Door hinge repair? - Dakota Durango Forum
General Parts Inquiries Can't find it in any other category?
post #1 of 14 Old 06-21-2010, 02:45 AM Thread Starter
caulk04
Vehicle: none
Door hinge repair?
Ok, so I've never had to mess with a door hinge before, but it's time to redo the bushings on mine.
I don't know what parts are out there to do the job...any insight? Should I be looking for a generic kit or something specific?
I only need to do the bushing for the spring detent lever, the hinge itself is fine, no sagging or anything.
caulk04 is offline
post #2 of 14 Old 06-22-2010, 12:07 AM
ColoDak
ColoDak's Avatar
Vehicle: '00 Dakota, '09 Kawi
Quoted: 2 Post(s)
I talked to a body shop near me about doing mine, they wanted $150 parts and labor.
'00 Dak. Q-Cab, Intense Blue, 5.9 360, AWD
http://www.cardomain.com/ride/3183475/2
ColoDak is offline
post #3 of 14 Old 06-22-2010, 12:34 AM
GWhaley
Vehicle: 2001 Dakota Q.C.
Go to your parts store. They should have door pin kits - come with pins and bushings - should be about 20 bucks a side.
GWhaley is offline
post #4 of 14 Old 06-22-2010, 02:06 AM Thread Starter
caulk04
Vehicle: none
Swung by vato zone today for a new CV clamp and checked out the door pin crap while I was there. Looks straightforward enough, I'll just have to check back to find the right size pin and bushing. Pin in there measures .350" which is just a shade under 9mm.
Looks like I'm gonna have to make a mess though and grind the factory pin to get it out.
caulk04 is offline
post #5 of 14 Old 06-22-2010, 03:22 AM
einsteingarage
Vehicle: 1997 Dodge Dakota 5.2L
Hello, I am a newbie from NH, I haven't given up my info in the "tell us about yourself section" frankly because I am to lazy to type about myself.
I am going through the door pin scenario on a 1997 4x4 5.2 that I bought a couple of days ago. I did get the top pin changed, PIA and I have yet to do the bottom pin. I will be trying to cut the pin in half and push the top up and the bottom down to get it out. I will let you know how it works.
oh yeah, $7 a kit at local auto parts store
einsteingarage is offline
post #6 of 14 Old 06-27-2010, 12:55 PM
einsteingarage
Door hinge kit turns out to be a big failure. The pins are not correct for the Dakota.
Looks like I will have to go to the dealer who only sells the hinges whole.
post #7 of 14 Old 09-05-2010, 06:11 AM Thread Starter
caulk04
Vehicle: none
Dead thread, come back to life...
Got real damn bored today and fixed my hinge. Vatozone hinge kit had the right pin (came with two different sizes).
Sawzall'd the pin in half, air hammered it out each way, removed factory bushing from detent lever, pushed new bronze bushing into lever, pushed new pin in. Done.
Now, if only it was that quick...I accidentally yanked on the detent lever while the pin was out and it came out, along with the spring. If this happens to you, use three zip ties and a vice to compress and hold the spring compressed. This makes it a breeze to get the spring back in.
caulk04 is offline
post #8 of 14 Old 09-05-2010, 06:15 AM
Rebel13
Mods Addict
Vehicle: 2K R/T
Bronze? Don't you mean brass!
Rebel13 is offline
post #9 of 14 Old 09-05-2010, 06:54 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
I got hinge kits off ebay for $11 a set...which does upper & lower hinges on 2 doors...bought 2 sets for the two 66 Chargers...I did one set of hinges already..took about 45 minutes...
was not that bad
Little Blue Guy is offline
post #10 of 14 Old 09-05-2010, 07:32 AM Thread Starter
caulk04
Vehicle: none
No. The material looks like bronze, not brass. I know the difference.
caulk04 is offline
post #11 of 14 Old 09-05-2010, 07:47 AM
Rebel13
Mods Addict
Vehicle: 2K R/T
Brass is the usual material for bushings. May not have a high gloss finish, but dull and pitted.
Rebel13 is offline
post #12 of 14 Old 09-05-2010, 01:26 PM
GWhaley
I've seen bronze used for bushings all the time.......
http://www.nationalbronze.com/
GWhaley is offline
post #13 of 14 Old 09-10-2010, 03:26 PM
rr440727
Mope Or Nope
rr440727's Avatar
Vehicle: Dakota 2000 SLT 4x4
Hey Caulk, any idea what exact size you used in that bushing kit for your hinge?
Or did you save the hinge kit part #?
I've had no luck with Pep Boys or any place like that getting the correct size.
rr440727 is offline
post #14 of 14 Old 09-11-2010, 01:51 AM Thread Starter
caulk04
Vehicle: none
No, it's not. Bronze is harder and more wear resistant. Commonly oil impregnable as well. FYI - I'm a machinist, I've made my share of bronze bushings and wear pads. Can't say I've ever made a brass one.
The pin is 9mm and the bushing od is 11mm. 9mm is just under 3/8", 11mm is 7/16". AutoZone had the pin kit back with their other 'Help!' products. Came with one pin of this size and one pin that is a bit larger, each with two bushings and an e-clip.
caulk04 is offline
