Durango wont warm up - Dakota Durango Forum
post #1 of 39 Old 01-26-2011, 09:10 PM Thread Starter
4wdurango
Vehicle: 2000,Dodge,Durango
In the colder weather we have been having lately the durango will not warm up. I have just replaced the thermostat with a 180 degree thinking the old one was stuck open. The old one was a 180 also, but I am having the same issues... would like to get it to warm up so I can have some heat... when its warmer out the durango will warm up, also when we are out 4x4ing and going very slow it will warm up....any suggestions are greatly appreciated. 5.9l 4x4
4wdurango is offline
post #2 of 39 Old 01-27-2011, 01:45 AM
Neil
Neil's Avatar
Vehicle: 99 Durango
Where is the dash gauge at?
Neil is offline
post #3 of 39 Old 01-27-2011, 03:20 PM Thread Starter
4wdurango
stays pegged on the cold side, unless we are offroading or something where we are moving very slow, but on the highway and when its cold out it doesnt move. I know it works becuase it does warm up when its warm out...
post #4 of 39 Old 01-27-2011, 05:54 PM
AandPDan
AandPDan's Avatar
Vehicle: 2000 Dakota Sport CC 4x4
Quoted: 47 Post(s)
It could be a defective thermostat, staying open.
You could always try the old trick of putting something in front of the radiator to reduce the airflow.
I know a lot of guys do it but why are you running the 180? If you want heat you'd get more with the 195?
AandPDan is offline
post #5 of 39 Old 01-27-2011, 06:15 PM Thread Starter
4wdurango
I thought it was a defective one, but I just replaced it with a new one and it is still doing the same thing. I dont want to block the radiator, i really just want to get it to run right.
post #6 of 39 Old 01-28-2011, 10:47 AM
petrock
The Anti-RUB
petrock's Avatar
Vehicle: 4.7L '03 Durango SLT
Quoted: 16 Post(s)
The 180 thermostat will open up earlier and won't let the motor get much hotter then 180. The stock thermostat is 195 (if memory serves) which allows the engine to get a fair bit hotter. I would advise, like AandPDan said, to go with a stock temp thermostat. At least it wouldn't hurt.
K&N FIPK
YouTube Channel: Pet Rock’s Garage
petrock is offline
post #7 of 39 Old 01-28-2011, 04:08 PM Thread Starter
4wdurango
I will probably try that, but the durango isnt even getting up to 180 unless im going very slow or if its hot outside. Its not even getting warm enough for the thermostat to open at all....
post #8 of 39 Old 02-10-2011, 03:20 AM
SPLAudioHz
SPLAudioHz's Avatar
Vehicle: 1999 Durango
Unless........................................the T-stat is stuck open.
Had this issue 6 weeks ago.
I have to be running out of parts to replace.
SPLAudioHz is offline
post #9 of 39 Old 02-10-2011, 03:21 AM
SPLAudioHz
SPLAudioHz's Avatar
I was told to "seat" the stat before putting it in. I didn't, because I thought it didnt matter. Took it out worked the spring down a few times and put it back in. Prob solved.
post #10 of 39 Old 02-10-2011, 04:37 AM
SPC. Brinkmeyer
Jason is the name
SPC. Brinkmeyer's Avatar
Vehicle: 2004, Dodge, Dakota 3.7L
Modifications: 3" Body lift, 285/75/16 BFG A/T K.O.'s, 5% tint on rear windows and sun shade, 20% on front doors, Flowmaster 40 Series Single in Dual Out exhaust 8" long 3" tips, Line-X black Bedliner
Quoted: 2 Post(s)
Garage
Send a message via Yahoo to SPC. Brinkmeyer
im having the same problem in my ram with a 5.9 and the needle dont come off of cold and i have a 195 in mine
Posting And You
04' dak QC 4wd, 285/75/16 BFG's_________________________________________06' 300C SRT8
SPC. Brinkmeyer is offline
post #11 of 39 Old 02-10-2011, 05:15 AM Thread Starter
4wdurango
I guess everything is possible, just replaced the tstat, the old one that came out was a 180 also, thought for sure that was the problem, but the new 180 and its doing the exact same thing.
post #12 of 39 Old 02-10-2011, 07:44 AM
petrock
The Anti-RUB
petrock's Avatar
Quoted: 16 Post(s)
Because 180 is too low. Go back to stock.
K&N FIPK
petrock is offline
post #13 of 39 Old 02-10-2011, 07:45 AM
petrock
The Anti-RUB
petrock's Avatar
Quoted: 16 Post(s)
Your tstat is probably stuck open.
K&N FIPK
petrock is offline
post #14 of 39 Old 02-10-2011, 07:50 AM
SPC. Brinkmeyer
Jason is the name
Quoted: 2 Post(s)
Garage
but im in the same boat as him i just changed it ive never had a problem with Tstats sticking open as often as mentioned...
Posting And You
post #15 of 39 Old 02-10-2011, 07:56 AM
petrock
The Anti-RUB
petrock's Avatar
Quoted: 16 Post(s)
Buy/borrow/rent an infrared thermometer and take a temperature measurement at spot where the temperature sensor attaches to the motor. See if the actual temp matches the temp gauge. If the gauge is way off, then replace the temp sensor. If the gauge is spot on, then replace the tstat.
K&N FIPK
petrock is offline
