How to siphon gas from our tanks - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
post #1 of 37 Old 08-15-2010, 12:21 AM Thread Starter
Scotty33
Scotty33's Avatar
Vehicle: 01 Dodge Dakota
Does anybody know how to get the gas out of the tanks on these trucks?
A siphoning kit doesn't work cause of the rollover thing in tanks now-a-days i think?
I have an 01 4.7 4x4 club cab
Thanks
Scotty33 is offline
post #2 of 37 Old 08-15-2010, 12:36 AM
Tydog07
150,XXX Miles
Tydog07's Avatar
Vehicle: '02 Dur 4.7L SLT
Modifications: Dwight TB
Thanks
Drill a hole in the tank??? Why do you need to siphon it anyway?
5DW #187 A lot of stuff...
Tydog07 is offline
post #3 of 37 Old 08-15-2010, 01:44 AM
Jarheadoo7
don't feed the bears
Jarheadoo7's Avatar
Vehicle: 2001 Dakota
just liek you siphon anything.. stick a hose in.. such the air outta the hose.. empty into a container lower then the origional source.. let gravity take over.. enjoy the taste of gas!
Jarheadoo7 is offline
post #4 of 37 Old 08-15-2010, 02:11 AM Thread Starter
Scotty33
Scotty33's Avatar
A brake line behind the gas tank burst, need it out of the way.
Can't do that, I've tried with a siphoning kit and a hose, it gets stuck where apparently new tanks have some rollover thing in them so if a truck rolls gas doesn't spill out.
Scotty33 is offline
post #5 of 37 Old 08-15-2010, 03:18 AM
DocZ
DocZ's Avatar
Vehicle: 2003 Dakota
Isn't it pretty easy to take the box off?
I'd rather than than pull the tank.
DocZ is offline
post #6 of 37 Old 08-15-2010, 03:37 AM
burganb
burganb's Avatar
Vehicle: 2001 Dakota SLT 4.7L 4x4
Garage
If its a rear brake line he must drop the tank to get to it. I have to do the same thing to remove my brake lines. I'll also, be siphoning gas out of the tank. But I've never heard of this rollover thing, maybe its something new?
burganb is offline
post #7 of 37 Old 08-15-2010, 03:53 AM
DocZ
DocZ's Avatar
OK Cool.
I'm unfamiliar with the setup on these.
My preference would be to support tank and move it over a bit to access that area rather than laying under it on stands, disconnecting everything and pulling tank out only to have to fight it back in place.
A good time to do a clean up , maybe spray some rustoleum and check shocks,flex lines etc..
2 different approaches with the same result ...lol
DocZ is offline
post #8 of 37 Old 08-15-2010, 04:41 AM Thread Starter
Scotty33
Scotty33's Avatar
I don't know I found it in a search and i can't get my siphon tube past a certain point so it must be there but please tell me I'm wrong.
And yeah its right in the middle of my brake line going to the rear conveniently tucked away behind the gas tank.
Originally Posted by DocZ View Post
OK Cool.
Whats your preference? I don't see how it is even possible but I'm open to ideas man.
Scotty33 is offline
post #9 of 37 Old 08-15-2010, 05:30 AM
Tydog07
150,XXX Miles
Tydog07's Avatar
Don't all somewhat modern cars have anti siphoning protection on tanks?
Tydog07 is offline
post #10 of 37 Old 08-15-2010, 06:23 AM
silverback
Mongo lift heavy things..
silverback's Avatar
Vehicle: 01 QC Dakota 3.9L 2WD
Sorry I don't know where in the forum it is, but one day I came across a post with a link to the Factory Service Manual in .pdf form and downloaded it. I'm doing the tank removal on a Quad Cab tomorrow to replace a fuel pump and it looks like I'll need to remove a cross member that's riveted in, gonna be fun removing those...reg cab looks easy. Anyway, search for the FSM, download it and good luck.
Hold on! Found it.
http://www.dakota-durango.com/forum/...ad.php?t=39972
This is the one I'm using. Thanks to viperkota.
QUAD SQUAD MEMBER
silverback is offline
post #11 of 37 Old 08-15-2010, 06:42 AM Thread Starter
Scotty33
Scotty33's Avatar
Yeah i have the fsm and im trying to do it without removing the cross member i don't see why its in the way so I'm ignoring it for now, maybe thats a bad idea though.
Let me know how it goes for you man and how you end up getting the gas out.
Scotty33 is offline
post #12 of 37 Old 08-15-2010, 07:20 AM
silverback
silverback's Avatar
Do you have a Quad cab? I don't know if the reg cabs or club cabs have the crossmember... I plan on drilling or cutting out the rivets.
As for getting the gas out...the FSM mentions (I'm paraphrasing here) to use the port on the fuel rail with a hose attached going into an approved container and then letting the fuel pump do the work. So far I just waited until the 'low gas' dash light came on and I have a motorcycle lift I plan on using to lower the tank.
I'll post what happens.
QUAD SQUAD MEMBER
post #13 of 37 Old 08-15-2010, 09:57 AM
scdakota
scdakota's Avatar
Vehicle: 99 dodge dakota
the easiest way to siphon the tank is to remove the bed then pull out the fuel pump cause there is an antisiphon ball in the tank or the fuel rail is a good way also
scdakota is offline
post #14 of 37 Old 08-15-2010, 02:14 PM Thread Starter
Scotty33
Scotty33's Avatar
Yeah i have the quad cab and i think a 2 piece drive shaft too (is it considered two pieces if theres a really short one from the tcase to the big drive shaft?) but when i was down there all day yesterday I didn't see any reason why the FSM says to remove the crossmember or the drive shaft.
How do you let the fuel pump work though is my second question because my haynes said to remove the fuel pump relay before this, i know i can put it back in, but i also read that you need a DRB scan tool otherwise operating the pump like this could be really bad.
Scotty33 is offline
post #15 of 37 Old 08-15-2010, 06:37 PM
Cranky
Sanford with no son
Vehicle: Dodges!
My 95 Dakota 'had' the ball....is it an anti siphon device or roll over anti spill device? I use my 95 as a 'reserve' tank whenever we have a storm in the Gulf. Last hurricane my electricity was off for several days and instead of keeping several cans of gas stored in my garage for my generator, I just use the truck for that and then whatever I don't need gets used up when I drive it.
You can have my guns when I'm out of ammo!
And I'm not a racist...I hate everyone equally!
Cranky is offline
