Sputtering/backfiring through intake - Dakota Durango Forum
2.5L/3.7L/3.9L Engines Questions regarding the I4 and V6 Engines
Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
post #1 of 10 Old 03-02-2010, 01:00 AM Thread Starter
rshaw
Vehicle: 02 dakota
Okay, so i bought a 2002 v6 dakota from a friend. I did an intake manifold gasket to it, hoping it would solve the problem. It got rid of the cylinder 1 3 5 misfire codes, and the 02 sensor high voltage code. But it did not solve the problem.
When you stand on the throttle, sometimes itl downshift and take off like it should, but usually it'll bog pretty bad and start sputtering and popping until it reaches the upper rpms, then it takes off.
So currently there are no codes being thrown, and the problem seems to be worse when it is cold. It isn't registered because i don't want to waste the money until it runs right.
I appreciate any help, Thank you!!
rshaw is offline
post #2 of 10 Old 03-02-2010, 03:11 AM
02sxtkota
No habla jibber jabber
02sxtkota's Avatar
Vehicle: 2002 dodge dakota sxt
Modifications: Bone stock except exhaust
Send a message via AIM to 02sxtkota
try plugs wires and etc cause mine did that for awhile and if it throwing o2 code that can cause it as well since i just went thru all that same thing.
02sxtkota is offline
post #3 of 10 Old 03-02-2010, 12:13 PM
99Dakota
Diesel Mechanic
99Dakota's Avatar
Vehicle: 99 Dakota 4x4
when mine did this a long time ago it was the upstream o2 sensor. i suppose if a tune up hasnt been done in ages try that.
99 Dakota Sport 4x4 3.9L V6
360 Air Intakez, V8 TB, MSD Coil, Magnaflow Y-Pipe back, Superchips 3715, Factory 3.92's, Firestone Destination A/T's, HID 5000K BI, HID 6000k Fogs, Monroe Sensatrac Rear Loadlevelers
99Dakota is offline
post #4 of 10 Old 03-02-2010, 07:57 PM Thread Starter
rshaw
Vehicle: 02 dakota
Well I did the cap and rotor. I doubt its the plugs because the wires look brand new. Also there is no code being thrown, so I really have no idea
rshaw is offline
post #5 of 10 Old 03-02-2010, 08:19 PM
Jarheadoo7
don't feed the bears
Jarheadoo7's Avatar
Vehicle: 2001 Dakota
ceck the gap on the plugs .. i think ours is .40 or .040 i cant remember for sure
Jarheadoo7 is offline
post #6 of 10 Old 03-04-2010, 02:16 AM
Little Blue Guy
#19 ƃop ǝnןq ǝןʇʇıן
Little Blue Guy's Avatar
Quoted: 22 Post(s)
First thing I would check would be fuel pressure & volume
(but that's just me)
Little Blue Guy is offline
post #7 of 10 Old 03-09-2010, 03:27 AM
justme84
If you've had the intake off it might not hurt to check the timing, just in case the distributor was put it a tooth off or something.
justme84 is offline
post #8 of 10 Old 03-10-2010, 01:25 AM
Four20
Vehicle: 02 dodge dakota
Ok I am dealing with this issue still but not as bad anymore. It oringinated as a busted intake bolts and gasket.
1. replaced gaskets all the way down to the heads. ( only intake was necessary but everything was in such great shape i regasketed the engine instead of replacing it with a used one )
2. removed clogged pre cats and main cat ( helped tremendously )
3. new rotor and cap, plugs and wires ( no luck )
4. replaced both upstream o2 sensors ( this killed the backfire issue )
Now the truck gives no codes but acts cold natured and seems to lack it original power. I did get my fuel milage back somewhat.
I ordered the 02 sensors online for half the cost of any of my auto parts stores locally could provide.
Four20 is offline
post #9 of 10 Old 03-10-2010, 02:35 AM
01dakotaqc
01dakotaqc's Avatar
Vehicle: 2001 Dodge Dakota
you dont have to take the distributor off to change the intake manifold and it also doesnt control timing. only fuel sync.
2001 dakota r/t R.I.P
2002 dakota r/t new truck
mods: mopar headers, 3" spintech exhaust, k&n intake, m-1 2bbl, 52mm tb, asp underdrive crank pulley, viper fan, shift kit, HS 1.7 rr's, Dynojet Wideband, SCT, 2/3 drop
01dakotaqc is offline
post #10 of 10 Old 03-11-2010, 01:12 AM
Four20
I never removed my distributor and still had the same issue.
If you replaced the intake gasket the pull your upstream o2 sensors. Yours are probably filled with carbon like mine were. They werent right just slow. Im also gonna go ahead and change the two downstream to ensure the comparisons are similar to those of factry spec.
It sucks cause mine were pluged into the wiring harness for the left side on top of the tranny. The right on the back of the block near the distributor. They couldnt have picked a worse spot to put that crap.
I think im the victim of ECM software failure, as it cannot compensate nor reset fully to accept the new values. ( theory only )
Now sometime during the warranty period the wiring harness and ecm programing was updated by the dealer. As ive owned the truck since mile 1 I know this for a fact.
This has been a great truck. Now its a project
I'm not tryin to hijack a thread here but we are dealing with a similar issue with similar symptons.
Four20 is offline
