heater direction settings dont work... - Dakota Durango Forum
post #1 of 11 Old 09-20-2010, 08:01 AM Thread Starter
ericgwingarcand
ericgwingarcand's Avatar
Vehicle: 1997 Dodge Dakota 4x4
they worked fine until i flushed my heater n cooling system...prior to doing the flush i turn ed the heater on full n set the direction to full defrost...now its stuck on full defrost n i cant get floor or vents but it still turns off! WTF!!!
97 Dodge DAKOTA 4x4
ericgwingarcand is offline
post #2 of 11 Old 09-20-2010, 11:47 AM
Climb385
Mopar 4 life
Vehicle: 00 durango slt 5.9l
Modifications: Headlights, fender flares, v8 throttle body,
Send a message via AIM to Climb385 Send a message via Yahoo to Climb385
my durango did the same thing, did u just do a tune up or mess with the area around the brake booster?? if u look behind the drives side valve cover on the fire wall there is a lil vacuum line that comes our the firewall and goes to a "T" fitting, mine got disconnected check that,it come right out the firewall and goes up towards the cowl into a t driverside, by the valve cover
2000 Durango slt 5.9l flame red R.I.P 9/25/99- 8/2/2010 5 Door Whore #193
97 extendedcab dakota 3.9 281,xxx miles original motor and trans!! waiting on the big 300!!!
97 extended cab 5.2 108k miles
3inch lift, 15x10 procomp beadlocks, 31 a/t's
360 swap in progress!!! waiting on this thing called free time, lol
Climb385 is offline
post #3 of 11 Old 09-20-2010, 05:54 PM Thread Starter
ericgwingarcand
ya i think that is exactly my problem! cuz here is a pic of the hose i found broke...where does it run to the back of the HVAC controls?
97 Dodge DAKOTA 4x4
post #4 of 11 Old 09-20-2010, 07:24 PM
Climb385
Mopar 4 life
that runs into the fire wall right where those two hoses go in, but yea thats the hose, mine came undone at the t
Climb385 is offline
post #5 of 11 Old 09-20-2010, 08:24 PM Thread Starter
ericgwingarcand
so at the heater hoses? how hard is it to get behind the dash to the heater hose area so i can fish out this broken hose...or how hard is it to get to the hose in the first place? can i see the heater core pipes from under the dash?
97 Dodge DAKOTA 4x4
post #6 of 11 Old 09-20-2010, 11:34 PM
logikfive
logikfive
logikfive's Avatar
Vehicle: '01 Ram 2500 Cummins
Garage
You'll never see those hoses behind the dash. They are hidden well behind the HVAC box. The heater core pipes are inside the HVAC box, so you'll never see 'em even if you could look up under the dash.
You're in for a rude awakening if you need to get back there to reconnect it. The dash will have to come out (if not entirely out you'll have to move it back quite a ways into the seats) and if you can't see it then, you'll have to pull the heater box away from the firewall. If you're that far into it you might as well do the heater core and AC condenser.
logikfive is offline
post #7 of 11 Old 09-21-2010, 01:12 AM Thread Starter
ericgwingarcand
holy hell...ill just run a new vac hose from behind the controls to the fire wall!....
97 Dodge DAKOTA 4x4
post #8 of 11 Old 09-21-2010, 03:21 AM Thread Starter
ericgwingarcand
i dont think this lil hose ran through the same spot as the heater core hoses...there is no room n when i checked on another dakota it ran behind the engine...PLEASE can anyone check on a 97-99 dakota with a 5.2 where this lil vac hose goes...only reason why i coudnt is cuz the truck i looked under was in a front end collision so i could only peek in the bend in the hood since it woudnt open. Also a pick of where the hose goes into the fire wall would GREATLY be appreciated!
97 Dodge DAKOTA 4x4
post #9 of 11 Old 09-21-2010, 06:16 PM Thread Starter
ericgwingarcand
anyone? please god!!!!
97 Dodge DAKOTA 4x4
post #10 of 11 Old 09-21-2010, 06:43 PM
logikfive
logikfive
logikfive's Avatar
Garage
On my '99 Durango it's ran directly under the heater core hoses, through the same foam grommet that is used for the heater core nipples.
Doubt they'd change it strictly for Dakotas.
post #11 of 11 Old 09-21-2010, 07:16 PM Thread Starter
ericgwingarcand
ok so this vac line does it run directly from the back of the HVAC controls? and if so wich one is it? ill just run a new vac hose through the fire wall to that T since i dont feel like ripping my entire dash appart. thanks
97 Dodge DAKOTA 4x4
