Clunk from front suspension - Dakota Durango Forum
post #1 of 15 Old 10-29-2010, 03:53 AM Thread Starter
cheapdakota
cheapdakota's Avatar
Vehicle: 1998 Dodge Dakota SLT 2WD
Got a minor issue. Every so often (usually in reverse and turning to right at same time) I get a "Clunk" coming from what feels/sounds like the left front close to the wheel. I thought maybe ball joint or tie rod went bad. Took to shop and all linkage was solid however due partly to age and partly to small power steering fluid leak, my sway bar end link bushings are are shot as well as the lower control arm bushings. I plan to replace these this weekend but do you think that this is really the problem? Could bad end link and control arm bushing create enough suspension movement to create this loud clunk sound? Also, looking at a few different bushings. What would you guys recommend: Polyurethane, OE Rubber, or that material the Moog uses (forget what its called)? Thanks for the help.
http://www.dakota-durango.com/forum/image.php?type=sigpic&userid=17706&dateline=128806  1424
cheapdakota is offline
post #2 of 15 Old 10-29-2010, 08:39 PM
blown 346
Vehicle: 2004 Dodge Dakota
Yes a shot bushing in the Control arm/end link is enough to create the noise your hearing.
I would replace it with a poly bushing. They will last longer, help the truck handle better. Moog is a great choice...
blown 346 is offline
post #3 of 15 Old 10-30-2010, 01:56 AM
hotrodbob38
Vehicle: 2002 dakota r/t cc
I would REALLY check the intermediate shaft...TRUST me, my truck had the sam eproblem..it drove me crazy..It was only starting to go and made those noises..I repalced alot of things and it ended up being that..when you put a new on in, make sure to tighted the hell out of it..if either bolt on either end is even a little loose, the same problem will happen...
hotrodbob38 is offline
post #4 of 15 Old 10-30-2010, 03:23 AM
AFDakRT
14 cylinders
AFDakRT's Avatar
Vehicle: 2000 Dakota R/T
Send a message via AIM to AFDakRT
Check the nuts that hold the upper control arm to the frame rail. They can work themselves loose over time, especially if you've had a alignment recently and they weren't tightened enough.
Amber Fire Pearlcoat 2000 Dodge Dakota R/T
Schwarz 1991 BMW 535i [Daily Driver]
AFDakRT is offline
post #5 of 15 Old 10-31-2010, 12:06 AM Thread Starter
cheapdakota
Replaced end link bushings today with Moog bushings. Still making same noise. But time was not wasted because the bushings were definitely shot (disentigrated in my hand). Also changed the oil, changed the color of my headlights from yellow back to white, and degreased my engine. It was a good day. Will save the clunk hunting for next weekend. Next steps are to try everything you guys mentioned. Also, is replacing lower control arm bushings really that difficult? Sears Auto wanted $450+ just in labor to relace them.
post #6 of 15 Old 10-31-2010, 06:46 PM
hotrodbob38
I had the same problem and replaced alot if "iffy parts". Parts that were showing wear..I did upper/lower ball joints, end links, outer tie rods..
I sprayed some grease into the control arm bushings, and it helped, A LITTLE..If you go in reverse up a small incline, turn the wheel hard to one side, its most likely control arm partds or intermediate shaft. I havean 02 rt club cab..The new intermediate shaft made my truck hand like new..( it only has 70K miles and I am very easy on my vehicles). If you have any kind of miles on your truck, try the intermediate shaft next..very easy to do..less than 1/2 hour, and most of the time is finding the tools!
post #7 of 15 Old 11-14-2010, 11:08 PM
jpayne80
K-State fan
Vehicle: 2003 Dakota Quad Cab 4x4
Did you ever happen to isolate the problem? Mine is making a similar noise. Thanks!
jpayne80 is offline
post #8 of 15 Old 11-15-2010, 12:22 AM
blown 346
My truck makes the same noise up front when it wants. My Tie rods are the root of the problem. Bot inner and outers have play.
post #9 of 15 Old 11-15-2010, 12:38 AM
jpayne80
K-State fan
When you say "play", what exactly do you mean? When the suspension is unloaded I can twist them. That's normal, right?
