Squeaky Serpentine Belt - Dodge Durango Forum and Dodge Dakota Forums
Go Back   Dodge Durango Forum and Dodge Dakota Forums > Technical Forums > Maintenance Forums
Maintenance Forums Keep your truck looking and running its best with this advice.
  #1
Old 03-14-2010, 10:30 PM
spruill745 spruill745 is offline
Vehicle: 1999 Dodge Durango 5.9L
Reputation: 10 spruill745 is just getting started
I just got a 1999 Dodge Durango, 5.9L V8 4x4. I love the truck alot, but the serpentine belt will not stop making noise. I bought it squealing just thinking it needed a new belt. I put a new belt on and it took care of the noise for 1 day and it came back, I put on new bearings on the idle pulley and the tensioner pulley , I also replaced the tensioner. It will not stop squealing, it happens when Im driving, at Idle all the time. Any suggestions?
  #2
Old 03-15-2010, 03:47 AM
trevor trevor is offline
Vehicle: Null
Reputation: 45 trevor must have done something right
Is something leaking onto the belt somehow?
Sometimes running tire chalk on it will quieten down the belt...but is not exactly a 'safe' thing to do.
__________________
A good sharp edge is a man's best hedge against the vague uncertainties of life.
  #3
Old 03-15-2010, 03:51 AM
2K1DurangoR/T's Avatar
2K1DurangoR/T 2K1DurangoR/T is offline
Jason
Vehicle: Ram 4x4 - Charger R/T
Reputation: 390 2K1DurangoR/T is a splendid one to behold2K1DurangoR/T is a splendid one to behold2K1DurangoR/T is a splendid one to behold2K1DurangoR/T is a splendid one to behold
x2 on the chalk. Crayon or soap works too.
When mine was squealing, crayon and soap would stop the squealing for a few minutes, though.
It took a new belt to fix it.
  #4
Old 03-15-2010, 07:16 AM
bigjv123 bigjv123 is offline
Vehicle: 2000 Dakota Sport 4.7
Reputation: 12 bigjv123 is just getting started
go grab a gatorback belt. i guarentee it will not squeak. be ready to pay like 45 bucks tho
__________________
home-made CAI, superchips 3715, dynomax home-made cat back, autolites, brush guard w/lights, sony xplode head unit, infinity kappa componants, 2 10" MTX subs
  #5
Old 03-15-2010, 06:17 PM
gatorback belt? Is that a more durable belt? Where do you purchase them? I will try all options. I took it to a mechanic friend to see what he thinks, if he does not come up with a solution I will try a gatorback belt. I heard its not good to use belt dressing? Why so?
  #6
Old 03-15-2010, 06:27 PM
blkjak blkjak is offline
_________________________
Vehicle: i do not own a dodge
Reputation: 224 blkjak is a splendid one to beholdblkjak is a splendid one to beholdblkjak is a splendid one to behold
Gatorback™ Poly-V Serpentine Belts With Quiet Channel Technology
http://www.goodyearep.com/productsdetail.aspx?id=3128
__________________
blkjak
  #7
Old 03-15-2010, 06:29 PM
slips and a temp fixblkjak
__________________
blkjak
  #8
Old 03-15-2010, 07:04 PM
So I just got a call back from my buddy, its the power steering pump. Its leaky! I didnt even check the fluid. The pulley is loose and not flush so he is 99% sure thats whats causing the squeak. Can I get the gatorback belts from Napa?
  #9
Old 03-15-2010, 07:25 PM
napa,autozone,any local parts store should have them
__________________
  #10
Old 03-15-2010, 10:32 PM
Jason
Plus, it makes a HUGE mess.
  #11
Old 03-17-2010, 05:18 PM
challenger's Avatar
challenger challenger is offline
sixpack
Vehicle: 99 Durango SLT Plus 5.9
Reputation: 10 challenger is just getting started
I was recommended Goodyear or Mopar original belt from this board for my 99 5,9. I couldn't find Goodyear around so I had to go to the stealer and pick up an original. Expensive, but worth every cent to get rid of that squealing noise.
Also check that your thermostat housing gasket is fine. Mine was rotted away and I had a small leak. It's possible some coolant could hit the belt.
  #12
Old 03-18-2010, 06:57 PM
So I got the truck back yesterday, my buddy replaced the p/s pump and pulley and it was quiet as a mouse. Now on my way home from work it starts to squeal again. Whats the deal? Could it be the a/c compressor clutch?
Will a gatorback belt really work?
  #13
Old 03-18-2010, 07:29 PM
challenger's Avatar
sixpack
my experience, throwing two belts because of squeaking noises; you get what you pay for here. Go for a quality brand!
  #14
Old 03-18-2010, 10:55 PM
take the belt off and spin the pulleys by hand or even start the truck up for a second and see if you can isolate the noise...and put on a gatorback belt and it will not squeak
__________________
  #15
Old 03-20-2010, 02:17 AM
My buddy just put a small amount of belt lube on it this morning and it hasnt been squealing all day. I dont know if its because of the lube or if the squeal finally just went away. I went to autozone today and bought a gatorback belt, so if it starts to squeal again I will put on the gatorback belt. It was expensive for sure.
You may not post new threads
You may not post replies
