I need help quick guys.Stuck in 4 wheel drive - Dodge Durango Forum and Dodge Dakota Forums
  #1
Old 04-04-2010, 07:34 PM
FEFD17's Avatar
FEFD17 FEFD17 is offline
Vehicle: 1999 Dodge Dakota
Reputation: 11 FEFD17 is just getting started
I put my truck in 4wd just to get it across the lawn,and I had no problem.I put the truck in 2wd,took off down the street,goto make a left and get this awful bind,snap noise.I stop the truck,put it back in 4wd,then into 2wd,back it up 10 feet, go forward and it's still stuck in 4wd.It acts/sounds like the drivers side is hung up and I cannot figure out how to get it back in 2wd.I have to drive 48 miles a day and I really dont wanna burn my front diff up.any idea's on how to get it out??
Just to be clear,the tranfer case is shifting fine, lo/hi range.
I jacked the front left tire up, put it in neutral,and if I spin the wheel,the front driveshaft is spinning.
I did try to hold the driveshaft,spint the wheel,no dice,if one spins,the other goes with it.I cannot find a 4wd/Front actuator on the axle or a fuse.any ideas??
__________________
1999 Dakota 5.2, 3.92 gear 31x10.5 tire Curtis 7.5' poly plow.
At least I only push snow,If I drove Ford I would be pushing the truck too.....
I work on them all.......And they all suck when they break....
  #2
Old 04-04-2010, 09:57 PM
Trouble Maker's Avatar
Trouble Maker Trouble Maker is offline
Vehicle: 02 & 03 Dakota Quad Cabs
Reputation: 41 Trouble Maker must have done something right
Normal operation.
There is no axle disconnect on your truck. The front shaft will spin any time the front wheels rotate. All the t-case does is disconnect the front shaft from the drive line internally when in 2wd.
__________________
Russ
His-SASed 02 Dakota Quad Cab Sport 4x4 4.7 NV3500 5spd/Std D44/9.25" 4.88s lockers frt/rr 35" ProComp Extreme MTs frt EPi 9k Superwinch rear LP 8.5k Superwinch
Hers-03 Dakota Quad Cab Sport 4x4 4.7 545RFE 5spd/Auto 3.92 L/S 265/75R16 Dueler RVTs 5th wheel hitch
  #3
Old 04-04-2010, 10:39 PM
6shooter's Avatar
6shooter 6shooter is offline
Resident Craigslist Whore
Vehicle: Silvy, Kota and a Harley
Reputation: 104 6shooter is just really nice6shooter is just really nice
if your stuck in 4wd, you shouldnt be able to spin the front wheels and have the rear stay still. and like trouble maker said, you have no disconnect on your axle. 4wd is engaged/disengaged at the tcase. since your tcase is operated manually and not with a button like the newer kotas, there will be no fuse. the only wiring your 4wd system has is to kick the 4wd light on thats in your gauge cluster.
__________________
  #4
Old 04-04-2010, 11:16 PM
caulk04 caulk04 is offline
Vehicle: 02 CC 4x4 4.7
Reputation: 239 caulk04 is a splendid one to beholdcaulk04 is a splendid one to beholdcaulk04 is a splendid one to behold
I imagine the 'snap' you heard was the t-case disengaging. Occasionally, I notice my t-case sticks in 4hi for a moment...it always pops out when it does this.
As mentioned, we run a 'live axle' in the front. It all spins, all the time.
__________________
Hey, does this smell like chloroform to you?
  #5
Old 04-05-2010, 04:23 AM
RebelX's Avatar
RebelX RebelX is offline
Vehicle: 98/Dodge/Durango SLT
Reputation: 20 RebelX is just getting started
Send a message via AIM to RebelX Send a message via MSN to RebelX Send a message via Yahoo to RebelX
when kickin out of 4wd. i always drive backwards about 15foot to make sure, then usualy give her some gas and see if the rear spins.
__________________
1998 Durango SLT 5.9L, 4x4, FlowMaster DF40 series, Nexen M/T's (Beast)
1980 Chevy Monte Carlo...stock for now
1988 Chevy Monte Carlo...custom built stroker/4spd auto
5 Door Whore # 173
  #6
Old 04-05-2010, 05:28 PM
FEFD17's Avatar
Thanks for all the replies.I did figure it out.I realized that the T-case is what connects -disconnects 4wd and that if I had not been pissed off to begin with,I would have figured it out without posting the question.It was the wheel bearing had a ton of play in it,and when I got it off,there were some flat spots in the bearing.I replaced it and all seems good.It has been a real rough time with my vehicles lately.I just picked up a '95 Monte Carlo,with the dreaded 3.1.It was already overheated,from the intake gasket and it wiped the crank out from the coffee milkshake mix.I bought it knowing this (real cheap) I just bought it for gas mileage,it was cheap and to keep the miles down on the Dakota(it's at 196,000 now).Then our Jeep GC I noticed,is leaving a trail of oil whereever it goes and the radiator just puked a quart of coolant on the ground after church.Gotta go get to work,Have a good one guys, and thanks for the replies.
__________________
You may not post new threads
You may not post replies