I do think I just figured out my problem. My darned passenger hub bearing in bad. I can wiggle the wheel about 1/4 inch.
I also noticed that I have the original ball joints on...110,000 miles on them. Bad or not I'm going to replace the uppers soon.
jpayne80 is offline
post #10 of 15 Old 11-15-2010, 10:39 PM
celicoupe
celicoupe's Avatar
Vehicle: 1999, Dodge, Durango
Check to see if your shocks are loose at the fittings. My 2WD ram had this issue.
celicoupe is offline
post #11 of 15 Old 11-16-2010, 06:28 AM
caleprofiveo
this is dayadge country
caleprofiveo's Avatar
Vehicle: '98 Dakota CC V6 2wd
Modifications: 3.92 9.25" lsd, added rear swaybar, headers, ud pulley, 19lb t-bird injectors, t-bird electric fan, 20% tint...
by play he means movement from side to side within the tie rod. just grabbing it and moving it around will not let you observe the play in it. jack up the front end and with your hands at 3 and 9 o'clock on the tire grab it and push/pull on it to observe the play or looseness in the tie rods. you shouldn't feel any.
i'm somewhat new to working on these truck but i think i saw that the 4x4s have press in ball joints. i had to do both uppers and lowers on my 2wd and it was a nightmare.
cale
caleprofiveo is offline
post #12 of 15 Old 11-16-2010, 07:33 PM
atvryan
atvryan's Avatar
Vehicle: 99 dodge dakota
mine had a clunk like that last year, it was the sway bar link,
atvryan is offline
post #13 of 15 Old 12-30-2014, 03:29 AM
Amphere
Are you talking about the intermediate shaft on the steering column? My dealer said that was causing my 'click' but I thought replacing it required dealing with the steering wheel and air bag, making it a tough job.
Amphere is offline
post #14 of 15 Old 12-30-2014, 03:35 AM
jpayne80
K-State fan
Very easy to change:
1. Secure steering wheel so it doesn't move (don't know if necessary)
2. Remove upper bolt completely.
3. Remove lower bolt completely.
4. Remove intermediate shaft by compressing (easier to remove)
5. Install new intermediate shaft.
6. Install upper and lower bolts.
You're done!
jpayne80 is offline
post #15 of 15 Old 02-14-2017, 03:42 PM
jkelley
Vehicle: 2002 Dodge Dakota
I know this thread is old and I don't post often, but I have been trying to find the root of my wobbly tire noise and a loud clunk that 99% of the time will happen when I go from reverse while backing out left and then shifting to drive and turning right.
I did a nearly complete front end suspension change out (upper and lower ball joints, sway bar end links, sway bar bushings, tie rod ends) and before I got to the control arm bushings on the front right (the side I started on) when I jacked up the lower control arm before popping the ball joint out I swung the knuckle around and clunk.... I swear I saw the upper control arm just move left... swing it right... the control arm moved right. The top right nut on the alignment rod of the upper control arm was definitely loose. So that was the source of my loud clunk and my bad tire noise (from having the clunk for way too long). I'm sure this also accelerated the wear on my wheel bearing which I replaced a couple months before that (thinking that was the source of the wobbly noise).
Noise is gone now that after getting the car aligned. It wasn't gone after I put the truck back together and drove it to the alignment shop (even though I torqued it to spec). I mentioned it to them and now it's not making the noise so maybe they just added some torque on it.
2002 Dakota Quad Cab 4.7 2WD
I still have shocks to do this weekend. Dunno why I was too lazy to do them (need to cut the top hat bolts off) when the upper control arm was free... oh well.
jkelley is offline
