Question about electric fan - Dakota Durango Forum
post #1 of 13 Old 09-07-2010, 02:18 AM Thread Starter
DaveAz
Vehicle: 2001 Durango
Noticed on my 2001 durango, that I have an electric fan as well as the manual clutch fan and wonder when it's supposed to come on. Should it come on when the A/C is on, or just when it reaches a certain temp?
DaveAz is offline
post #2 of 13 Old 09-07-2010, 02:19 AM
jrp1588
jrp1588's Avatar
Vehicle: 2002 Dakota R/T Clone
Both. it comes on at about 215 I think...but don't quote me on that. It also comes on with the AC
Mods:
4.10 gears, Yukon Duragrip, BlkDak 51.75mm TB, M1 intake, AFE Stage 2 CAI, FMS 21# fuel injectors, Gibson Shorty Headers, SCT tune, clutch fan delete, HS 1.7 NA Roller Rockers, Single 3" Magnaflow exhaust.
jrp1588 is offline
post #3 of 13 Old 09-07-2010, 02:24 AM Thread Starter
DaveAz
Hmm...I have never seen it on, so I wonder then. Does anyone know if this would not work correctly if the blower fan resistor is not working. Blower motor only works on high. Gonna replace it once I get paid.
DaveAz is offline
post #4 of 13 Old 09-07-2010, 02:24 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
yup...what he said....both...but not sure about the temp it comes on
as long as your clutch fan works as it should, it may never come on unless AC is on
Little Blue Guy is offline
post #5 of 13 Old 09-07-2010, 03:07 AM
gocartone
gocartone's Avatar
Vehicle: 2001 Dakota 4x4 R/C
AC or defrost turns it on only, so turn either on and it should kick in. Your truck probably won't see 215 unless your pulling on a hot day or have cooling issues.
2008 Corvette 485whp
2001 RC 4.7 5-Speed 4x4
2006 Yamaha FZ6
2004 Honda 450R
gocartone is offline
post #6 of 13 Old 09-07-2010, 04:33 AM Thread Starter
DaveAz
When sitting idling w/ the A/C on, it starts to warm up in this AZ heat. Like I said tho, I've never seen it on...Have to do some testing to see what's up I guess.
DaveAz is offline
post #7 of 13 Old 09-07-2010, 05:57 AM
gocartone
gocartone's Avatar
Have you turned the A.C. on and checked to see if it was running? There is a fuse for it under the hood IIRC if it doesn't work.
2006 Yamaha FZ6
2004 Honda 450R
post #8 of 13 Old 09-08-2010, 01:21 AM Thread Starter
DaveAz
I did check, and no worky...checked fuses, and all are ok. Gonna check the relay later today. Does anyone know if the blower motor resistor is bad, and only blowing on high, if it would somehow affect the electric fan in engine bay from operating?
DaveAz is offline
post #9 of 13 Old 09-08-2010, 03:40 AM
nitrohog
nitrohog's Avatar
Vehicle: '99 Dakota R/T Club cab
Garage
The blower motor resistor should not effect the operation of the electric radiator fan. I think you either have a wiring issue, fan motor issue, or a bad relay if all fuses check out.
'99 Custom R/T --1.92 heads, m1 2bbl, 52mm f&b, Mike Leach headers, Mopar 2400 stall, 4.56 rear, Comp cams 210/220 cam, 1.6 roller rockers, K&N FIPK, SCT, MSD 6A, 24lbs injectors, APS trans, Flex-a-lite 180 fan, 100 shot of giggle gas. Best E.T. of 12.863@104.6
nitrohog is offline
post #10 of 13 Old 09-08-2010, 04:12 AM
gocartone
gocartone's Avatar
Yup resistor won't hurt it at all. Swap the relay with one you know is good just to try it out, make sure the wiring right at the fan is good as it's in kind of a shitty spot (right under the fan shroud).
2006 Yamaha FZ6
2004 Honda 450R
post #11 of 13 Old 09-10-2010, 04:50 AM
renzo
Vehicle: 99 Dakota Extra cab 5.2
Something else to check: There is a thermostat switch(usually screwed into a coolant area) sorry I dont know where it is on your truck. This switch senses the high temp of coolant and switches on/off the fan. IF you find it, you can test it with boiling water & a V.O.M.
Did a little research(should have done it before I opened my mouth)
On the Dakota(and others Im sure) The electric radiator cooling fan is controlled by the Powertrain Control Module (PCM) through the radiator cooling fan relay. The PCM will activate the relay after receiving inputs from the engine coolant temperature sensor and/or an air conditioning on/off signal.
Last edited by renzo; 09-10-2010 at 05:14 AM. Reason: Activated mouth before engaging brain
renzo is offline
post #12 of 13 Old 09-10-2010, 10:34 PM Thread Starter
DaveAz
Thanks...I'll check that all out.
DaveAz is offline
post #13 of 13 Old 09-11-2010, 03:04 AM
IndyDurango
2000 SLT+ 5.9L Platinum
IndyDurango's Avatar
Vehicle: 2000 Dodge Durango SLT+
Modifications: Gaming, Investing, My D
Definitively, comes on at temps over 210 and when the AC is on regardless of temp.
HTH,
IndyDurango
. . . . .Driving a Durango Cures 5-Door Envy. . . . .
IndyDurango is offline
