lowering a 2000 durango 2wd - Dakota Durango Forum
Suspensions - Lifted & Lowered Drop Kits, Lift Kits, Shocks and More
post #1 of 20 Old 02-18-2011, 12:17 AM Thread Starter
jrstone8264
Vehicle: 2000 dodge durango 2wd
Hey guys im brand new to the forum, and fairly new to the durango/dakota world....wanting to lower my durango...ive read several different things but have never really messed with suvs...so im kinda lost...i dont want anything extreme maily sort of a performance stance....planning on doing the factory r/t wheels with some cooper cobra tires....but trying to get an idea on tire size as well....was thinking abt a 2/3 drop...but not sure mainly wanna drop the backend to level it out...any input would be greatly appreciated...also wanted to mention you guys are awesome....and have some of the sickest dakotas/durangos ive ever seen
jrstone8264 is offline
post #2 of 20 Old 02-18-2011, 12:25 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
Vehicle: 2002 Dodge Dakota
Welcome! I've done a few different drops (3/5, 5/7, 2/5, and now 0/1.25) and for someone who's driven the truck for nine years it's pretty refreshing to be back up where I am now. A 2/3 shouldn't give any driveability problems though. I'd actually go with 1" up front with RT coil springs if I were you and 2-3 in the back, whatever you need to level it out. 2" could be done with blocks, but for 3" or more go with shackles and or hangers.
2002 3.9L 5-speed, original owner
SCT tuner, HS 1.7 RRs, custom Airaid CAI, Dwight modified TB, OBX headers, 180* T-stat, Flowmaster muffler, deleted 3rd cat, many other useless mods
Chad7531 is offline
post #3 of 20 Old 02-18-2011, 12:59 AM Thread Starter
jrstone8264
see ive done shackles on several trucks ive built but havent been able to find a kit for the durango....and i sort of understand the concept of the blocks but ive always done blocks for lift never lower lol....but from what i understand its the way the rearend is set up with the springs under the rearend....i mainly wanna level it down...i though abt lifting the front but decided lowering would be way cooler
post #4 of 20 Old 02-18-2011, 01:02 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
If all you want to do is level it, throw some blocks in there. You're right, depends on the setup for lift vs. lower with blocks. Shackle and hanger kits are widely available for your Dur BTW.
Chad7531 is offline
post #5 of 20 Old 02-18-2011, 01:17 AM Thread Starter
jrstone8264
how hard are those to install....i know my way around a garage pretty good...problem is i dont have a garage lol....working out of the driveway with a few floor jack...jackstands and some ratchets isnt as easy as the lift last forum i joined seemed like every one had a 3 bay garage in the backyard lol....
post #6 of 20 Old 02-18-2011, 01:20 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
How easy are blocks? Cake! With a lift and impact I had it back on the ground in 15 minutes. With a jack and hand tools, still cake, just not so fast. Put the frame on jack stands, unbolt the u-bolts to release the axle from the frame, put the blocks in between, and then bolt it back together.
Chad7531 is offline
post #7 of 20 Old 02-18-2011, 01:32 AM Thread Starter
jrstone8264
lol ok...any particular names i need to look for or any links on good buys....
post #8 of 20 Old 02-18-2011, 01:46 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
Basically blocks are blocks, not much to them. I was making stainless steel blocks and selling them, now there's an improvement. But am no longer so, it's just not worth my time for what people will pay for them. Stainless is just too dang hard. All I currently have on my suspension is 1.25" DIY stainless blocks. You can even buy the material yourself and drill and tap some holes, I have all the specs.
Chad7531 is offline
post #9 of 20 Old 02-18-2011, 01:53 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
This is my most recent aluminum set, it's that easy. You need longer u-bolts though to compensate for the block.
And here's my complete stainless set I have on my truck
Chad7531 is offline
post #10 of 20 Old 02-18-2011, 01:56 AM Thread Starter
jrstone8264
they should be more than around 35-40.00 to buy tho right? pretty sad...ive got a buddy that worked for 4 wheel parts in memphis n he always hooked me up. so i dont know much abt retail stuff lol...what abt rims n tires bidding on some 17 in r/t wheels....i wanna run cooper cobras...i figured ill have to drop the back abt 3 inches to get level cause mine came with the factory towing package....what size tires would you recommend
post #11 of 20 Old 02-18-2011, 01:58 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
If you're going 3" I would avoid blocks. It can be done, be it won't be a fun ride. I haven't the slightest clue on tire size. Start a thread in the wheels and tires section and I'm sure others will jump and and help you out there. I think blocks are around $75 or so with u-bolts, but that's an educated guess.
Chad7531 is offline
post #12 of 20 Old 02-18-2011, 02:09 AM Thread Starter
jrstone8264
ill do some measurement tomorrow in the day light....2" might be enough....and will do abt the wheels and tires section.....thanks for all the help...o yea can you pm on the specs....might give building them a shot....do the have to be drilled and tapped or just drilled
post #13 of 20 Old 02-18-2011, 02:11 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
I'll write up a pm now.
Chad7531 is offline
post #14 of 20 Old 02-18-2011, 02:22 AM Thread Starter
jrstone8264
first day on the forum n already am loving it !!! thanks for all the help chad...
post #15 of 20 Old 02-18-2011, 02:26 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
PM sent, no problem, rep me with the scale looking thing above my info on the right.
Chad7531 is offline
