Disappointed with the 4.7 Jeep TCM Swap Mod - Dakota Durango Forum
Computer Control Parts Info Links : PCM Modules
post #1 of 43 Old 09-06-2010, 04:20 AM Thread Starter
Jasoon
Jasoon's Avatar
Vehicle: 2001 Quad Cab Dakota 4x4
Ok, I'm officially disappointed with this mod, and thinking of removing it from my truck.
I was really hoping it would transform the truck into having 5 real gears. Instead, I've got 3 gears and 2 overdrives.
I towed my Boat with my dakota, loaded to the gills with gear, my wife, and my kids, to Bull Shoals Arkansas. Overdrive was off. The 4.10 gears I had installed earlier in the year do made towing easier, yet I decided to back off on most of the hills as it is still a 9 year old truck with 90000+ miles. I kept my speed between 55 and 65 on most of the Arkansas roads, RPM's in the 2500-3500 range. For most of this trip, the truck was in 3rd gear, 6500 rpms, 65 mph
A "true" 5 speed should drop to "4th" and keep rpm's about 2500 at 65 mph, right?
Tonight, while driving home from Branson, at 70mph, I'm at ~2000 rpms with the mod and 4.10 gears. Up the hills I go. Instead of dropping to 4th for a little extra power, the truck skips it and drops to 3rd and 3500rpms.
It's not giving me 5 gears, it's giving me 3 gears + 2 overdrives. And it won't go into the "4th" or first overdrive for anything it seems, except to bridge between 3rd and 5th after going up that hill.
Anyone else experience this?
MOPAR THUNDER...2001 Dodge Dakota Quad Cab 4x4, 4.7L V8, 120,000 miles.
Still passes the 8 foot test.
In search of a fiberglass tonneau Cover
Jasoon is offline
post #2 of 43 Old 09-06-2010, 04:30 AM
Shimrra
110 HP, 11.1 MPG. FML
Shimrra's Avatar
Vehicle: '93, 3.9L, '92 3.5L
Modifications: V8 TB, e-fan.
Send a message via AIM to Shimrra Send a message via MSN to Shimrra Send a message via Yahoo to Shimrra Send a message via Skype™ to Shimrra
all that mod was ever for was a second OD. i dont know where you got the idea it was anything else. jeep owners complained about engine noise on the highway so they gave the tcm a second OD to lower revs.
dont know where you got the idea it was going to be a "true 5spd"
'93 Dak, V6 Auto RWD;
V8TB, E-fan, and a bad smoking habit.
IN THE WORKS:
'92 318 swap, coming closer to completion every dime I can squirrel
Shimrra is offline
post #3 of 43 Old 09-06-2010, 05:45 AM
03GOLDDAKOTA
03GOLDDAKOTA's Avatar
Vehicle: 2003 dodge dakota slt
Modifications: 265/75/16 M/T's, K&N fipk, flowmaster exhaust,
learn to drive? its not tough to get the truck to shift into 4th, gentle throttle input and a little patiance and you'll find it
03GOLDDAKOTA is offline
post #4 of 43 Old 09-06-2010, 07:18 AM
BlackDak
BlackDak's Avatar
Vehicle: 01 Flat Black X-AWD V8 QC
Modifications: RC Monster trucks, MoPar
Hmmm, that TCM was on my "want list". I was also under the impression it would make a big change. Thanks for the clarification!
BlackDak is offline
post #5 of 43 Old 09-06-2010, 02:33 PM
akcooper9
I agree...
While I can get it to drop to 4th I still dont care for the way it drives/shifts
IMHO the stock TCM with my gears/tires is best
akcooper9 is offline
post #6 of 43 Old 09-06-2010, 03:29 PM
t vago
t vago's Avatar
Vehicle: 2000 Dodge Dakota SLT QC
Quoted: 12 Post(s)
It will make a big change... in your gas mileage. Nothing else. I estimate this thing paid for itself in my truck in 3 fill-ups.
Then again, I don't do a lot of towing.
2000 Dakota SLT QC- 4.7L V8, 545RFE transmission, Polished/Ported Cylinder Heads, Bosch +4 Plugs, HO Cams, Mopar beehive valvesprings, bwdakrt 65 mm Throttle Body, Fuel Delivery mod, Magnaflow Hi-flow cat, Dynomax Cat-back, Trans-Go Shift Kit, JGC Fan conversion, no engine-driven fan, Ceramic front brake pads, Power Slot Cryo rotors, Goodridge S/S brake hoses, 2004 Mopar fuel injectors, JBA Ceramic coated headers, intake heater, Toyota MR2 EHPS Pump
2001 Durango SLT- Next-Gen Corsair 4.7L V8, 545RFE transmission, 12-hole 24 lb fuel injectors, Fuel Delivery mod, JGC Fan conversion, no engine-driven fan, 65 mm throttle body, Toyota MR2 EHPS Pump
2005 Magnum- 3.5L V6, NSG370 6-speed manual transmission, 2.87 rear end, Bosch +4 Plugs, Billet Technology Catch Can, Stop Tech S/S brake hoses, JBA Ceramic coated headers, intake heater
t vago is offline
post #7 of 43 Old 09-06-2010, 04:12 PM
caulk04
Vehicle: none
It did exactly what I wanted. It lowers the RPM and it holds the TC lockup instead of unlocking at the slightest hint of throttle.
