Jeep 4.7/Dodge 4.7 Diff? - Dakota Durango Forum
post #1 of 6 Old 04-27-2010, 03:54 PM Thread Starter
elmo3dakota
Vehicle: 2001 Dodge Dakota
Is there a difference in the 4.7 between dodge and jeep? I have a jeep with a blown motor and a buddy has a 4.7 out of a dodge. Will it work?
elmo3dakota is offline
post #2 of 6 Old 04-27-2010, 04:15 PM
gocartone
gocartone's Avatar
Vehicle: 2001 Dakota 4x4 R/C
What years? Same motors though, little changes from year to year. Someone else can help you with that though as IDK myself.
2008 Corvette 485whp
2001 RC 4.7 5-Speed 4x4
2006 Yamaha FZ6
2004 Honda 450R
gocartone is offline
post #3 of 6 Old 04-27-2010, 06:22 PM
djdanrt
djdanrt's Avatar
Vehicle: 2x 2000 Dakota RC 4.7
Modifications: K&N FIPK, ASP Pulley, BBK 70mm TB
I think the most important thing is the tone ring on the camshaft I know they made 16tooth from 2000-2003 then I think mid 2003 they went to 32tooth. You might want to double check that but im pretty sure its right or close to being right. Not sure about the years on the Jeep but I think they went 32tooth sooner.
Also not sure if the sensor wheel in the right bank of cams makes a difference to the 16 or 32 tooth tone wheel.
I think thats the only issue from it working. I was thinking about buying an Jeep HO engine and its what ive come up with. Decided to rebuild mine though.
djdanrt is offline
post #4 of 6 Old 04-28-2010, 12:09 AM
caulk04
Vehicle: none
Dakotas had the 16t (JTEC) from 2000-2002. Durangos were the same, but some 2002 Durangos had the 32t (NGC).
'02 Ram - JTEC. Beyond that, could have been NGC, not sure of years.
99-02 Jeep GC's - JTEC as far as I know. May have switched mid-year like the Durangos.
If the engine is on the floor, just pull a valve cover (passenger side) and check that the reluctor ring on the cam matches yours. If it does, you're golden.
caulk04 is offline
post #5 of 6 Old 04-28-2010, 01:06 AM
djdanrt
djdanrt's Avatar
I guess I got 2003 mixed with 2002. Ive heard they went from the jtec to ngc on the 2002s. Although I think they had more NGC. Either way its something to be aware of and double check.
djdanrt is offline
post #6 of 6 Old 04-28-2010, 08:46 AM
modain
I drive with two feet
modain's Avatar
Vehicle: 2002 Dak QC, 2001 Durango
Modifications: Superchips 3715, no chrome, R/T rear sway bar, Monroe Reflex shocks
I would think the Jeep GC had 16 teeth tonerings from 1999-2004 because the (JTEC) PCM and TCM were separate (just like our 2002 and below Dakotas, and up to mid year 2002 Durangos). The 32 tooth tonering in the Dodge's was coupled with the NGC PCM (with integrated TCM).
I don't know for certain, but that's what I think...
2002 Graphite QC SLT Plus, 4.7L, NV3500, Superchips 3715, HO Cams, 2003 Intake Manifold, Dwight's 65mm TB, 3.92 LSD, R/T rear swaybar, no chrome
2001 Patriot Blue Durango SLT, 4.7L, 545RFE, Superchips 3715, Fastman 68mm TB, Jeep GC TCM, R/T rear swaybar, 3.55 Open (for now)
1999 Forest Green Dakota RC Sport, 2.5L, NV1500, Jeep 4.0L TB, 3.92 LSD
modain is offline
