Quad Cab
remove the torx screw holding the turn signals in it should be a T10 then pull turn signals forward to remove
After turn signals are removed you will see three 10mm bolts holding the headlight in remove them and pull firmly to remove headlights
the whole thing takes 30 min or less to change all the lights on the front end
acr242004 is offline
post #10 of 11 Old 06-18-2011, 05:18 AM
Warrior
Mopar n00b
Warrior's Avatar
Vehicle: 2000 Durango 4X2
Modifications: Absolutely none (yet)
Rep to acr242004 for your post...thanks for the write up, it helped me get the new Silver Star bulbs in.
Warrior is offline
post #11 of 11 Old 06-20-2011, 01:18 PM
70Cuda383
Don't be "That Guy"
70Cuda383's Avatar
I used to reach in through the fender. fuck that. reaching into a blind hole, trying to line up the tabs so the light fits in just right, then getting hte lock ring to line up and twist into place...while being a contortionist...it took me probably 30 minutes to change 2 head lights, just because I was fighting everything.
I just finished some paint work where i pulled the front lights off. I'm doing my headlights that way from now on. I think I cut my time in half! torx screw for the corner lights, 3 10mm bolts for the head light, and I had it off in about 3 minutes. swap the lights out while good visibility, great access, and not worry about smashing that expensive halogen lamp against something or touching it and getting oils on it, etc. then put it all back together.
so much easier, and because of how it's built/designed, you don't mess with the headlight aim at all when you remove it.
70Cuda383 is offline
