Turn signals blink twice then stop - Dakota Durango Forum
Lights Parts Info Links : Clear Corners * Headlights * Headlight Covers * Tail Lights * Tail Light Covers
Thread Tools Rating: Thread Rating: 5 votes, 5.00 average. Display Modes
post #1 of 10 Old 09-14-2010, 10:49 PM Thread Starter
rrroscoe
rrroscoe's Avatar
Vehicle: 1999 Durango SLT
My 99 Durango has a turn signal gremlin. Left or right side doesn't matter, they will only blink twice after activating, then they stop blinking. If I turn them off then on right after that happens I get nothing. Three seconds later I can turn them on and only two blinks. Hazzards work fine. Can anybody help?
rrroscoe is offline
post #2 of 10 Old 09-14-2010, 11:43 PM
Rebel13
Mods Addict
Vehicle: 2K R/T
Is the stalk still engaged when they quit? If so, sounds like the flasher relay has burnt up.
Rebel13 is offline
post #3 of 10 Old 09-15-2010, 12:46 AM Thread Starter
rrroscoe
rrroscoe's Avatar
Yes the stalk is still engaged. I am going to get a flasher module and see what happens.
rrroscoe is offline
post #4 of 10 Old 09-16-2010, 12:29 PM
Neil
Neil's Avatar
Vehicle: 99 Durango
Yes replace the flasher module. That's what mind started doing when it went out. The flasher is on the back side of the fuse panel on the side of the dash.
Neil is offline
post #5 of 10 Old 02-01-2011, 06:01 PM
occupant
Occupant Ilied Industries
occupant's Avatar
The flasher is a PITA to get to. I just fixed this on our 2000 Durango. The fusebox has a panel on the far left side of the dash, only accessible with the door open. Open that and you'll see what might be a flasher unit but this isn't it. Look up above the parking brake pedal at the BACK SIDE of the fuse panel. There should be a beige plastic panel there with a black rectangular relay and a green square relay (if it's original). The green one is the flasher. It's the one on top. It's tough to get in and out if you have fat American fingers like mine. 5-prong, they run about $15-$20 most parts houses.
The problem with this single flasher system is it makes you think something big is wrong when it isn't. The turn signals will blink minimally and then not at all, but the hazards will keep working. These stupid 5-prong flashers have two circuits in them. The one that gets used most (the turn signals) will fail first, but the hazard light circuit will still work. So someone like me who is used to seeing two separate flashers in a vehicle will think, "well, there's only one flasher, so the flasher must be good if the hazards still work!" And we'll go spend $45 or $162 or whatever on the multifunction switch thinking it HAS to be the problem. I'm glad I changed the flasher first. Sounds different and I don't like the new click sound, but they WORK and that means I'll pass inspection next month if nothing else breaks between now and then.
Alan Moore - TOAD Towing - Westerville, OH
00 Suburban 1500 LS 4x2, white, 5.3L, 231K
occupant is offline
post #6 of 10 Old 06-07-2011, 03:50 PM
ta3834bbl
Vehicle: 2000 Durango, 2001 diesel
Same thing is happening to my wife's 2000 Durango. I've already pulled the relay thinking that might be it. Today it gets a new one and hopefully that will fix it. Thanks for the advice on here guys.
ta3834bbl is offline
post #7 of 10 Old 06-12-2011, 01:38 AM
occupant
occupant's Avatar
This is like the one we bought...5 prongs on it...
Cost about $19 at AutoZone, I see them for about $15 on Amazon.
Still working great 4 months later. Still hate the new clicky sound. Oh well!
occupant is offline
post #8 of 10 Old 06-12-2011, 10:49 PM
ta3834bbl
Yup, that did it. All fixed, and your right, this one sounds clicky / ticky . But it works. They had a generic one for 20 and the green one with the mopar # on it for 54 bucks. Yup, I got the 20 dollar one. Thanks for the advice.
post #9 of 10 Old 07-06-2011, 06:16 AM
tomgaz
Vehicle: 2000 dodge durango slt
same here i replaced the flasher and i was good to go.
tomgaz is offline
post #10 of 10 Old 08-09-2011, 07:22 PM
Levassor1
Vehicle: 2000, Dodge, Durango
durango turn signal relay burnout
Hi,
For several years, this 2000 Durango has occasionally blown the fuse for the turn signals. Now it does it almost instantly. I just replaced the flasher unit with one from NAPA and it fried instantly! All the blubs are good, btw.
I tried disconnecting the brake light switch and it made no difference.
Levassor1 is offline
