transfer case problems - Dakota Durango Forum
post #1 of 13 Old 05-17-2010, 03:40 AM Thread Starter
Junkydakota
Vehicle: 01 dakota quad cab 5.9awd
I've got a 2001 dakota quadcab with the 244d awd transfer case and i'm pretty sure its going bad. It started off with a low rumble this morning and within a mile it was making a squealing/howling/gravel in a dryer sound that was worse when you hit the throttle but eventually was all the time. The service 4wd light came and went a few times but when I locked it in 4wd high or low they both worked. I pulled the fill plug but didn't see any metal at all. Any ideas? Also could I swap in a 233(?) t-case so I could get a little better mileage? If so does the wiring or computers need swapped? Also can I pull the front shaft and drive without problems?
Junkydakota is offline
post #2 of 13 Old 05-17-2010, 04:33 AM
Trouble Maker
Trouble Maker's Avatar
Vehicle: 02 & 03 Dakota Quad Cabs
Sounds like the front drive shaft CV joint is taking a dump. Pull the front shaft, put it in 4wd so the truck will move and see if the sound is still there.
Switching to a 233 won't gain you much since in 2wd all the parts in the front still turn.
Russ
His-SASed 02 Dakota Quad Cab Sport 4x4 4.7 NV3500 5spd/Std D44/9.25" 4.88s lockers frt/rr 35" ProComp Extreme MTs frt EPi 9k Superwinch rear LP 8.5k Superwinch
Also his: 09 Power Wagon Hemi 4.56 gears 285/70R17 Duratracs factory winch and lockers
Hers-03 Dakota Quad Cab Sport 4x4 4.7 545RFE 5spd/Auto 3.92 L/S 265/75R16 Dueler RVTs 5th wheel hitch
Trouble Maker is offline
post #3 of 13 Old 05-17-2010, 04:45 AM Thread Starter
Junkydakota
I'll do that after work tomorrow. Will it be safe to drive much with it out if no noise? Also the tag says new process 244d not new venture?
post #4 of 13 Old 05-17-2010, 05:46 AM
HemiDak
Mods Addict
Vehicle: ​
You can drive the truck like that forever, and it won't hurt anything.
New Process and New Venture are the same companies. Just a name change is all.
HemiDak is offline
post #5 of 13 Old 05-17-2010, 05:47 AM
Trouble Maker
Not as long as you have it in 4wd so the center diff in the t-case is locked.
New Process/New Venture are the same company.
Russ
post #6 of 13 Old 05-17-2010, 10:26 PM Thread Starter
Junkydakota
You win a prize!! The cv joint was crunchy! Took the shaft out, boot ripped and no grease. Also the tranny shop that did my rebuild lastyear left the wiring harness lay across the joint and it ate through some wires.
Anyway, does anybody reman these? Advanced or autozone?
post #7 of 13 Old 05-17-2010, 10:54 PM
HemiDak
Mods Addict
Vehicle: ​
Search here first:
www.car-part.com
Last time I needed CV axles I got them for $33/each from my favorite local wrecker.
HemiDak is offline
post #8 of 13 Old 05-17-2010, 11:11 PM Thread Starter
Junkydakota
Originally Posted by HemiDak View Post
Search here first:
www.car-part.com
I tried car-part.com and the closest to me was 126 miles away and they wanted $200. Advanced sells a reman for $309 so I guess thats what i'll do.
post #9 of 13 Old 05-18-2010, 05:01 AM
HemiDak
Mods Addict
Vehicle: ​
When I first read your post I thought you were talking about a CV axle, and not the CV joint in the driveshaft. My mistake.
HemiDak is offline
post #10 of 13 Old 05-23-2010, 04:26 AM Thread Starter
Junkydakota
The shaft from advanced came with a u joint at both ends and a sticker on it saying the problematic cvs are replaced with ujoints and spin balanced to 3500 rpm. Well I read on ebay the same thing from a place selling the shafts but they did not recommend them for awd applications. And it turns out i'm getting a vibration from about 65-70 mph on up, and even a little bit when braking to a stop. So should I have a cv shaft instead? Will this ruin my transfer case front bearing?? I'm worried.
post #11 of 13 Old 05-25-2010, 02:51 AM Thread Starter
Junkydakota
Any ideas? Anybody got a 2wd t-case they want to get rid of?
post #12 of 13 Old 05-25-2010, 04:28 AM
HemiDak
Mods Addict
Vehicle: ​
There aren't any. 2wd's have tail housings on the back of the transmission instead of a transfer case.
HemiDak is offline
post #13 of 13 Old 05-26-2010, 12:46 AM Thread Starter
Junkydakota
lol, a t-case thats capable of 2wd rather than awd.
