4.7L Replacement Y-Pipe - Dakota Durango Forum
Headers & Exhaust Parts Info Links : Headers * Exhaust
Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
post #1 of 100 Old 07-14-2010, 04:19 PM Thread Starter
burganb
burganb's Avatar
Vehicle: 2001 Dakota SLT 4.7L 4x4
Garage
So i was discussing fixing the Y-pipe with my Dad the other day and he said That when I had my front wheels off for installation of the new shocks he took a look at the pre-cats. Said that had to be the one of those things Dodge had to screw up. It literally goes:
Intake Manifold-->Ball Flange--> about an 1.5-2" straight pipe-->a sharp 90degree bend--> precat-->another sharp bend--> and then on to the rest of the Y-pipe.
So we start thinking it maybe hard to try and gut the system than original thought. So Dad started talking replacement Y-pipe. Only ones I knew of is Walker and Magnaflow. But I think I found someone else...
Catco Catalytic Converters
They make the Y-pipe to fit 2001-2003 Dakota (w/ wheel base 131.5). It They actually only make Y-pipes for the 4.7L and the 3.9L. And what's nice is the pipes are made with 409 SS, not aluminized steel.
Their company's catalog link is below:
http://www.showmetheparts.com/catco/
burganb is offline
post #2 of 100 Old 07-14-2010, 05:08 PM
Neil
Neil's Avatar
Vehicle: 99 Durango
Wow, I really can't understand what you are trying to say.
What is the problem and what did Dodge "screw up"?
Why are you thinking about gutting or replacing it?
Neil is offline
post #3 of 100 Old 07-14-2010, 05:56 PM
GWhaley
Vehicle: 2001 Dakota Q.C.
Did you get a price on the complete 3 Cat Y pipe? Make sure you are sitting down...............they aren't cheap. I spent a couple of weeks looking for a direct bolt up - the 3 cat assemblies were north of a grand.....I ended up getting two aftermarket pre-cats and just cut out the old ones, welded in the new ones.....(old ones were breaking up). Worked like a charm and it was under 300 bucks including the install. And I didn't have to mess around with 02 sensors - they are still in the factory locations
GWhaley is offline
post #4 of 100 Old 07-14-2010, 06:00 PM Thread Starter
burganb
burganb's Avatar
Garage
The screw up is the sharp 90degree bend right after the exhaust manifold to the precat and then one right after the precat. instead of a nice smooth flow like it should be.
I was thinking of gutting all the cats because the precats are rattling apart and clogging the 3rd cat. Not only does it sound like shit, but it also has dropped performance and mpg. I used to get 18-19 in the summer, now I get 16-17. So I lost a good 2 mpg. I probably lost more than that though since I have the Jeep TCM swap now.
Mainly, I was trying to let the guys know that were looking for a replacement pipe know I found a direct fit that is not $800 for aluminized steel. Its like $439 for the pipe w/ 2 precats and one 3rd cat made out of 409 SS and $283 for the pipe with one cat made of 409 SS.
burganb is offline
post #5 of 100 Old 07-14-2010, 06:03 PM Thread Starter
burganb
burganb's Avatar
Garage
GWhaley--- See above ^^^
burganb is offline
post #6 of 100 Old 07-14-2010, 07:35 PM
GWhaley
Prices sound good - up here they are almost double that......good info to know for the future.....good find!
GWhaley is offline
post #7 of 100 Old 07-14-2010, 07:42 PM
Dave_NY
Sexual Tyrannosaurus
Vehicle: 04 Dakota SLT 4.7L 4x4
Would those direct cats fit the 2004 model? I see it under the 2001 4.7L but for 2004 they don't even have the Dakota model.
Guess I should give them a call to find out.
Dave_NY is offline
post #8 of 100 Old 07-14-2010, 08:21 PM
gocartone
gocartone's Avatar
Vehicle: 2001 Dakota 4x4 R/C
What's the ID on the one without cats? And it's for the 4.7 right? It looks like it has a hole for an O2 sensor right before the one cat on it, which doesn't exsist on our trucks but I think the 3.9s have something like that (not sure).
