1997 5.2L Dakota 4x4 won't shift into OD when cold? - Dakota Durango Forum
post #1 of 12 Old 12-12-2010, 05:49 PM Thread Starter
SuperchargedWS6
Vehicle: 1997 Dodge Dakota V8 4x4
When it gets to about 5 degrees F or colder, my truck won't shift into overdrive. This is an issue as it spins 3100rpm at 65mph on the highway if not in overdrive. This means horrible gas mileage and also spinning the engine high when I'd rather be taking it easy on it (due to the cold).
Has anyone experienced this? Is there a fix for this?
SuperchargedWS6 is offline
post #2 of 12 Old 12-12-2010, 09:10 PM
sonderegger
Vehicle: '99 Dodge Dakota 5.2L 4x4
Modifications: Blue LED's, 33's, 3" Body Lift, Mtx Thunderform & More
your lucky mine wont shift into overdrive when its warm. itll kick back into 3rd once the truck starts to warm up and wont go back into 4th.
$onderegger"
1999 Dodge Dakota 5.2L 4x4 - 3" Body Lift - 33x12.5R15 Pro Comp Xterrain
Originally Posted by RedKota99 View Post
well, I cut it off, I then started it up to see how it sounded with the lack of the rear exhaust. I instantly lost 3 teeth and got the urge to have sex with my sister.
sonderegger is offline
post #3 of 12 Old 12-14-2010, 05:50 AM
360dakota
360dakota's Avatar
Vehicle: 1998 Dodge Dakota
i had the same problem yesturday. it was 13 below when i was headed back to college and it took 60 miles for it to decide to lock up. i went to a gas station and let it sit for 5 or so minutes, started it up and finished my journey and everything was fine. im assuming it was just cold
360dakota is offline
post #4 of 12 Old 12-20-2010, 04:42 AM
chuckyshamrok
RatBastard
chuckyshamrok's Avatar
Vehicle: 2000 R/T CC
Modifications: MSD Ignition, Mopar Headers
Garage
This is a stupid question, but have you checked the tranny fluid?
~2000 Dodge Dakota R/T CC~
6000K HID's, Graphite R/Ts, Mopar Headers, Spectre Xtreme Air Cleaner, Taylor Ignition Wires
chuckyshamrok is offline
post #5 of 12 Old 12-28-2010, 03:52 AM
DakotaNash
Texas, Pffffft
DakotaNash's Avatar
Vehicle: 01 4.7 Sport, 06 GTO
Modifications: Headers, K&N Air Filter, Dual Exhaust w/ No Mufflers
Mine does the same thing. Once its up to operating temp then it should to back to normal.
Originally Posted by Underdog Racing View Post
so go give him a hug.....around his throat....with a winch cable
DakotaNash is offline
post #6 of 12 Old 12-28-2010, 07:03 AM
iangoround
Vehicle: 2001 Dodge Dakota
The transmission is designed to stay out of overdrive in extreme cold until the fluid is up to a certain temperature in order to prevent damage. Check your manual, I know I remember reading about it in there someplace.
Ian Hildreth
2001 Dakota 3.9L AWD
1986 Daytona Turbo Z C/S
iangoround is offline
post #7 of 12 Old 01-03-2011, 10:02 PM Thread Starter
SuperchargedWS6
Yup, fluid is OK. It may be there to protect the tranny until the fluid is up to temp, but my problem with it is, no other vehicle I have ever been in does this!
I'm saving my tranny, but running a cold engine on the highway at 3200rpm. Personally, I'd rather keep the engine revs down and risk the tranny. In the cold temps I drive really easy (accelerate really slow) so I'm sure there would be no harm.
Normal operation or not, I was wondering if there is a temp sensor or something and if I could bypass it. Sounds like no one has done this as for most, it doesn't seem to be an issue.
I was looking at rebuilding my engine and putting some money into it, but this is a deal breaker for me. If I get no overdrive for most of my winter months, I may as well sell the truck and get something different to drive/mod.
post #8 of 12 Old 01-03-2011, 10:36 PM
chuckyshamrok
RatBastard
Garage
are you letting the engine warm up before you get on the highway, or are you getting on right away without letting the engine warm up?
post #9 of 12 Old 01-03-2011, 10:48 PM Thread Starter
SuperchargedWS6
I always let the engine warm up for about 5 mins, but that makes no difference to the tranny.
In these temps, the engine really doesn't warm up much until you are driving it, and I live right off the highway, so there is no change to drive around at low speeds until it fully warms up.
post #10 of 12 Old 01-04-2011, 06:05 AM
iangoround
If there is nothing mechanically wrong with the truck, I'd suggest swapping in a 5spd or trading for a truck that is.
Ian Hildreth
post #11 of 12 Old 01-04-2011, 02:04 PM Thread Starter
SuperchargedWS6
The 5speed is actuall a really good idea!
post #12 of 12 Old 01-11-2011, 06:14 AM
360dakota
360dakota's Avatar
i would let it warm up longer. i let mine warm up for about 15-20 minutes and everything is fine. and this is in -10 degree weather
