Idler Arm replacement Question(s) - Dodge Durango Forum and Dodge Dakota Forums
  #1
Old 11-05-2010, 08:56 AM
FEFD17's Avatar
FEFD17 FEFD17 is offline
Vehicle: 1999 Dodge Dakota
Reputation: 11 FEFD17 is just getting started
Hey everybody! hope all is good,I however am about to send this F"in P.O.S. Dak to the yard.I know it's not the truck's fault but I am getting really tired of everything I look at needing to be replaced.I am in the process of getting the truck ready to plow for winter.I jacked the front of the truck, found around ohhh a shitload of play in the front end and realized the Pitman arm is toast.I get the part in hand and crawl under.I grab my 1 1/4 wrench and it wont fit, shit.... get my big crecent wrench and grab on to the nut and it will not budge.My questions are,Anybody know what size the nut is that holds it to the steering box?Second question, is it normal thread or is it backwards?I for the life of me cannot believe it's THAT tight.I really dont want to pull the steering box,I have enough to do now.I have inner and outer tie rods,ball joints,Upper AND lower,Shocks and control arm bushings all ready to go,I just wanted to get the Pitman in first.Thanks for any help !!!!!
__________________
1999 Dakota 5.2, 3.92 gear 31x10.5 tire Curtis 7.5' poly plow.
At least I only push snow,If I drove Ford I would be pushing the truck too.....
I work on them all.......And they all suck when they break....
  #2
Old 11-07-2010, 12:56 AM
FEFD17's Avatar
Can anybody help me out here??PLEASE! I need my truck back A.S.A.P. I just need to know:
1) Can the pitman arm be swapped out with the seering box still on the truck?(I really really REALLY hope so)
2) what size is the nut holding the pitman arm to the steeering box?
I have a 1 1/4 (too small) 1 5/16 (fits but just seems sloppy) and a 34MM (seems like it's bigger than the 1 5/16).
3) Are they always that FRIGGIN" TIGHT!!!! holy crap!
4) Is it better to disconnect it from the center idler bar before I try to take the nut off?(just wondering if it's binding it up by holding tension onto the steering box because the joint is that sloppy)...just wondering..
Any input is really appreciated....I dont dare run it with the arm that bad,and I really need my truck to help out at the firehouse to move stuff around at the firehouse.THANKS for any help!
__________________
  #3
Old 11-07-2010, 12:16 PM
Dman98 Dman98 is offline
Reputation: 10 Dman98 is just getting started
I have a 98 Durango, to remove mine I had to remove the gearbox, impact the nut off and use a puller to get the Pittman arm off. To install make sure the key way line up, start the nut and as you tighten the nut the arm will be pressed on. Make sure the note the orientation of the Pittman arm in reference to the gearbox and install the same way or your steering wheel will be off.
  #4
Old 11-07-2010, 01:42 PM
l1tech l1tech is offline
Vehicle: 02 Dakota CC 4.7
Reputation: 24 l1tech is just getting started
I don't know what size the nut is so I can't help ya there but I have repalced alot of these. The threads are normal. If you don't have a pitman arm puller then stop where you are because you will not get the pitman arm off without one. When you put the new one back on be dam sure that you torque it or else you won't get it seated all the way and it will come loose.
__________________
  #5
Old 11-07-2010, 02:53 PM
6shooter's Avatar
6shooter 6shooter is offline
Resident Craigslist Whore
Vehicle: Silvy, Kota and a Harley
Reputation: 104 6shooter is just really nice6shooter is just really nice
remove the center bar from the idler arm first. if you pop the idler off the box, the center bar and idler will be floppin around while your trying to get them separated and itll be miserable for you. for socket size, make sure you're using a 6 pt socket, not a 12 pt. use an impact to get the nut off the steering box, or use a hammer and give the idler arm few smacks to help bust that nut free. to split the idler arm from the box, and from the center bar, a pickle fork and BFH is your friend.
__________________
  #6
Old 11-07-2010, 05:47 PM
FEFD17's Avatar
I appreciate the info everyone.I am going back out now to get this off.I did mark it already.I just got a new can of PB Blaster and found my 3lb mini sledge........I did however get my exhaust on instead.I came off the manifold with a new y pipe,connected to a new Dynomax cat and pipe that runs into a Flowmaster Super Turbo muffler and tailpipe.Now I just have to get it so I can drive it again instead of having to listen to it in the driveway...LOL...here we go again...be back later.Thanks again!!!!
__________________
  #7
Old 11-07-2010, 07:00 PM
If you use a pickle fork be careful not to mess up the gear box. One big problem with using a pickle fork is that it won't evenly apply downward force onto the pitman...it will more or less cock it very slightly...this may prevent it from breaking loose.
__________________
  #8
Old 11-07-2010, 07:17 PM
FEFD17's Avatar
I have a pitman arm puller.I fully plan on using that.I do think my plow frame is what is making it that much harder to get the leverage to get onto it,to get the nut loose.I have a shitload of work left to do,4 ball joints,inner and outer tie rods,(for both sides) I might even get a new idler joint and idler bar off Ebay(WAY WAY cheaper than anywhere else I can find it) and the front shocks I already have.I have 6 Quarts of new oil and a filter for it and just need to get the worst of all this over with--that being the Pitman arm.If I dont get it off today I am calling to see if anybody local can get it in.It's just so sloppy I dont dare drive it-----it is really that sloppy.Thanks for the help everybody,I need my truck back-(really I just have a ton of work at the firehouse to help with.)I will post back later with how this turns out!
__________________
  #9
Old 11-07-2010, 07:39 PM
6shooter's Avatar
thats why you pound the fork in just enough so you dont need to hold it in place, then use the hammer to tap on the pitman arm around the bore that the steering shaft sits in. ive had them fall right off after a few taps before.
and since he has a puller, he'll be in good shape. when you use the puller, putting tension on it and tapping periodically on the arm never hurt anything!
__________________
  #10
Old 11-08-2010, 02:30 AM
FEFD17's Avatar
Well,I got the steering box off.I had no friggin'choice so I pulled it.Put the steering gear on the floor,put the puller on it and it will not pop off.I have tension on it,have been hitting it with a hammer---only on the pitman arm-(NOT the steering box). I had to call it a night,I was getting to the point I was going to start throwing shit and I would have regretted it later.The worst smelling part of this whole bag of shit is the old pitman orm has ZERO play in it(I may have under load of turning the wheels)-but that is a complete guess.I have it out I am changing it anyway.What a bitch.
__________________
  #11
Old 11-08-2010, 02:42 AM
6shooter's Avatar
sometimes a torch is the only way. or a cut off wheel on a die grinder.
__________________
  #12
Old 11-08-2010, 01:32 PM
Tighten the puller as tight a you can get it then heat it with a torch...it'll pop
__________________
  #13
Old 11-08-2010, 07:14 PM
FEFD17's Avatar
Well I got it off.I tied the steering wheel off,checked the steering shaft and....shit...The top of the shaft--the "keyed" part of it is good the left side is good the right side looks like the splines are wore off.The metal bushing inside the shaft is toast.I am really losing patience fast with this truck.
__________________
You may not post new threads
You may not post replies
