97 Dakota (3.9L) will another ECM help me ? - Dakota Durango Forum
Computer Control Parts Info Links : PCM Modules
post #1 of 17 Old 01-12-2011, 12:39 PM Thread Starter
slade25
Vehicle: 1997 Dakota sport
1997 V6 Dakota 3.9L 176,000 Km automatic trans
issue #1 - comm error unable to run a scan
#2 - various "hic ups" lately seem to point to ECM
maint (1) - i had an auto electrical tech work 90 min searching for the scan problem. He found no opens, shorts and bad wiring at connector port end. His conclusion was that my ECM was the culprit.
maint (2) - vehicle constantly stalls out, especially when shifting gears. When idling or in traffic it wants to hic up/burp and stop working, unless i keep the accelerator suppressed. Once the vehicle warms up, this problem usually ceases (but not always). I have replaced wires, igniton coil and plugs, as well as the temp sensor.
Speaking to another auto tech, he suggested i replace the ECM. Used ones are much cheaper (of course). If I do this, and get an ECM same year,engine, model, will it work okay for me(after it settles in and assuming it is fully functional)? I'm wondering if the Dodge dealer has to get involved with any updates, flashing, etc ? Because it's a 1997 vehicle, i would think updates have long since ceased.
If anyone could advise and assist, it would be much appreciated.
Steve
slade25 is offline
post #2 of 17 Old 01-13-2011, 12:59 AM
neromo4
neromo4's Avatar
Vehicle: 04 Dakota CC Sport
mine used to have "hic ups" and then i cleaned off a ton o carbon that was on the iac, and i did seafoam. no problems fo years now.
neromo4 is offline
post #3 of 17 Old 01-13-2011, 11:25 PM Thread Starter
slade25
I've been reading a few of the PCM posts on recent similar issues. I'm more confused now than before !?
I could really use accurate clarification on this one.
Can anyone with a confident degree of experience and know how answer the following please:
If I obtain another used PCM for my 97 Dakota (3.9L,2wd,auto) do I have to do anything to the PCM before installing it in place of the original ?
i.e. 1. do I have to have my VIN programmed into it, 2. do I have to get it flashed or updated at the Dodge dealer ?
3. what is the complete procedure to "re-establish" full communication with the truck, once the new/used PCM is installed? and how long should this take ?
thanks,
Steve
p.s. with respect to cleaning the IAC, i'm not familiar with seafoam. What exactly is this ?
slade25 is offline
post #4 of 17 Old 01-14-2011, 01:18 AM
neromo4
neromo4's Avatar
neromo4 is offline
post #5 of 17 Old 01-14-2011, 09:29 AM
SteveBeRT
Vehicle: 2001 Dakota RT
I tried taking a PCM out of a 97 3.9l dakota automatic and put it in my 97 3.9l dakota automatic and the my truck would not start. The PCM would have to get reflashed for your vehicle.
SteveBeRT is offline
post #6 of 17 Old 01-14-2011, 04:29 PM
varsis
Vehicle: 97 dakota 5.9
Modifications: SAS'd, 5.9 swap, 5.38 gears, and much more...
Send a message via AIM to varsis Send a message via Skype™ to varsis
I have a PCM if you need one. Not sure if it will fix your issue but I think it's not the PCM by what you described.
Have you looked at the o2 sensors? Cap? Crank and cam sensor? But it almost seems like your tps is failing though
varsis is offline
post #7 of 17 Old 01-29-2011, 01:47 AM Thread Starter
slade25
ECM 97 Dakota issue
Dodge Dakota 1997 2wd auto 3.9L
problem: unable to run scan - getting link error
poor idling - stalls out frequently
poor gas mileage
--> i may 2 problems?
today i managed to get the check engine light to disappear, after removing all 3 bus harnasses to the ECM itself, verifying data and power continuities at the connector port and at the 3 connectors to the ECM.
i drove the truck about 25 miles, it works a bit better (still not right though) and the check engine alarm has not returned yet. So far I have no codes, but i still cannot "talk" to the computer with the scanner. Any ideas anyone ? (do i need a new ECM?).
as for the idling problem, I took out the IAC and cleaned it up well. It was quite dirty. I also used a performance throttle cleaner (poured some in carb and remainder in gas tank). When the truck is warmed up (approx 90-100 on my 25 - 150 temp gauge) it stalls less frequently. Temp sensor has also been replaced. When the truck is in Drive it will stall while idling (way more so when it has not reached it's normal operating
temp).
Any ideas on how to tackle my idling issue and the ECM no scan issue ?
slade25 is offline
post #8 of 17 Old 01-29-2011, 02:11 AM
Misfit
We Are 138
Misfit's Avatar
Vehicle: 98 Dakota V6 & 03 Cobra
Modifications: CAI,Xhaust,Flux Capacitor
Quoted: 20 Post(s)
Garage
Sounds like your computer is fried.
