Noise in front diff :( and more! - Dakota Durango Forum
post #1 of 10 Old 04-11-2010, 03:11 PM Thread Starter
DsmDriver
Vehicle: 2001 durango R/T
Hi there would like to start by taking you for the space!
So heres the situation,
I have a 2001 durango r/t with the 5.9 awd set up.
when I bought the truck a year ago I heard this noise when turning tight, it sounds like a cv click. So I replace both and replace both wheel bearings at the same time noise is still there and now it will actually stop the truck if im in reverse not pushing the fuel pedal. I need help I'm at my wits end ! lol
some one said the the main pin might be be worn out or the side gears are moving in. ive herd soooo many possibilities, if the side gears are pushing in to the king gears and what not how do u adjust them out some?
Thank you guys in advance
Kevin Coleman
DsmDriver is offline
post #2 of 10 Old 04-11-2010, 04:10 PM
tosterho
Grab life by the horns
tosterho's Avatar
Vehicle: 2002 Dodge durango
Modifications: Yokohama at's, fast man tab, powertrax locker, transgo shift kit, propod 3 gage, super hips, addco sway bars, t/s lift
Well if possible I would go to a junkyard and get one out of an old truck and replace yours with it. The cost of replacing what your talking about probably will cost a lot of money and could possible be beyond your capabilities unless your a good mechanic.
02 Dodge durango 4.7, 32" goodyear wrangler mtr's, afe cold air intake, fastman tb, clutch fan delete, transgo shift kit, superchips, powertrax locker, rancho rs5000 shocks, clear corners, propod 3 gauge pod, nu image gauge face, altezza tail lights
tosterho is offline
post #3 of 10 Old 04-11-2010, 04:22 PM Thread Starter
DsmDriver
I have some one that is going to do it for me but want to get everything together and right before i take it to him so that it cost me less to repair.
and the only other front diff that is available around here thay want 1500 for it i was thinking just take the front axles out but everyone keeps saying i cant cause it all wheel drive.
i would like to make it 2wd 4wd liek the datotas but hear that wouldnt work either
post #4 of 10 Old 04-11-2010, 05:37 PM
Trouble Maker
Trouble Maker's Avatar
Vehicle: 02 & 03 Dakota Quad Cabs
Originally Posted by DsmDriver View Post
I( i was thinking just take the front axles out but everyone keeps saying i cant cause it all wheel drive.
You can do that BUT you have to put the t-case in 4wd and leave it there AND you have to install the outer axle stubs or the wheel bearings will separate.
Much better solution is to fix the problem properly. Might want to take it to a qualified drive line shop for a second opinion on what the problem is. If one of the Various, AB locations in your sig is Edmonton, AB go to Alberta Driveline on the Yellowhead and talk to them.
Russ
His-SASed 02 Dakota Quad Cab Sport 4x4 4.7 NV3500 5spd/Std D44/9.25" 4.88s lockers frt/rr 35" ProComp Extreme MTs frt EPi 9k Superwinch rear LP 8.5k Superwinch
Also his: 09 Power Wagon Hemi 4.56 gears 285/70R17 Duratracs factory winch and lockers
Hers-03 Dakota Quad Cab Sport 4x4 4.7 545RFE 5spd/Auto 3.92 L/S 265/75R16 Dueler RVTs 5th wheel hitch
Trouble Maker is offline
post #5 of 10 Old 04-12-2010, 05:38 AM
01RT
Vehicle: 2001 durango rt " 410 "
Put t-case in 4wd?? its an awd . How are yu going to do that ?? lol do yu mean 4-hi?? still just take it in to driveline shop get it checked out.. If yu want a 2wd durango ( rare ) sell the RT and see if yu can find a good one and buy that ...Don`t wreck a good awd RT lol
01RT is offline
post #6 of 10 Old 04-12-2010, 06:15 AM
99 rango 18
99 rango 18's Avatar
Vehicle: 99 durango slt
2wd durangos arn't rare I see them all the time.
99 2wd durango with stock 318 for now, AAR cowl hood smoked bugeye projectors, lowered 3/3in, 2.5% windows, black tails, 2 15inch Orion xtr pro subs and xtr 1000.1 amp Orion xtr 500.4 for the doors.
99 rango 18 is offline
post #7 of 10 Old 04-13-2010, 04:45 AM
mrprocessor64
Vehicle: 99 dakota and 2001 durang
it might be the front drive shaft it was on mine it has a cv joint at the transfer case end
mrprocessor64 is offline
post #8 of 10 Old 04-13-2010, 05:58 PM
01RT
well must be a south of the border thing lol , i haven`t seen a 2wd only durango up here ,,,,,,,,, then again we use 4x4 / awd for winter and offroad ,,,mud fun alot up here........ be nice to have a rt with just 2wd with no awd / or 4x4 option...........
01RT is offline
post #9 of 10 Old 04-18-2010, 11:47 PM Thread Starter
DsmDriver
i dont want to run it as a 2wd I just want it fixed
post #10 of 10 Old 04-18-2010, 11:53 PM
suprchgd99rango
Pre-Teen Giggle Brigade
suprchgd99rango's Avatar
Vehicle: 99 dakota r/t
Send a message via AIM to suprchgd99rango
its hard to find a 2wd durango around here too. i know of one and she lives 5 minutes from me.
my durango is basically and r/t. 5.9 with awd and 3.92 gears.
i swapped the transfercase for the 2wd with optional 4wd out of my old durango and i would never go back unless this one gets fucked up.
when i had my transmission done, thats the main thing i wanted was to have 2wd to do burnouts
Originally Posted by Hustlajustin View Post
Dont put the Pussy on a Pedestal! J/K it is the best, now that I think about it, its like a snuggie for my penis
suprchgd99rango is offline
