2003 - 2008 Dodge Durango Timing Chain with Sprockets FULL SET - Dakota Durango Forum
post #1 of 1 Old 12-09-2010, 05:29 PM Thread Starter
1ATony
1ATony's Avatar
Vehicle: 1998 dodge durango
PLEASE VISIT OUR WEBSITE FOR CURRENT PRICING
This complete timing chain and gear set is just what you need to keep your Dodge Durango 4.7L engine in good running order.
Our timing belt or chain sets come from a company that is commited to supplying components that are engineered and manufactured under strict quality control procedures. They are leaders in timing component quality which provides you with the highest quality parts available on the market. They are an importer and supplier of high quality timing system products manufactured by both OEM and aftermarket manufacturers that understand quality standards. The distinct difference between them and other companies is that they are consistently supplying the highest level of quality components that is in demand from ASE Certified Mechanics everywhere!
The parts that you will receive in this kit are the same superior quality parts that the high level competition engine rebuilding shops call for and use everday. So do not settle for lesser quality parts when it comes to engine repair. Only go for the best knowing that 1A Auto has already done the research for you on the highest quality suppliers available!
This high quality, timing chain set, contains the following pieces and has the following specifications:
(1) - Primary Timing Chain - 70 Link
(2) - Secondary Timing Chains - 106 Link
(1) - Primary Chain Tensioner
(1) - Secondary Chain Tensioner - RH Side
(1) - Secondary Chain Tensioner - LH Side
(2) - Guide Rails - Fixed
(2) - Guide Rails - Tensioner
(1) - Camshaft Sprocket - LH - 30 Teeth (Has No Ring)
(1) - Crankshaft Sprocket - RH - 30 Teeth (with NGC Ring)
the "NGC" sprocket has 8 window sets having 1,2 or 3 widows per set. Clockwise from key way NGC ring has the following arrangement of the window sets. 1,3,1,2,2,3,2,1
(1) - Crankshaft Sprocket - 25 Teeth
(1) - Idler Sprocket - Primary - 50 Teeth
(1) - Idler Sprocket - Secondary - 30/30 Teeth
Fits the following Dodge & Jeep engines as listed:
V8 4.7L (8th Vin Digit N) (NGC Engine - Has 32 Tooth crankshaft tone wheel)
Please note: This timing chain set is designed for the professional installer. It does not come with any installation instructions. If you do not have a service manual, please consult a professional mechanic prior to installing this kit.
Most car manufacturers recommend changing your timing belt between 50,000 and 70,000 miles (consult your owner's manual to see what your specific manufacturer suggests).
1ATony is offline
You may not post new threads
You may not post replies
