4.7l dakota stalling/hesitating - Dakota Durango Forum
post #1 of 13 Old 01-13-2011, 03:24 PM Thread Starter
02dakota
02dakota's Avatar
Vehicle: 2002 dodge dakota 4.7l
Modifications: voolant intake, single chamber flowmaster, 2"-3.5" drop YOUTUBE VIDEO http://www.youtube.com/watch?v=2oZPb-isbDQ&feature=related
2002 4.7l dakota 105k miles- started stalling the other day. It begins to stall at about 3000-4000 rmps under heavy acceleration, and feels like there is a rev limiter even though there isn't. The check engine light starts flashing once it starts to stall. The spark plugs have been changed. Any other ideas?
02dakota is offline
post #2 of 13 Old 01-13-2011, 07:19 PM
SolidStateS15
SolidStateS15's Avatar
Vehicle: 01 Dakota CC 4.7L 4x4
Send a message via AIM to SolidStateS15
check for codes. sounds like maybe a tps issue. may need to clean the TB.
- 01 Dak CC 4.7L 4x4 5spd MT, DD
- 85 Toyota Supra MKII, Project car
- 09 Toyota RAV 4, Grocery getter
SolidStateS15 is offline
post #3 of 13 Old 01-13-2011, 07:28 PM
mthandt
mthandt's Avatar
Vehicle: 2002 Dakota QC
Modifications: K&N 77 series,Superchips 3715.
Send a message via AIM to mthandt Send a message via Yahoo to mthandt
Check your cat and see if it is clogged. Get under there and whack it with a hammer, if it has stuff rattling around in it, it's bad. If it's really bad, at higher rpm's no air would be getting out of the engine and you could stall.
What are the codes you're throwing? Do the key trick to find out. Check this thread and it will show you how if you don't know how:
http://www.dakota-durango.com/forum/...ead.php?t=8258
My truck is cool.
mthandt is offline
post #4 of 13 Old 01-13-2011, 07:33 PM
SPC. Brinkmeyer
Jason is the name
SPC. Brinkmeyer's Avatar
Vehicle: 2004, Dodge, Dakota 3.7L
Modifications: 3" Body lift, 285/75/16 BFG A/T K.O.'s, 5% tint on rear windows and sun shade, 20% on front doors, Flowmaster 40 Series Single in Dual Out exhaust 8" long 3" tips, Line-X black Bedliner
Quoted: 2 Post(s)
Garage
Send a message via Yahoo to SPC. Brinkmeyer
CELs come on for a reason check em! they will tell you what is wrong i hear time and time again TB sensors clogged dirty or bad check your codes
Posting And You
04' dak QC 4wd, 285/75/16 BFG's_________________________________________06' 300C SRT8
SPC. Brinkmeyer is offline
post #5 of 13 Old 01-13-2011, 11:04 PM Thread Starter
02dakota
02dakota's Avatar
CEL finally stayed on so I could check the codes. It gave me p 300,305,and 307 which basically means its misfiring. I have been slowly losing coolant so i suspect the head gasket may be bad and causing the hesitation some how(recently installed new water pump and thermostat and there are no coolant leaks, no white smoke from exhaust, and oil is clean). I'm having a mechanic i know check it out next week and I will update as soon as I know something.
02dakota is offline
post #6 of 13 Old 01-13-2011, 11:11 PM
SPC. Brinkmeyer
Jason is the name
Quoted: 2 Post(s)
Garage
heater core for loss of coolant i heard some of them leak and have a drain for it to run outside of the vehicle to keep it out of the cab of the truck do you ever notice any coolant drops in your driveway or anything or smell any burnt coolant or the smell of plain coolant in the cab
Posting And You
post #7 of 13 Old 01-22-2011, 01:17 AM Thread Starter
02dakota
02dakota's Avatar
Just to update: The drivers side catalytic converter is bad, so that is what was causing it to hesitate. As for the loss of coolant, there was a leak in one of the hoses for the heater. Should I replace the old cat with a high flow one? If I did would it cause any problems if I left the stock cat on the passenger side? Anyone know of some good replacements for the cat?
02dakota is offline
post #8 of 13 Old 01-22-2011, 05:46 PM
SolidStateS15
well the stock ones are more expensive and flow like crap so i would replace them both with universal high flows. you can get them on ebay for like 40 bucks. you also need to find out why it's clogged. it means you have a problem like burning oil.
post #9 of 13 Old 01-24-2011, 04:26 AM
SPC. Brinkmeyer
Jason is the name
Quoted: 2 Post(s)
Garage
are you sure its realy clogged or its just the sensor saying it i got a 04 and last year it said it was bad we replaced the y pipe with cats ($500+labor) and its saying its bad again this year i think i just have a wire rubbing somewhere... but with yours actualy hesitating maby realy is bad...
Posting And You
post #10 of 13 Old 01-24-2011, 05:12 AM
mthandt
mthandt's Avatar
Glad i was right but then again I'm not because it's not the cheapest thing to fix. I would recommend you do this vvvvvv it's the best thing price wise and performance wise.
My truck is cool.
mthandt is offline
post #11 of 13 Old 01-24-2011, 05:20 AM
SPC. Brinkmeyer
Jason is the name
Quoted: 2 Post(s)
Garage
next time i replace mine thats what im going to do
Posting And You
post #12 of 13 Old 01-24-2011, 05:27 AM
mthandt
mthandt's Avatar
Yeah man, that's definitely the better route IMO. I replaced my one cat with a Magnaflow one and it didn't stop my code but it was worth it to me for the cost effectiveness and the little bit of performance gain.
My truck is cool.
mthandt is offline
post #13 of 13 Old 01-24-2011, 05:40 AM
SPC. Brinkmeyer
Jason is the name
Quoted: 2 Post(s)
Garage
yea i think i might have a wire rubbing somewhere and grounding out or something idk the code comes on and goes off as it wants lol idk but im either going to bust em out next time or put in a high flow prolly go with a high flow so the sensors still work
Posting And You
