99 durango 5.2 tranny prob..takes of in 3rd and no OD - Dakota Durango Forum
post #1 of 11 Old 03-29-2011, 05:38 AM Thread Starter
07tbss
Vehicle: 1999 dodge durango
Alright first of all its a 99 durango with the 5.2 and im pretty sure either a 42re or 44re. Its taking of in 3rd gear if you just put it in drive. I can manually shift the first 3 gears but it never shifts into OD. I had a mechanic friend of my scan it today and its pulling a PO753 code which says "shift solenoid". I know where it is and im pretty sure i know how to replace it but i dont think this is the problem. I did some reading around and found it could be a bad pcm. So i found the pink wire in the middle plug going to the pcm and spliced and ran it to a straight ground. The truck now shifts up and down perfectly and starts out in 1st as it should. However i still dont have OD and the other threads i read said that they had all gears..?? Would this still be a bad PCM if i dont have OD??? or do i have another problem along with a bad PCM?? Any help is appreciated. I myself am leaning toward pcm but i dont want to blow a bunch of money and still have the same prob... Any help is appreciated..thanks in advance!!
07tbss is offline
post #2 of 11 Old 03-29-2011, 03:27 PM Thread Starter
07tbss
Just a little bump with some more info...I just talked with a local transmission mechanic and he also seems to think it could still be just the pcm... I was just wondering if anyone else has experienced or heard of this happening after bypassing the pink wire? Just trying to lean one way ore the other before I spend the $$$$.
07tbss is offline
post #3 of 11 Old 03-29-2011, 03:53 PM
Mastec
5.9L of Love
Mastec's Avatar
Vehicle: 2001 Durango 5.9 R/T
Modifications: Westin Pushbar & Brush Guards
Send a message via AIM to Mastec Send a message via MSN to Mastec
Have you checked the transmission relay under the hood, if you have one? My 01 Durango did what yours is doing. Changed the relay and everything worked fine. Just a thought.
5 DOOR WHORE #101
BEING DISABLED, QUALITY OF LIFE SUCKS ASS
Mastec is offline
post #4 of 11 Old 03-29-2011, 04:35 PM Thread Starter
07tbss
Yes sir I did...I swapped it with the horn relay and it made no difference....that was actually the first thing I tried
07tbss is offline
post #5 of 11 Old 03-30-2011, 01:14 AM Thread Starter
07tbss
Just ordered a pcm so hopefully this will fix all of my problems. I hope this will fix all the issues as the "pink wire jumper" only gave me gears 1-3 so im hoping i dont have seperate issue with the overdrive. Still would like to hear what others think about this though.
07tbss is offline
post #6 of 11 Old 03-30-2011, 01:37 AM
Mastec
5.9L of Love
Mastec's Avatar
Wish I could help but the new relay fixed my issues. I am sure someone will chime in.
5 DOOR WHORE #101
Mastec is offline
post #7 of 11 Old 04-05-2012, 05:27 PM
Cowboy_Customs
Vehicle: '98 Durango SLT
Modifications: None yet....
What ever happened with this? im having the same problem as of today, along with a code PO743....
I do know i ran it pretty low on tranny fluid recently due to my own stupidity not checking the fluid level properly untill yesterday.
1998 Durango SLT 318 4x4 pretty stock, kinda loud... 164K
Cowboy_Customs is offline
post #8 of 11 Old 04-05-2012, 09:24 PM Thread Starter
07tbss
Never fixed it...Ordered a rebuilt pcm, swapped them out...same problem. I got tired of screwing with a vehicle i never drove and sold it for what i had in it. Sorry i couldnt help
07tbss is offline
post #9 of 11 Old 04-07-2012, 02:16 AM
nitrohog
nitrohog's Avatar
Vehicle: '99 Dakota R/T Club cab
Garage
I just battled with this issue for a couple of weeks. I started by swapping the relay and clearing the code, I drove it once and everything worked fine, on the next start up I had the code come back. Next I swapped in my spare PCM, that didn't change a damn thing. Next I ohmed from the white connector on the PCM to the center conductor on the trans relay which is the majority of the circuit including the shift solenoid. Mine was reading properly so at that point I decided it was either the solenoid, the governor pressure sensor, or an intermittent connection in the harness. I ended up pulling every connector on the transmission off, cleaning them with contact cleaner, unplugging and re-plugging them a few times to knock off any oxidation and clearing the code again. Thankfully for me at least that has solved the problem for the last couple of weeks and the code has not come back yet (knocks on wood).
Here is a very helpful link:
http://www.socaldieseltrucks.com/for...roubleshooting
'99 Custom R/T --1.92 heads, m1 2bbl, 52mm f&b, Mike Leach headers, Mopar 2400 stall, 4.56 rear, Comp cams 210/220 cam, 1.6 roller rockers, K&N FIPK, SCT, MSD 6A, 24lbs injectors, APS trans, Flex-a-lite 180 fan, 100 shot of giggle gas. Best E.T. of 12.863@104.6
nitrohog is offline
post #10 of 11 Old 04-09-2012, 12:33 AM
Cowboy_Customs
I was following your thread about this, i guess since were getting out of winter i should probably pull the connections and clean them all up. Mine is doing exactly what yours has been doing. I can clear the codes with my scanner and it operates just fine, shut it off and start it back up and it could be limp mode or not... at this point i cleared it 3 days ago maybe 4 and it hasent come back since...
Thanks for the link, that is excellent info. Someone should put that link in the knowledgebase. I found this is a common problem throughout the car community, with very little info on it.
post #11 of 11 Old 04-09-2012, 03:05 AM
MonsterDak
/\/\[]P@R
MonsterDak's Avatar
Vehicle: 2 daks
i pulled a 3-4 solenoid code. forgot what it was. no od tho. it will shift when i let off the throttle and i hit the od off and can feel it shift out. but as soon as i give it gas it slips out of od. clutches are most likely bad in the od unit. lucky me. thank god i have extra transmissions laying around. gotta swap od units.
MonsterDak is offline
