R/T leaf springs - Dakota Durango Forum
Suspensions - Lifted & Lowered Drop Kits, Lift Kits, Shocks and More
post #1 of 40 Old 02-17-2011, 01:37 AM Thread Starter
jrp1588
jrp1588's Avatar
Vehicle: 2002 Dakota R/T Clone
R/T leaf springs
I've got some R/T leaf springs I plan to install that weekend. It looks fairly simple, but I'm always open to tips if you have them.
One specific question I have is what size the torx head is on the bolts on the leaf spring eyes? I don't have a torn driver big enough, so I'll need to buy one before I install.
Mods:
4.10 gears, Yukon Duragrip, BlkDak 51.75mm TB, M1 intake, AFE Stage 2 CAI, FMS 21# fuel injectors, Gibson Shorty Headers, SCT tune, clutch fan delete, HS 1.7 NA Roller Rockers, Single 3" Magnaflow exhaust.
jrp1588 is offline
post #2 of 40 Old 02-17-2011, 01:38 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
Vehicle: 2002 Dodge Dakota
You'll also need a torch and air hammer if they've never been out.
2002 3.9L 5-speed, original owner
SCT tuner, HS 1.7 RRs, custom Airaid CAI, Dwight modified TB, OBX headers, 180* T-stat, Flowmaster muffler, deleted 3rd cat, many other useless mods
Chad7531 is offline
post #3 of 40 Old 02-17-2011, 02:20 AM Thread Starter
jrp1588
jrp1588's Avatar
I was a bit worried about that. Any idea on the torx head size?
Mods:
jrp1588 is offline
post #4 of 40 Old 02-17-2011, 02:21 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
Hold on I guess I'll check since it's in the garage.
Chad7531 is offline
post #5 of 40 Old 02-17-2011, 02:24 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
Sorry, I don't have a driver big enough.
Chad7531 is offline
post #6 of 40 Old 02-17-2011, 02:25 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
If you'll have to buy one I can borrow from my neighbor tomorrow to check the size. Don't count on it coming out without heat and an air hammer though.
Chad7531 is offline
post #7 of 40 Old 02-17-2011, 02:31 AM Thread Starter
jrp1588
jrp1588's Avatar
I'll do what it takes. The R/T springs have good bushings in them, so I'm not worried in the slightest bit about saving the bushings from the old springs. They are probably just going into the trash.
I tried checking my Haynes manual, but it didn't list anything about the torx driver size.
Mods:
jrp1588 is offline
post #8 of 40 Old 02-17-2011, 02:44 AM
Rebel13
Mods Addict
Vehicle: 2K R/T
I have the torx bit but to lazy to check. You don't need it anyway if it is not in lock state, unfortunatly most northern trucks are in a seized state. You can use a dog bone along with a socket on the nut side, thus not needing the torx bit.
Rebel13 is offline
post #9 of 40 Old 02-17-2011, 02:46 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
They'll pop right out with heat since you aren't worried about the bushings. It you need the TORX size still tomorrow let me know and I'll get a bit from my neighbor and check.
Chad7531 is offline
post #10 of 40 Old 02-17-2011, 02:48 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
They should break loose with heat, if not grind them off.
Chad7531 is offline
post #11 of 40 Old 02-17-2011, 02:49 AM Thread Starter
jrp1588
jrp1588's Avatar
So I'm assuming if they are stuck, I'll need new bolts, is that something that is easy to find at autozone? What do I need to know to get new ones? Size, length, etc?
Mods:
jrp1588 is offline
post #12 of 40 Old 02-17-2011, 02:51 AM
Chad7531
Armed and Dangerous
Chad7531's Avatar
Not sure, honestly I've taken mine off like three times with the same bolts. Heat up the nut and she'll break free. I guess if they break take some measurements. Length, diameter, and threads per inch.
Chad7531 is offline
post #13 of 40 Old 02-17-2011, 02:53 AM Thread Starter
jrp1588
jrp1588's Avatar
Cool, well I'll just see how it goes then.
Mods:
jrp1588 is offline
post #14 of 40 Old 02-17-2011, 04:01 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 189 Post(s)
Something I noticed on a buddies Jeep Wrangler when we were replacing his clutch. The leaf springs have greaseable bolts on the spring eyes. As in there are grease zerts built into the bolts so you can grease your spring eyes to keep the bolts from seizing to the bushings. Not sure if they will work for our leaf springs, but would be awesome to use.
As far as tips. Before you torque down the spring eye bolts lower the truck down to put weight on the leaf springs.
hskrRT is offline
post #15 of 40 Old 02-17-2011, 04:02 AM Thread Starter
jrp1588
jrp1588's Avatar
Thanks, that's what the Haynes said as well. Why is that exactly? I guess it would twist or something when weight would be applied?
Mods:
jrp1588 is offline
