Problems No heat in back! - Dakota Durango Forum
post #1 of 9 Old 12-17-2010, 05:15 PM Thread Starter
Alpine247
Vehicle: 02 Durango
Just brought my first 02 durango and love it.But i notice it has no heat in the back front works fine.Ive search and it most likely it the blend door? Where is this located Thanks
Alpine247 is offline
post #2 of 9 Old 12-17-2010, 09:52 PM Thread Starter
Alpine247
Vehicle: 02 Durango
Well i took the rear seat out alone with the panel.First thing i check if the lines were hot.Which one was hot about middle way,the rest was cold.So i went to the pump notice it was leaking antifreeze out from the connector.So i took it off,And straight wired it to a 12v battery nothing.So im guessing i have a bad pump .Which is $110 on ebay
post #3 of 9 Old 02-14-2011, 01:56 PM
Tydog07
150,XXX Miles
Tydog07's Avatar
Vehicle: '02 Dur 4.7L SLT
Modifications: Dwight TB
Check my thread on this, I fixed mine because the rear heater door wasn't working.
5DW #187 A lot of stuff...
Tydog07 is offline
post #4 of 9 Old 02-14-2011, 03:03 PM
Vendetta
Black'd the F**k out....
Vendetta's Avatar
Vehicle: 02 Durango
Yes sir, I had the exact same problem when I bought mine(used)....did the cheapo epoxy job on it then(2 years ago) and am now wishing I would have just bought a new heater door......because it's broke again.
I'm in the sandbox right now so I'm missing MOST of the cold weather, but it's definitely on my list of things to fix AGAIN this summer...
5 Door Whore #156
Vendetta is offline
post #5 of 9 Old 02-14-2011, 10:37 PM
Tydog07
150,XXX Miles
Tydog07's Avatar
Yeah, it sure is nice to have. I'm having a weird problem that started within the last week when it was in the single digits. Only the highest fan settings works now, I have no fan/heat/cold air when the knob is set on the first three settings, but does work well on the 4th. I assume it's an electrical or knob issue, but I can't seem to find any fixes, I may start a thread soon.
Tydog07 is offline
post #6 of 9 Old 02-18-2011, 06:06 AM Thread Starter
Alpine247
Vehicle: 02 Durango
Not really worried about the back heat.The front will roast ur ass and will heat up the back.But lowest it gets around here maybe in the twenty's teens at night.So it not worth the hassle fixing it lol since it probably the door.
post #7 of 9 Old 02-18-2011, 08:24 PM
Tydog07
150,XXX Miles
Tydog07's Avatar
Well I fixed my front heater problems. Blower Motor Resistor block. $10 from dodge dealer, 15min. fix.
Tydog07 is offline
post #8 of 9 Old 02-23-2011, 03:56 AM
bmg97
Vehicle: 2002 Durango R/T
Modifications: Magnaflow Cat-back, HS1.7RR, K&N Intake
Where would you get the new heater door ?
2002 5.9 R/T, Magnaflow Cat-back, HS1.7 RR's, K&N Intake.
bmg97 is offline
post #9 of 9 Old 02-23-2011, 02:13 PM
Tydog07
150,XXX Miles
Tydog07's Avatar
You can't buy it new unless you buy the whole rear heating assembly. You have to go to a junk yard, but I found someone who was parting out on here.
Tydog07 is offline
