Replacement ball joint torque spec? - Dodge Durango Forum and Dodge Dakota Forums
  #1
Old 12-30-2005, 03:52 AM
esheffield's Avatar
esheffield esheffield is offline
Vehicle: 1991 Dakota 4x4, 1998 Durango 4x4
Reputation: 10 esheffield is just getting started
Question Replacement ball joint torque spec?
I have a '98 Durango that needs upper ball joints. I picked up some locally (would have ordered Moogs, but don't have time to wait for an order right now). Anyway, what should I torque the bolts that attach the ball joint to the control arm? I only have the Haynes manual which says the ball joints can't be replaced and the whole arm must be replaced as a unit, so no torque spec there. And no data came with the replacements. I searched and found mention of 60 lbft in another thread, but they were talking about the lower ball joint - but I thought it pressed in anyway though.
Thanks!
  #2
Old 12-30-2005, 10:46 AM
razman131's Avatar
razman131 razman131 is offline
Home Owner....
Vehicle: 1999 Dakota R/T
Reputation: 29 razman131 must have done something right
Send a message via Yahoo to razman131 Send a message via Skype™ to razman131
best bet is to torque the fasteners using a torque chart for the size bolts. 60 sounds about right IIRC. when i re did my BJ`s last summer that is wht i used. if ya dotn get any better answers by Tuesday, let me know what size bolts they are(head size) and ill double check my charts at work.
you can replace just the BJ`s but for some reason seeing as they are RIVETED in, the service manual says its FASTER to replace the whole arm(read= $$$)
ya gotta cut off/drill out the rivets and use the suppied fasteners if ya just replace the BJ`s
  #3
Old 12-30-2005, 02:03 PM
addicted2blue00's Avatar
addicted2blue00 addicted2blue00 is offline
Vehicle: 00 dakota CC 98 dakota RC
Reputation: 56 addicted2blue00 has a spectacular aura about
all i can say is have fun and be ready to spend at least half a day doin it if ya never have. it took me 1 1/2 days but only cuz i swapped the springs -dropped- and replaced upper and lower, word of advice, air chisel would really be a must to be quicker and have ear plugs, i just tighted the bolts to the arms tight as i could, castle nut only enough to slip the pin in, and make sure you bend up the pin so it doesnt think about comin out. and if ya need brakes or wanna drop it or so now is a good time. heres a good way to get the rivets out, 2 ways or so. chisel the top heads off, change chisel head, chisel the center of the rivet, if it doesnt wanna come out then drill the center of the rivets out either half way or all the way, make sure ur bit is SHARP! or your wasting time, then try chiseling the center again or the bottom of the rivet to get whats left out, once all 3 are off itlls just fall off, also have it checked to see if you tierod ends -outer- could be bad cuz of the BJs goin out, they are easy to change out if so - took me 15 mins-. the air chisel will be your best friend, if ya got any questions pm me ill be glad to help. once your done think how hard those 6 rivets were, then think of the 30 i did to drop mine :biggthump
You may not post new threads
You may not post replies
