1999 Dakota 3.9 Idle/Stumbling Issue - Dakota Durango Forum
post #1 of 13 Old 06-24-2010, 01:44 PM Thread Starter
dakrt360a
Vehicle: 1999 Dodge Dakota
I'm looking for some advice here...
The issue I have been having the last few months have been occasional to frequent rough idle. This seems to be drastically worse in the presence of moisture, say the morning after a nightly storm. For instance, after a rain last night, the truck started fine but idled very rough. Normally once I start driving and after a few miles it tends to calm down and run normal. Sometimes it will feel like it is missing and stumble a bit while at speed.
I have already tried the usual IAC replacement, spark plug replacement etc. After reading some of the posts on here I have heard possibilities like fuel pump, computer, o2 sensors, etc. Any input will be welcome. Thanks.
dakrt360a is offline
post #2 of 13 Old 06-24-2010, 04:06 PM
vortmax
Unregistered User
vortmax's Avatar
Vehicle: 2001 Dakota, RC 2x4 3.9L
Quoted: 10 Post(s)
You mention plugs. Did you replace the wires too? Are they routed properly? I believe there is a TSB out for an alternate wire routing for 3 and 5 to solve an issue like this.
vortmax is offline
post #3 of 13 Old 06-27-2010, 04:01 AM
LIMtnBkr17
LIMtnBkr17's Avatar
Vehicle: '00 Dakota Extended Cab
Modifications: Stock
I also have a 2000 Dakota with the 3.9 and often notice that it idles high and sometimes rough for about 10-15 seconds when I put it in park (up around 2000 rpm). Doesn't happen all the time but enough for me to be curious about how to make it stop. I notice it the most after towing a trailer or if I throw it into park quickly.
While Im trouble shooting, my truck also makes a rather loud clicking noise when it gets wet. When the engine gets wet from going through even the smallest puddle it makes a loud clicking noise from the front. When it dries out a minute later its quiet again. Any ideas what that is? It makes the small amount of off roading I do very annoying and driving in the rain is also getting to be a nuisance. I just don't like the noise and wonder how I can make it stop. Hopefully someone on here can help us out.
LIMtnBkr17 is offline
post #4 of 13 Old 07-06-2010, 09:00 PM
LIMtnBkr17
LIMtnBkr17's Avatar
bump*
post #5 of 13 Old 07-06-2010, 09:37 PM
vortmax
Unregistered User
vortmax's Avatar
Quoted: 10 Post(s)
First, I would recomend making your own thread instead of piggy backing a question onto someone else's thread.
Second, pull the truck into a dark garage or wait until night time, start it up, pop the hood and mist around the plug and coil wires with a spray bottle. That ticking sounds like a wire or wires arcing to the block. If you see visible arcing, replace your wires and route them correctly.
vortmax is offline
post #6 of 13 Old 07-07-2010, 01:36 AM
Low_Kota
Low_Kota's Avatar
Vehicle: 2001 Dodge Dakota
My truck has had this problem twice. First time it was an 02 sensor, second time a full tune up fixed the prob, Plugs, Wires, cap and rotor.
Low_Kota is offline
post #7 of 13 Old 12-13-2010, 08:10 PM
Underwhere
Vehicle: 1999 Dakota Sport
Bringing this up from the dead.
I had this same issue this morning. Yesterday it was pouring. Today on the drive to work I notice the RPM's bouncing around when I'm in traffice and in Drive. If I shift to Neutral it's fine.
Haven't replaced anything thus far. Curious to see whether you found anything wrong.
Underwhere is offline
post #8 of 13 Old 12-20-2010, 01:03 AM
66shelby
66shelby's Avatar
Vehicle: 1999 Black R/C R/T
hello, I have the same problem, 2000 dakota 3.9L when I put it into park its a rough idle and almost wants to die, and sometimes does. It got to the point where it wouldn't keep an idle, I did the IAC and it fixed the problem, but not completely, it doesn't do it as frequent. I have a Cervini's hood with scoops and I think it might be because of the water too. I tried pulse plugs and changed spark plugs and same problem, but I have not replaced the wires. I do have an engine light on and says small evap leak and large leak, so maybe thats it and might work for other dakotas. I am still looking for the leak and even had it on a hoist and had a mechanic look at it. and he couldn't find anything.
66shelby is offline
post #9 of 13 Old 10-11-2012, 05:34 AM
Underwhere
FYI I replaced the plug wires as well as the cap and my moisture related issues have gone away completely.
I tried changing my plugs but they were stuck and one of them started to strip out.
post #10 of 13 Old 04-17-2013, 06:05 PM
Izzy's 00 Dak
Vehicle: 2000 Dakota V6 RWD SLT
Modifications: None so far. :(
Garage
OMG! This is exactly what mine has done. I have changed the PVC, Iac, Plugs and now am about to change out my wires (The only reason I didn't do the wires was because they look new) also changing the Dist Cap and the rotor. Thats this weekend. Hope it isn't the o2 sensors cause I won't replace those until I have my CAT replaced.
Izzy's 00 Dak is offline
post #11 of 13 Old 04-28-2013, 07:13 PM
theJester517
theJester517's Avatar
Vehicle: 1997 Dodge Dakota Sport
Quoted: 9 Post(s)
Garage
I know on my 97 V6 the brake booster comes awfully close to the valve cover and my wires for the 4th and 6th cylinder were scrunched up and the heat from the engine actually cracked one and they were arcing. make sure they're all in a good spot
1997 Dodge Dakota Sport 4x4 Regular Cab V6 5 Speed
2004 Dodge Stratus R/T Coupe V6 5 Speed
Dodge 'till the day I die...
theJester517 is offline
post #12 of 13 Old 04-28-2013, 07:29 PM
Izzy's 00 Dak
Garage
Yep. So I finally got around to getting done what I wanted. Switched out the wires, dist. cap and the dist. rotor. Completely solved my issue.
post #13 of 13 Old 04-28-2013, 07:33 PM
theJester517
Quoted: 9 Post(s)
Garage
sweet
