| Register | Home | Forum Extras | Website Features | Garage | Calendar | Search | Today's Posts | Mark Forums Read | Auto Loans |
| Lights Parts Info Links : Clear Corners * Headlights * Headlight Covers * Tail Lights * Tail Light Covers |
Thread Tools | Rate Thread | Display Modes |
#1
No reverse lights
01 cc 4X4 4.7
No reverse lights. Changed bulbs and fuse. What else might it be? |
| Sponsored Links | ||
Advertisement | ||
#2
bad connection where the two sides splice into one by the bumper, bad reverse light switch in the tranny.
#3
I did have the bumper off recently. I'll go check.
#4
Connections seem to be ok. No power to either backup socket. Tails and brakes work. Is there a switch on the tranny or is it in the steering column? Looks like I am in for some disassembling.
#5
i got the same prob with my 98 5.9L if you find anything let me know. i gave up looking, lol.
__________________
1998 Durango SLT 5.9L, 4x4, FlowMaster DF40 series, Cooper STT's (Beast) 1980 Chevy Monte Carlo...stock for now 1988 Chevy Monte Carlo...custom built stroker/4spd auto 5 Door Whore # 173 |
#6
same here with my durango, i think its the switch on the tranny, but idk how to fix it or even get to it
__________________
#7
It was the switch connector on the driver side of the trans. You need skinny hands to get to it. A lift would make it so much simpler.
#8
very easy to change and about 50 bucks for the part
__________________
2003 Dakota Quadcab 4.7L, 5 speed, 4x4,
Functional shaker hood, Flowmaster 40, Superchips 3715, leather interior |
#9
did you have to replace it or what?
__________________
#10
Somehow it got loose. Cleaned it and reconnected it and all is good.
#11
The park/neutral/safety switch controls the reverse lights. On the 5.2/5/9 it's external right above the trans pan. You need a 1" deep socket to get on it. Mine went out a couple years ago. On the 4.7, it in internal to the trans and you have to drop the pan.
__________________
99 Durango 5.9, FT 4x4, IP stage III w/ K&N air hat, M1, SCT, Fastman TB, 1.7 RR, JBA headers, Borla cat back, Martin Saine valve body, Hotchkis swaybars, Blistein shocks, lowered 2" Black Rhino Kenya wheels, 246. 7 RWHP, 319 TQ |
#12
Is it toward the front, like perpendicular to the front left tire? I looked and looked last night and could not find it.
#13
New Safety Switch, still no backups
I checked my fuses, replaced the bulbs, and the Neutral Safety Switch was replaced last summer. Still nothing. Is there a possible wiring issue or should I just try and get a new switch, as they can be bad at the point of purchase? Mine is a 1990 3.9l v6 SE btw
#14
If you replaced the switch within the last year, it may have a warranty. As for fuses, I hope you have a repair or shop manual to tell you which fuses have what circuits on them. You may check the one fuse labeled as "B/U lamps", but another fuse could also be shared with the circuit. My Saturn just came out of the shop with the radio not working. I checked it's radio fuse & it was fine. But, I also lost the door chime. I checked the fuse for that & it was blown. Replaced it, & both started working again. If those "free" options don't work, you may have to trace the wires all through the truck to make sure one isn't cut/burned/worn through.
__________________
For Sale: 1994 Dakota Club Cab, 318 V8, 5-speed. Clear front corners with LED bulbs. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | Rate This Thread |
