P0505, cant figure it out - Dakota Durango Forum
post #1 of 22 Old 10-14-2010, 10:43 PM Thread Starter
4wdurango
Vehicle: 2000,Dodge,Durango
I recently purchased a 2000 Durango 5.9 4x4, I am super happy with it just wish I could figure out how to fix the P0505 code. I have searched a bunch, online and on this forum and I have not found a solid conclusion as to what the fix is. I purchased a new IAC, set it to spec and put it in, reset the pcm to get rid of the engine light and it came right back. I cleaned everything, cleaned the old one tried both of them reset the engine light and it still comes right back on. Any help or advice would be very much appreciated. Thanks
4wdurango is offline
post #2 of 22 Old 10-14-2010, 11:01 PM
01dakotaqc
01dakotaqc's Avatar
Vehicle: 2001 Dodge Dakota
here is the code from this website. it may have something to do with your speed sensor or wiring
P0505 (M) Idle Air Control Motor Circuits A vehicle speed signal was not detected
2001 dakota r/t R.I.P
2002 dakota r/t new truck
mods: mopar headers, 3" spintech exhaust, k&n intake, m-1 2bbl, 52mm tb, asp underdrive crank pulley, viper fan, shift kit, HS 1.7 rr's, Dynojet Wideband, SCT, 2/3 drop
01dakotaqc is offline
post #3 of 22 Old 10-15-2010, 02:47 AM
l1tech
Vehicle: 02 Dakota CC 4.7
How did you set the IAC to spec???
l1tech is offline
post #4 of 22 Old 10-15-2010, 04:06 PM Thread Starter
4wdurango
The directions said to adjust it so the end copper colored thing was 1 and 1/8inch from the mounting surface.... I dont know though, the durango idled pretty high at that setting, and the one I took out sat out much farther, but it would still throw the code....
post #5 of 22 Old 10-16-2010, 02:31 PM
l1tech
How did you adjust it, there is no way too and it is something that is not meant to be adjusted. Get yourself a new IAC and you will probably be ok but when you take this one out of the box do not do anything to it, just bolt it in the pcm adjusts it.
l1tech is offline
post #6 of 22 Old 10-17-2010, 06:40 AM Thread Starter
4wdurango
Weird, I tried that first and the durango was idling around 1600 rpms...? I drove it for a while and reset the engine light with it idling that high and the idle never went down and the engine light came back... I took the IAC back to Checker and looked at another one that had directions that said to adjust it to 1 and 1/8 inch so I tried that, still idled a little high.... I will pick up another one from somewhere else and see how it goes...
post #7 of 22 Old 10-17-2010, 02:22 PM
l1tech
Well if you have had 2 different IACs in there and it won't idle correctly you need to look elsewhere for your problem. Barring any other issues tha may be causing your high idle like a vacuum leak you need to start checking the wiring from the IAC back to the pcm adn see if you have any issues there
l1tech is offline
post #8 of 22 Old 10-17-2010, 11:40 PM Thread Starter
4wdurango
Thanks for all the responses... With the stock IAC(meaning the one that was in there when I bought it) the durango idles fine and exhibits no problems at all except the engine light. With the replacement IAC the durango idled high and still had the engine light. I wonder if it was defective or something?? should I get an IAC from the dodge dealer? I will examine the wiring and post my findings.
post #9 of 22 Old 10-18-2010, 12:21 AM
l1tech
It's possible the IAC you bought was defective. You could try getting another one but I have a funny feeling that you are going to have the same issue.
l1tech is offline
post #10 of 22 Old 10-20-2010, 06:49 AM
mprete4
Vehicle: 2001 dodge ram 2500
check the connection at the pcm. the connector has a corrosion problem. let me know if this works. if you find corrosion. try your best to clean all the pins and then put diolectic grease (like you use on spark plugs) to keep it from corroding again.
mprete4 is offline
post #11 of 22 Old 01-02-2011, 06:13 AM Thread Starter
4wdurango
Its been a while since I last posted, but I just wanted to update the thread. I went out to start the Durango the other day and the battery was dead, or so I thought. I didnt get a chance to check it out until today and I found the ground connector for the battery was loose, and had a bunch of old dioelectric grease or something on it... I cleaned the crap out of it, and while I was at it I undid all the grounds I could find in the engine bay and cleaned them all with a metal brush. The outcome.... no engine light, the code is gone, so apparently it had something to do with a bad ground....
post #12 of 22 Old 01-02-2011, 07:24 AM
99Dakota
Diesel Mechanic
99Dakota's Avatar
Vehicle: 99 Dakota 4x4
you prob. didnt fix it. all you did was clear the pcm. the check engine light will be back.
did you clear the codes after u replaced the IAC?
99 Dakota Sport 4x4 3.9L V6
360 Air Intakez, V8 TB, MSD Coil, Magnaflow Y-Pipe back, Superchips 3715, Factory 3.92's, Firestone Destination A/T's, HID 5000K BI, HID 6000k Fogs, Monroe Sensatrac Rear Loadlevelers
99Dakota is offline
post #13 of 22 Old 01-02-2011, 07:26 PM Thread Starter
4wdurango
I have reset the PCM many times, and the light comes back immediately. when I started it yesterday I knew I had cleared the PCM, but I was expecting the light to come on right after I started it and it didnt. Yesterday I drove for about 15 min and no engine light, started it up this morning and let it run for a few minutes and no engine light. Its weird, but it seems like it worked. The new IAC I put in there was making the durango run worse than the original, so currently the original is in there, not the new one.
post #14 of 22 Old 01-06-2011, 03:13 PM Thread Starter
4wdurango
you were right, its back, just took it longer this time... when I was trying to fix it and I would reset the PCM it would be back on right when i started the durango... very strange......the search continues.
post #15 of 22 Old 02-04-2011, 03:59 PM Thread Starter
4wdurango
Thought I would add something that is strange to me... we have had extremely cold weather lately(for us down here in southern arizona). When the temps outside are freezing and below the engine light turns off... strange...