If I'm towing, I let it cruise in 5th with the TC lock until it drops to 3rd, then I hit the OD-off and lock the TC back up. I refuse to tow with the TC unlocked, might as well have a turbo heater on the trans.
Hey, it's not for everyone and I'll admit the trans still doesn't shift the way I think it should (lock the TC in 2nd and leave it locked) but this is better than factory IMO. 4.56 gears make it very nice.
Another thing to think about, it may run the RPM higher by skipping to 3rd, but I bet it gets better mileage (especially if you lock the TC) that way and is easier on the engine. Lower RPM and higher throttle input are just going to increase cylinder pressure and temperature.
caulk04 is offline
post #8 of 43 Old 09-06-2010, 04:32 PM
Shimrra
Shimrra's Avatar
the issue isnt the mod, it was the fact you turned OD off. thus limiting yourself to 3ed. the only time i use the OD button is in city, on on ramps, or climbing big hills on the highway
IN THE WORKS:
Shimrra is offline
post #9 of 43 Old 09-06-2010, 04:53 PM
96daksport
96daksport's Avatar
Vehicle: Dakota
Send a message via AIM to 96daksport
Does anyone have any before and after MPG figures?
96daksport is offline
post #10 of 43 Old 09-07-2010, 02:54 AM Thread Starter
Jasoon
Jasoon's Avatar
I really can't see towing 4000 lbs of boat and hauling 1500-2000 pounds of gear and people, and leaving OD on. Putting that much weight on the smallest gear in the box? Quickest way to a new tranny. Even the owners manual says turn it off.
Wishful thinking on my part that it would be a 5 speed, instead of a 3+2.
Gentle throttle isn't getting it done either, it doesn't get the trans to shift soon enough. When on hills at 70mph, it just tries to get more power out of 5th, gives me that "humming" noise until it gives up and shifts to 3rd (Cruise Control On). Then it drops from 3500, to 3000rpms, to 2500rpms, then back to 5th, er, 2nd overdrive.
Someone needs to make me a mod to lock out 2nd overdrive and keep 1st overdrive, lol.
Learn to drive? I'd say I "adapted" by backing off on the hills, allowing the speed to go down, so the truck doesn't spend too much time in the upper RPM band. I depend on this truck too much to tear it up and wear it down.
Maybe I live around too many hills.
I did forget one benefit of the TCM Swap, it does result in "smoother" shifts. (Don't have a clue why, but it does) For this reason, I'll probably keep it.
Jasoon is offline
post #11 of 43 Old 09-07-2010, 03:34 AM
project_dog
Schaw Flapping Pus
Vehicle: 2008 Mazda 6i
Send a message via MSN to project_dog
Ill take it off your hands if you dont want it.
project_dog is offline
post #12 of 43 Old 09-07-2010, 03:57 AM
03GOLDDAKOTA
your not going to wear down or tear up your truck by runnin 4k up a couple hills the 4,7 can run there all day long, and using cruise you will never see 4th your acctually going to have to use your foot lol
post #13 of 43 Old 09-07-2010, 04:01 AM
wuba
Mine goes into 4th with no problems what so ever, I just push in the clutch and pull the lever back and let out of the clutch. Works every time.
03 Dakota RC 4.7, 212x, 68mm Fastman, 3" exhaust with no cats, Auburn LSD, Hotchkis, Nitto's 275/50/17
Oklahoma SCCA ESP#7 Best time 14.39
http://www.streetfire.net/video/a-fa...ck_2017029.htm
wuba is offline
post #14 of 43 Old 09-07-2010, 04:22 AM
01Motorsport
RCC #93
01Motorsport's Avatar
Vehicle: 2001 Dodge Motorsports LE
Modifications: HO cams,homebrew alloy intake,SSBC rear disc, Edelbrock IAS,R/T rear bar and 17x9's,Michelin LTX Pilots,Magnaflow Y/Cat/22"/2 1/2" duals,3/2 drop,Snugtop cab-hi
Quoted: 2 Post(s)
I think they're on a different page than you and me
Kickass vid, BTW...
>END: threadjack<
'01 Dodge Motorsports 4.7/ 5-spd manual/ 3:92LSD/ Gee Whiz commercial vehicle/ mods?-beaucoup!/ &...US129 Dragon Slayer -Howard
01Motorsport is offline
post #15 of 43 Old 09-07-2010, 04:46 AM
gocartone
gocartone's Avatar
Vehicle: 2001 Dakota 4x4 R/C
It would be down shifting to 3rd on those hills with the old TCM too. It's not going to change all your gear ratios so 1-4 are lower and 5th is OD, it's just adding it on so when you are cruising on level ground you are getting better MPG's. You could always switch to the stock, cruise at higher RPM's and have it going from 4th to 3rd on the hills, isn't this better?
2008 Corvette 485whp
2001 RC 4.7 5-Speed 4x4
2006 Yamaha FZ6
2004 Honda 450R
gocartone is offline
