EGR Light is on, running rough - Dakota Durango Forum
Gen I Dakotas 1986-1990 Dakota-Specific Questions
post #1 of 4 Old 04-09-2010, 06:00 AM Thread Starter
87Dakota5speed
Vehicle: White 1987 Dakota 5speed
Exclamation EGR Light is on, running rough
and she bucks in first and second a bit.
Want to replace the EGR, but have no idea where it is.. If someone can post a picture of where it is, I can replace it, but until then, I have no idea where to go.
Since this is an early OBD1 system, can the EGR light mean a number of different things?
87Dakota5speed is offline
post #2 of 4 Old 04-11-2010, 09:33 AM
oxygen454
Journeyman Fabricator
oxygen454's Avatar
Vehicle: 1993 Dodge Dakota 5.2L V8
The EGR is usually on the back of the engine or near the firewall.
Here is what it apparently looks like
More info on this found at this site... EGR Valve Site
Im not sure if you can check your codes with the ignition switch. The slightly newer years, if you turn the key on and off in a series of turns, the engine light will blink a code. The process can be found in the FAQ section.
Try disconnecting the vacuum hose to see if there is a change in how the engine runs. If the engine runs better, this could mean a few possibilities but does not necessarily mean the EGR is bad. Also check your smog pump when the engine is warm at normal operating temp. to see if there is warm air being blown into the exhaust manifold. (should only blow air when the engine is cold)
Hope this can be somewhat of some help!
oxygen454 is offline
post #3 of 4 Old 04-13-2010, 05:51 PM
tdmer
tdmer's Avatar
Vehicle: 2001 Dakota q/c 4x4
If it's a v6 it's located on the drivers side of the intake manifold underneath the throttle body.
OFF CAMBER MEMBER
tdmer is offline
post #4 of 4 Old 05-01-2010, 07:49 AM
oxygen454
oxygen454's Avatar
Any updates? Am curious if you solved the issue.
