| Register | Home | Forum Extras | Website Features | Garage | Calendar | Search | Today's Posts | Mark Forums Read | Auto Loans |
| Gen III Dakotas 1997-2004 Dakota-Specific Questions |
Thread Tools | Rate Thread | Display Modes |
#1
Part Diagrams with Part Numbers (97-01)
So here is a link for vehicle diagrams and the OEM part numbers. I figured it would help the early Gen III guys that need to know part numbers of different items.
1997: http://www.berrysprinter.com/e-fiche...97-01/97AN.pdf 1998: http://www.berrysprinter.com/e-fiche...97-01/98AN.pdf 1999: http://www.berrysprinter.com/e-fiche...97-01/99AN.pdf 2000: http://www.berrysprinter.com/e-fiche...97-01/00an.pdf 2001: http://www.berrysprinter.com/e-fiche...97-01/01AN.pdf Last edited by burganb; 08-04-2010 at 05:55 AM. |
| Sponsored Links | ||
Advertisement | ||
#2
Don't forget the '02 and later guys...
http://www.berrysprinter.com/e-fiche...02-05/02an.pdf http://www.berrysprinter.com/e-fiche...02-05/03an.pdf http://www.berrysprinter.com/e-fiche...02-05/04an.pdf
__________________
![]() 2000 QC with 4.7L V8, Polished/Ported Cylinder Heads, Bosch +4 Plugs, HO Cams, Mopar beehive valvesprings, bwdakrt 65 mm Throttle Body, Fuel Delivery mod, Magnaflow Hi-flow cat, Dynomax Cat-back, Trans-Go Shift Kit, JGC Fan conversion, no stock engine-driven fan, Ceramic front brake pads, Power Slot Cryo rotors, Goodridge S/S brake hoses, PLX M250 WB AFR gauge, 2004 Mopar fuel injectors, JBA Ceramic coated headers, coolant-based intake heater 2002 Chrysler Sebring Convertible GTC with transplanted 3.5L LH engine |
#3
Yes, well I didn't have that PDf on my computer so I forgot about them having on for the later guys too. |
#7
Thanks!
__________________
#8
Sweet!
__________________
2000 Dakota CC 3.9L 5SPD Man 180* T-Stat, 360 Power Shot IntakeZ, bwdakrt modded V6 TB , Superchips 3715, HS 1.7 RR's , Black Magic 180 Extreme Fan (Clutch fan kicked to the curb!), Taylor 8mm Wires, NGK FR5-1's, EBC Sport Rotors & Hawk Pads, Infinity Reference 6020CS & 6022SI, AMI Locking Fuel Door, Diamond Clear Corners with O*NEX 6000K HID's.
#9
What about for us Durango guys?
__________________
4.7L '03 Patriot Blue Durango SLT K&N FIPK Magnaflow Muffler w/ stock tubing |
#10
Had the same question...
Try here: http://oskin.ru/pub/chrysler-dodge/m...02-05/03dn.pdf Change the '03' to your year, if needed...should pop right up. |
#11
Are these the Dodge part numbers etc? So if I call the dealer and ask if I have for a specific part number for this .pdf, will they be able to find it? Thanks...
__________________
#12
Yup, they will either be able to give you a price right off that part number listed, or tell you what part number superseceded it.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | Rate This Thread |
