02 4.7 Knock sounds like a lifter - Dakota Durango Forum
post #1 of 9 Old 09-05-2010, 01:25 AM Thread Starter
Tjoe
Vehicle: 2002,Dakota,Sport Plus
I have a 2002 Dakota w/ a 4.7L. . . . I noticed a little tic a few months ago. The truck ran great. Well, the tic got worse. Now, Ive got a knockin. I pulled the valve cover from the driver side the noise was comming from, replaced the lash adjusters. This didnt fix the knock!
My oil pressure is still good. engine runs great. Stil have knock. I think deep in the engine.
Any suggestions? thinking that I may have bent a con rod. Also, this truck is a hard starter, Takes 2-3 times of rolling over before she takes off. Most of the time it stays running
Tjoe is offline
post #2 of 9 Old 09-07-2010, 05:31 AM
trad444
Mopar lover
trad444's Avatar
Vehicle: 04 QC Dak. SLT+ 4x4 4.7L
Quoted: 3 Post(s)
Assuming its knocking at idle and all the time you could unplug each coil one at a time and if the noise goes away then that cylinder is your problem (bad connecting rod bearing/ really bad piston slap). Also engine timing could be really wacked out causing a ping too. Why do you think you have a bad connecting rod did you suck in water some how?
trad444 is offline
post #3 of 9 Old 09-07-2010, 06:05 AM
Adobedude
Vehicle: 2001 Dakota R/T
Quoted: 5 Post(s)
Broken exhaust manifold bolt....Common.
11.27 @ 118.16 All Motor on Mars.
3rd place overall- 2014 & 2015 New Mexico Mopar Challenge Series
Adobedude is offline
post #4 of 9 Old 09-08-2010, 05:58 AM Thread Starter
Tjoe
ive pulled all coils, no change. Ive put in new valve adj/lifters, no change nothing on top seems out of normal. Im stuck. knock is constant. did put some trans fluid into the vacuum, this quieted the hammer for a min but returned. My truck runs great, sounds like ass though. Im thinkin that if I had a bad bearing, I would have shelled the engine by now. Ive put 3000 miles on the sucker sounding like ass. Scrathing my head!
Tjoe is offline
post #5 of 9 Old 11-01-2010, 02:48 AM
BADXMPL
Vehicle: 2001 DODGE DAKOTA CC
Mine was ticking like that and i had to do all of the chains and tensioners. Kind of a big job took me most of the day at the shop with the air tools and a lift.
BADXMPL is offline
post #6 of 9 Old 11-04-2010, 11:27 AM
AIR_RAM
www.AIRRAM.com
AIR_RAM's Avatar
Vehicle: 2002 QC RAM 4.7L *SOLD*
Modifications: 2011 Grand Sport Corvette :)
Quoted: 6 Post(s)
The most common cause would be an exhaust leak at the headers. I would check for leaks before moving forward.
NICK
AIR_RAM is offline
post #7 of 9 Old 11-04-2010, 07:45 PM
99Dakota
Diesel Mechanic
99Dakota's Avatar
Vehicle: 99 Dakota 4x4
sounds like a broken manifold bolt or rusty or cracked manifold.
99 Dakota Sport 4x4 3.9L V6
360 Air Intakez, V8 TB, MSD Coil, Magnaflow Y-Pipe back, Superchips 3715, Factory 3.92's, Firestone Destination A/T's, HID 5000K BI, HID 6000k Fogs, Monroe Sensatrac Rear Loadlevelers
99Dakota is offline
post #8 of 9 Old 08-15-2014, 08:23 PM
agh1972
agh1972
Vehicle: 2002 dodge dakota sport
Modifications: none
My 02 dakota is ticking and the truck is shaking ass well it started out of no where what could be the problem?
agh1972 is offline
post #9 of 9 Old 08-15-2014, 09:13 PM
Arisley
Reformed Redneck (Sorta)
Vehicle: 2003 Dodge Durango
Modifications: Bone stock
First, you should start your own thread instead of hijacking someone else's.
Second, we need a bit more information than that. From your description it could be anything from a flat tire with a bolt stuck in it, to a thrown rod.
Arisley is offline
