fixing exhaust leak... - Dakota Durango Forum
Headers & Exhaust Parts Info Links : Headers * Exhaust
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
post #1 of 17 Old 12-30-2010, 06:56 PM Thread Starter
blackknight87
blackknight87's Avatar
Vehicle: 1997 Dodge Dakota Sport
So i had my truck in the shop to fix a leaky gasket. and while in there i had them check for an exhaust leak. Well sure enough the flange that connects the header to the Y pip is pretty well corroded and is likely the culprit for the leak.
My mechanic confirmed that the leak is from the corroded flange. But informed me it would be roughly...400 to fix. because i would need a new header, Y pipe and then labor. So i said ok, just leave it.
My question to you guys is how HOT do headers get? if they are within a certain temperature range i might attempt fixing the leak with some epoxy. I know of this stuff called PC Fahrenheit. Its used for high temp fixes. Ive used it before, but that was for a HID projector retrofit. That stuff was perfect.
so anyways her is a link to it, tell me what you think.
http://www.mcguckin.com/index.php?ma...roducts_id=973
1997 Dodge Dakota Sport 4x4, 5.2L V8
2010 Chevrolet Camaro 2SS/RS, Auto
blackknight87 is offline
post #2 of 17 Old 12-30-2010, 10:28 PM
SH0K0TA
Layin Low
SH0K0TA's Avatar
Vehicle: 1997 Dakota Sport
Modifications: Custom Diamond grille, Halo Headlights, replaced bumper for chrome bumper, chrome fender flares, side mirrors, roll pan and air dam ordered, subs, speakers, and blue neon lights
Send a message via AIM to SH0K0TA
it says not to use over 500*F... i wouldn't use it to fix that...
if you wanna fix it on the cheaper side... just go to the junkyard and look for a dakota, check for the Y pipe and offer 20-30 bucks and negotiate.
if you got the stock exhaust manifolds... get some $150 ones from ebay and take those 3 items with about 3 hours worth of work (can be done in the driveway) would save you a good amount of money.
SH0K0TA is offline
post #3 of 17 Old 12-30-2010, 10:51 PM Thread Starter
blackknight87
yea i found that the exhaust will be too hot for that stuff to work. i thought about doing it myself....idk. maybe.
Thanks.
post #4 of 17 Old 12-31-2010, 01:17 AM
SH0K0TA
Layin Low
SH0K0TA's Avatar
its really easy to do, honestly. but the easiest way (that i found) to do the headers was to put the front of the truck on jacstands, remove the front tires, and the plastic inner fender liners... then its straight shot for everything. only difficult part is the drivers side with the brake stuff right there.
SH0K0TA is offline
post #5 of 17 Old 12-31-2010, 10:57 PM Thread Starter
blackknight87
Yea i dunno it i wanna spend the money to replace the headers, cuz this truck is just a winter beater.
But ive heard that exhaust leaks cause loss of power and gas mileage. sooo it might be worthwhile to fix it.
post #6 of 17 Old 01-01-2011, 12:16 AM
SPC. Brinkmeyer
Jason is the name
SPC. Brinkmeyer's Avatar
Vehicle: 2004, Dodge, Dakota 3.7L
Modifications: 3" Body lift, 285/75/16 BFG A/T K.O.'s, 5% tint on rear windows and sun shade, 20% on front doors, Flowmaster 40 Series Single in Dual Out exhaust 8" long 3" tips, Line-X black Bedliner
Quoted: 2 Post(s)
Garage
Send a message via Yahoo to SPC. Brinkmeyer
hell yea they caus a lot of loss of power i hot the 3.7 and had the cats replaced and that jank ass shop cut off the rear flanges and jus clamped it and had two half dime size holes and i got 1 welded but the other was right next to the frame so we couldnt get to it so i tried some of thoes fix a hole in your exhaust clamps and other crap which didnt work... i finaly got a 3" body lift so we could finaly get to it and welded that hole up and its like a gained a extra ton of power...
but even if it is a beater y not jus pick up some ebay headers for 150 or 200 and get a y pipe from a junk yard for 50 and have a combined cost of $200 or $250 which would be cheaper than haveing your stock stuff replaced you could do it yourself and you would bump your HP up aswell
Posting And You
04' dak QC 4wd, 285/75/16 BFG's_________________________________________06' 300C SRT8
SPC. Brinkmeyer is offline
post #7 of 17 Old 01-01-2011, 12:26 AM
deanler
deanler's Avatar
Vehicle: 94' Dakota
just use copper silicone
deanler is offline
post #8 of 17 Old 01-01-2011, 12:28 AM
SPC. Brinkmeyer
Jason is the name
Quoted: 2 Post(s)
Garage
whats that... ive never heard of that
Posting And You
post #9 of 17 Old 01-01-2011, 12:40 AM Thread Starter
blackknight87
I would be up for doing new headers and the y pipe, but im just nervous about breaking bolts off in the engine block. Since they are pretty old and rusty. I dont want to be in a situation where the truck isnt drivable. know what i mean.
whereas if i take it to a shop. i dont have to worry about it.....just pay out the ass. lol
post #10 of 17 Old 01-01-2011, 12:43 AM Thread Starter
blackknight87
http://www.motorcycle-superstore.com...t-Sealant.aspx
Copper silicone is only good up to 700 degrees. Ive read that exhaust gas can be anywhere from 500 to 1500. i wouldnt use that stuff.
post #11 of 17 Old 01-01-2011, 12:48 AM
SPC. Brinkmeyer
Jason is the name
Quoted: 2 Post(s)
Garage
my friend did his headers in the 318 he told me to try the bolts and see if you can turn them and spray them with some pb blaster every day for like a week or 2 before you wanna change them and they should come right out due to the penetrating lube and the heat helping it go through the threads... but if you dont wanna take off the old manifolds cuz you are afraid of breaking off the bolts then take it to a shop and have them take off the manifolds and y pipe and rent a car dolly and toe it back to your house... think they like $50 a day... and slap on the new headers and y pipe
Posting And You
post #12 of 17 Old 01-01-2011, 12:51 AM Thread Starter
blackknight87
Yea i could do that. but if i had it at the shop. i would just save my time and have them do it all. seems like a hassle for all that.
post #13 of 17 Old 01-01-2011, 12:58 AM
SPC. Brinkmeyer
Jason is the name
Quoted: 2 Post(s)
Garage
yea but thats y i said that way you could save some money lol it wouldnt be that bad i dont belive
Posting And You
post #14 of 17 Old 01-01-2011, 02:58 AM
deanler
deanler's Avatar
Vehicle: 94' Dakota
Suit yourself, I used that for over a year on my headers with no gasket, just the silicone. If your just trying to fill some pitting its probably your best bet.. Otherwise have a machine shop skim the header flange
deanler is offline
post #15 of 17 Old 02-05-2011, 04:51 AM
bennett15
bennett15's Avatar
Vehicle: 1998, Dodge, Durango
Modifications: 22s, 12K HID Headlights, 12K HID Fogs, 18" Fi SSD, TRX1200.1 TRX600.2, RE 6.5" Components
get yourself a welder or go to a local shop and get them to run a pass over the flange if need be can always just zip cut it off after
bennett15 is offline