2008 Corvette 485whp
2001 RC 4.7 5-Speed 4x4
2006 Yamaha FZ6
2004 Honda 450R
gocartone is offline
post #9 of 100 Old 07-15-2010, 02:19 AM
DocZ
DocZ's Avatar
Vehicle: 2003 Dakota
Can't you go to a y pipe for a later model? My 03 Dakota has just one cat after y pipe
DocZ is offline
post #10 of 100 Old 07-15-2010, 03:24 AM
silverback
Mongo lift heavy things..
silverback's Avatar
Vehicle: 01 QC Dakota 3.9L 2WD
I've got a 2001 QC 3.9 2wd that has the 3cat set-up. Last Friday I heard an exhaust leak & it was the passenger side pre cat, it managed to break loose at the pipe/cat weld on the bottomside. Had it welded back on yesterday but unfortunately the part that is welded (from the factory) is on the inside, under the outer shield. The guy said it wouldn't hold for long. Muffler shop quoted me $225 to install another cat or somewhere just over $700 for a new 3 cat system. I found the Catco various online retaiers & ebay for a 3.9 to run $390 +/- with shipping, the 4.7 runs $30-$40 more. The 5.9 runs cheaper at around $310...wonder if that would fit my 3.9?...
My cats still look good, maybe I can sell them to help make up some of the cost of a new set.
All I can say is if you don't have access to have someone weld one up for you, shop around and ask the ebay sellers questions cause some of them are dumbasses trying to take your hard earned cash. Good luck with your choice & let us know what you get & how they fit.
QUAD SQUAD MEMBER
silverback is offline
post #11 of 100 Old 07-15-2010, 06:36 AM Thread Starter
burganb
burganb's Avatar
Garage
They make two different kinds for the 2000-2003 Dakota 4.7L one with 3 cats and one with just a single cat. I might just buy the single cat version and have someone weld bung holes to put the two O2s close to the exhaust manifold in. The other two are getting ziptied to the frame.
burganb is offline
post #12 of 100 Old 07-15-2010, 04:29 PM Thread Starter
burganb
burganb's Avatar
Garage
Originally Posted by silverback View Post
I've got a 2001 QC 3.9 2wd that has the 3cat set-up. Last Friday I heard an exhaust leak & it was the passenger side pre cat, it managed to break loose at the pipe/cat weld on the bottomside....
Yeah, your lucky yours is just a leak. Mine is both of them rattling apart. I'll try and see if I can get a video up of how is sounds sometime, so you guys will know what it sound like if you think yours is going bad. I can barely hear it if I'm driving normally. But If I sit in the driveway with the door open and rev it. You hear it a little bit on the up rev and then the rattle gets really bad as the rev goes back down.
burganb is offline
post #13 of 100 Old 07-15-2010, 04:44 PM
GWhaley
That's the way mine was as well - my truck had two replacement y pipes put on under warranty - the last one had barely any miles on it.....and of course the federal emissions warranty had ran out.....that's when I went on the hunt for an aftermarket alternative...
GWhaley is offline
post #14 of 100 Old 07-15-2010, 07:39 PM
QUAD DAD
QUAD DAD
Vehicle: '02 Dakota Quad Cab 4X4
Yeah that's weird . My '02 has only one after the 'Y' pipe too.
2002 4.7 QC Sport Plus 4X4
Some of my mods are Gibson dual sport exhaust, H.O. cams and now H.O. intake, CAI, ARE lid w/spoiler, Street Scene grille inserts, 1 piece headlights, Transgo reprogramming kit, chrome wheels, Power Slot Cryo rotors & Hawk pads, custom embroidered interior, cowl hood with custom underhood liner.
QUAD SQUAD MEMBER
QUAD DAD is offline
post #15 of 100 Old 07-15-2010, 11:16 PM
silverback
silverback's Avatar
Well sumbitch, mine broke loose this morning. There are two different kinds for the 2000-2003 3.9 also. I like your idea above. Anyone out there have luck doing this?
QUAD SQUAD MEMBER