Get another one, i don't think it HAS to be a 97, just a 97+ 3.9, either way, it would need a reflash, then just install it and go.
Misfit is offline
post #9 of 17 Old 01-29-2011, 02:12 AM
Misfit
We Are 138
Misfit's Avatar
Quoted: 20 Post(s)
Garage
To make shit easy, Autozone etc sells computers, no idea how much they are, but they will be ready to install and go out of the box.
Misfit is offline
post #10 of 17 Old 01-29-2011, 03:49 AM Thread Starter
slade25
Did i hear correctly that pre 1999 vehicles do not have to get replacement ECM's flashed ? With mine being a 1997, if I get a replacement with identical specs, do I need do anything more than install, re-connect and let vehicle acclimatize for 10-15 min ?
I spoke to a person about that the other day as well, and his opinion was the same. No need to do anything to the replacement pcm if it's an older vehicle.
Can anyone clear this up ?
slade25 is offline
post #11 of 17 Old 01-29-2011, 04:18 AM
varsis
All I have read about PCM s is that as long as there is a vin and if you have security it needs to be programmed I think. if there is no security a vin it's ok. Btw all the PCM s I have put in my 1997 have ran a 1997 ram 1999 rt and soon another 1997 Dakota PCM when it shows up.
varsis is offline
post #12 of 17 Old 01-29-2011, 05:26 PM Thread Starter
slade25
strangely enough, my scan is now working/talking to the ECM. I did 2 or 3 scans and I have no codes.
When I run the I/M checks, I am getting:
Misfire - Ready
Fuel - Ready
CCM - Ready
EGR - Ready
O2S - Ready
CAT - NOT Ready
H2OS - NOT Ready
2AIR - n/a
A/C - n/a
can anyone advise on the 2 Not Ready findings ?
slade25 is offline
post #13 of 17 Old 02-18-2011, 12:43 AM Thread Starter
slade25
I still have the PO783 fault that`s been there for 3yrs.
Before I went to a transmission shop codes PO783 and PO141 came up on my cheapo obd ii. When I go there, the tech put his $10k machine on it and was coming up with nothing on the transmission diagnostic side. On the Engine side of the diagnostic he came up with both the PO783 & PO141. Kind of surprising but I` hoping that means the tranny side is okay.
Now here`s where it got very weird. We did a test drive and he left his $10k scanner hooked up as we drove around. The truck was performing worse than the drive over i might add - stalling out and seemingly slipping in gear and performing like crap. Then something i`d never seen before started happening. The Air bag light came on and an audible alarm started to beep (same sound as when the gas guage is low). And then the RPM and Speedometer guages started to flucuate and proceeed to zeroize. This was all while we were test driving. When we got to the parking to the told me he thinks i need a new ECM before i do anything else. He did another scan and was getting communication error. I thought oh noooo
We popped the hood and he checked the trans fluid, it looked and smelled okay he said. I pushed the 3 connectors from the bus harnass onto the PCM and put my cheapo obd ii on the scanner port and it read the damn codes ! PO783 and PO141 again. I went and got him again, he got his machine out and he got the same...and nothing showing on the transmission side. He still thinks i have a PCM related issue...intermittent or whatever (worst kind actually).
So I drive it home and the damn truck performs like a dream all the way. No stall outs, smooth shifting of the transmission, no coughs, burps, etc.
Talk about a system that is all over the place. I don`t know what to think now, but I`m sure it will act up again tomorrow morning after sitting all night.
Anyone have any suggestions on this conundrum ?????
Steve
slade25 is offline
post #14 of 17 Old 12-13-2014, 01:56 PM
Flippy
Vehicle: Dakota 2002 Sport Manual
1) Is it my ECU ?
irregular codes after resets but mostly O2 sensor P0138 but sometimes 0141 & others - Experiencing misfires which often go away on their own & can return on the same drive . Seems not temperature dependent a it occurs in very cold & hot .
2) what to check ( new plugs , wires & cap did not help)
3) 2002 dakota 3.9 auto trans
Flippy is offline
post #15 of 17 Old 12-13-2014, 06:03 PM
01dak3.9
Vehicle: 2001 Dakota cc 3.9 auto
Modifications: Planning a carbed 360
Quoted: 11 Post(s)
Maybe your O2 sensor needs to be replaced
2001 Dakota 3.9 Kicker speakers, 2 CompRT 10's, 600.1 amp, Edelbrock air cleaner
Sure I believe in peace. Peace by superior firepower! - Ted Nugent
01dak3.9 is offline
