valve roller rockers keep falling off - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
post #1 of 18 Old 10-24-2010, 06:27 PM Thread Starter
HectorR2006
HectorR2006's Avatar
Vehicle: 2001 Durango SLT4.7
Okay, let me start by saying that I just finished paying over $1400 to get remaned heads/ valve assembly because 2 of my rocker arm's/ rollers fell off some how. anyways, now that I have brand new heads, it did it agian. Is there something else that could be causing the rollers to fall off like that. the work is under warranty, so im gonna bring it back to the shop but what could possibly be causing this truck to do this with all the top end being new? Has anyone had any similar problems? Its a 2001 durango slt4x4 4.7 btw.
HectorR2006 is offline
post #2 of 18 Old 10-24-2010, 09:41 PM
rimfire,22
Vehicle: Dodge Durango
hectorR2006,
Funny you mention this. My 4.7 Durango is in the shop because of a loss of compression to the no.5 cylinder and one of the possibilities is that maybe the rocker may have fell off too!!! He believes my valve is either stuck in the open position due to carbon or maybe the rockers. I too am puzzled about the possibility. So far he says I have no head gasket issue so for that I'm sorry you had your redone for such a large price.
rimfire,22
rimfire,22 is offline
post #3 of 18 Old 10-25-2010, 12:55 AM
l1tech
Vehicle: 02 Dakota CC 4.7
You said you have reman heads, did they rebuild/resurface your old heads? Dodge does not recommend resurfacing the heads on these motors and I have seen some shops do it and the end result is cam followers that keep popping out of place. I have had luck on one motor with installing new lash ajusters but the other 3 that came to me from another shop we were not able to fix until new heads from Dodge were installed.
Just a question but has this motor been severly overheated that you know of at some point of it's life??
Forgot to mention that low oil pressure can cause this issue also. Was the top end of the motor sludged up when they pulled it apart?
l1tech is offline
post #4 of 18 Old 10-25-2010, 12:05 PM Thread Starter
HectorR2006
The engine has not overheated (not since I owned it) but when the shop did show me my engine it did have tons of slude on the top. The oil pressure was always high before the rebuild but now that you mention it, the oil pressure guage wasnt steady like it used to be. when i would turn it on after the rebuild, it would start off on high then make its way towards the middle then eventualy towards the lower "safeline". If i accelerated it, it would go back to high. So from what you stated, do you think the engine is no-good.
post #5 of 18 Old 10-25-2010, 07:46 PM
scjeep4.7HO
scjeep4.7HO's Avatar
Vehicle: 97 dakota, 04 G. cherokee
Modifications: 2004 Grand Cherokee. Supercharged 4.7L HO, cammed. meth injected, SCT tuned, 72mm F&B throttle body, 180* T stat, Magnaflow exhaust, Trans go shift kit W/ deep trans pan.
You may have a lifter/lash adjuster that has went bad. If it doesn't stay pumped up it could allow for the cam follower to pop out.
Paxton NOVI 2000 supercharged Jeep 4.7L HO, Cammed, Heads, Built Motor, Custom COG supercharger drive sysem, Custom ATI dampner w/ custom cog pulley, Both Sheet metal intake or stock intake, Turbo Smart race port BOV, 72mm F&B throttle body, Meth injected, SCT tuned, 60# injectors, Billet fuel rails, full Fuel system, True dual Exhaust W/Magnaflows, Iridium plugs, Built Transmission W/Trans-Go shift Kit, Deep trans pan W/Trans cooler, 180* T stat, 275 60 R17 rubber, ETC....
scjeep4.7HO is offline
post #6 of 18 Old 10-25-2010, 08:43 PM
l1tech
You need to put an actual mechanical oil pressure gauge on it to see what the oil pressure is doing.
If the engine had tons of sludge on the top side then you can bet that the oil pan is full of sludge also and may be clogging the oil pickup tube.
l1tech is offline
post #7 of 18 Old 10-29-2010, 10:54 PM Thread Starter
HectorR2006
so the shop ended up pulling the passenger side head and, well...one of the valve seats had fallen off and jamed itself between the valve and the opening. That inturn caused the rocker to fall off this time.
post #8 of 18 Old 10-31-2010, 04:49 AM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Vehicle: 2002 QC RAM 4.7L *SOLD*
Modifications: 2011 Grand Sport Corvette :)
Quoted: 6 Post(s)
Hopefully there was little to no damage.... Keep us posted.
NICK
AIR_RAM is offline
post #9 of 18 Old 04-03-2011, 04:17 AM
Jdk4387
JDKSXT03
Vehicle: 2003 Dakota Sxt
Modifications: 2003 Dakota, 3.9 to 4.7 swap, SAS!!!
this exact same thing just happened to me except cylinder #4. Also had bought re-man heads 8 months ago.
03' Dak on 37's with D44 and 8.8 underneath!
Jdk4387 is offline
post #10 of 18 Old 04-03-2011, 03:13 PM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Quoted: 6 Post(s)
I have heard that in some cases where the seats have been replaced that if not instlled properly the seats themselfs could come lose. When this happens they can prevent the valve from closing all the way... this leads to slack in the valvetrain as the cam lobe comes around to BDC, the follower is no longer riding the cam... and can just fall off...
Oil pressure and bad lash adjusters can also lead to this problem.
SPEED SAFE, NICK
AIR_RAM is offline
post #11 of 18 Old 04-07-2011, 02:32 PM
l1tech
Does anyone see a pattern here with reman heads???
l1tech is offline
post #12 of 18 Old 04-09-2011, 02:53 PM
KotaKid287
Chevy SUCKS!!!!!!!
KotaKid287's Avatar
Vehicle: 02 Dak, 95 XJ, 06 Corolla
Modifications: A few
I sure do.
Sucks to hear about the problems guys. To the OP, is your issue gonna be warranted?
God made Man, Samuel Colt made them equal.
KotaKid287 is offline
post #13 of 18 Old 04-11-2011, 02:58 PM Thread Starter
HectorR2006
sorry it took a while to reply but yeah they repaired the damage under warranty. I love my truck even more now. It seems to be getting great gas mileage now too!
post #14 of 18 Old 04-12-2011, 01:46 AM
KotaKid287
Chevy SUCKS!!!!!!!
KotaKid287's Avatar
Awesome, glad to hear it.
post #15 of 18 Old 06-19-2011, 08:35 AM
BlackDak
BlackDak's Avatar
Vehicle: 01 Flat Black X-AWD V8 QC
Modifications: RC Monster trucks, MoPar
I had the same thing happen about a year ago, due to an overheat. Also tapped the piston!
BlackDak is offline
