What type of oil u use??? - Dakota Durango Forum
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
post #1 of 63 Old 02-23-2010, 06:16 PM Thread Starter
rimfire,22
Vehicle: Dodge Durango
Hello to all,
In my 01' Durango V-8 I want to try a synthetic oil that a 5W-20 instead of the typical 5W-30 weight. Any issues using this lighter weight oil????
rimfire,22
rimfire,22 is offline
post #2 of 63 Old 02-23-2010, 07:33 PM
gocartone
gocartone's Avatar
Vehicle: 2001 Dakota 4x4 R/C
Any reason for the switch? I run 5-30 M1 Truck and Suv synthetic in mine. I wouldn't recomend switching to a 5-20.
2008 Corvette 485whp
2001 RC 4.7 5-Speed 4x4
2006 Yamaha FZ6
2004 Honda 450R
gocartone is offline
post #3 of 63 Old 02-23-2010, 07:35 PM
ajjacobs
Site Supporter
Vehicle: '03 Quad 4.7l
Quoted: 5 Post(s)
M1 5-30.
ajjacobs is offline
post #4 of 63 Old 02-23-2010, 07:56 PM
moparsz
1700 + 1/4 mile passes
moparsz's Avatar
Vehicle: 2002 Dakota 4.7
Modifications: if you can think it, it probably has it
Quoted: 21 Post(s)
Garage
5-20 and 5-30 are the same weight. the 20-30 is how long before the oil breaks down. 10w30, 20w30 are heavier/thicker oils
Best pass 2002 Dodge Dakota : 13.302 @ 103.39 MPH and 1/8 E.T. 8.569 @ 82.87mph
Drag Track http://www.youtube.com/watch?v=LCNQhtcXkKE
New Years Eve Burnout http://youtu.be/tnWhrInUB6o
www.AIRRAM.com Discounted Performance Parts with FREE SHIPPING!
moparsz is offline
post #5 of 63 Old 02-23-2010, 08:05 PM
gocartone
gocartone's Avatar
Not true at all, the first number is the cold weight, the second is the running temp weight.
2006 Yamaha FZ6
2004 Honda 450R
post #6 of 63 Old 02-23-2010, 08:10 PM Thread Starter
rimfire,22
Hi guys/gals,
OK you telling me yes or no BUT your not telling my why.
I just want to try it once to see if I gain any MPG. That's all. So is it OK just once????
rimfire,22
post #7 of 63 Old 02-23-2010, 08:24 PM
gocartone
gocartone's Avatar
You won't gain any mpg going from a 30 to a 20, but you will be sacrificing protection to run it. Just stick to the 5-30.
2006 Yamaha FZ6
2004 Honda 450R
post #8 of 63 Old 02-24-2010, 01:52 PM
caulk04
Vehicle: none
The engine is designed for 5w30. Run that. Bearing and pump tolerances are designed for that viscosity.
Mobil1 5w-30 with a Mobil1 filter. M1-204 I think it is...
caulk04 is offline
post #9 of 63 Old 02-24-2010, 04:21 PM
01Motorsport
RCC #93
01Motorsport's Avatar
Vehicle: 2001 Dodge Motorsports LE
Modifications: HO cams,homebrew alloy intake,SSBC rear disc, Edelbrock IAS,R/T rear bar and 17x9's,Michelin LTX Pilots,Magnaflow Y/Cat/22"/2 1/2" duals,3/2 drop,Snugtop cab-hi
Quoted: 2 Post(s)
I would agree; use 5w30. The cars that use 5w20 are made with closer tolerances. The 4.7 OEM operating temperature is 195 degrees, which thins out 30 weight plenty enough.
Mobil1 5w30 and NAPA Gold 1085 filter
'01 Dodge Motorsports 4.7/ 5-spd manual/ 3:92LSD/ Gee Whiz commercial vehicle/ mods?-beaucoup!/ &...US129 Dragon Slayer -Howard
01Motorsport is offline
post #10 of 63 Old 02-27-2010, 06:37 PM
Tydog07
150,XXX Miles
Tydog07's Avatar
Vehicle: '02 Dur 4.7L SLT
Modifications: Dwight TB
I'm surprised more of you don't run Amsoil, how come?
5DW #187 A lot of stuff...
Tydog07 is offline
post #11 of 63 Old 02-27-2010, 07:25 PM
RyanWJ
15w40 (IIRC) Shell Rotella T with a Bosch filter. Got tired of 60 dollar oil changes with as much as I drive.
2013 Focus ST on 25 psi
Gone: '02 4.7 Jeep GC- lifted, SCT, 08 manifold, FRP 71mm TB
RyanWJ is offline
post #12 of 63 Old 02-27-2010, 07:48 PM
gocartone
gocartone's Avatar
How much is Amsoil a qt, like ~$10? Thats $60 just for oil, I can get M1 Synthetic for $4.50 a qt at Wal-Mart. That makes it about $30 for a full oil change, half of what it costs just for the Amsoil.
You run 15w40? Thats pretty thick stuff for such a cold climate to be running. I would deffinatly change out to a 5-30 or 5-40 if you need thicker oil. With a 15w and cold start it's going to take longer for the oil to circulate, causing more wear on your parts.
2006 Yamaha FZ6
2004 Honda 450R
post #13 of 63 Old 02-27-2010, 08:37 PM
caulk04
Vehicle: none
Local availability and price. I would rather just pick up oil when I need it.
I sure as hell hope you aren't running 15w40. Switch to the right viscosity and your engine will like you much better. I bet your mileage goes up too.
$4.50 for Mobil1? Yeah...try over $6. Keep an eye out at AutoZone, they often run a special of 5qt Mobil1 AND a Mobil filter for $29.99. I'll pick up 5qt and a filter for one of the trucks or the RZR whenever I see it on sale. Too bad Mobil doesn't make a filter for our car.
caulk04 is offline
post #14 of 63 Old 02-27-2010, 09:19 PM
gocartone
gocartone's Avatar
The 5qt jugs are $22 at walmart, thats 4.40 before tax a qt. Sure if you buy them one qt at a time they cost more, but I'm pretty sure you can't get that kind of price break with Amsoil.
2006 Yamaha FZ6
2004 Honda 450R
post #15 of 63 Old 02-27-2010, 10:26 PM
Pugsy
Pugsy's Avatar
Vehicle: 02Dakota Sport CC 4.7 2wd
I used to run Amsoil until it got too expensive. I now run Royal Purple which is cheaper (but still expensive oil changes) and a performance oil.
Pugsy is offline
