V6 to V8 Swap - Dakota Durango Forum
2.5L/3.7L/3.9L Engines Questions regarding the I4 and V6 Engines
post #1 of 6 Old 01-30-2010, 04:26 AM Thread Starter
V6KotaRT
2000 Fake R/T & 2001 R/T
V6KotaRT's Avatar
Vehicle: 2001 Dakota R/T
Modifications: Cervinis SS Hood, roll pan, 3/5 Drop, Stillen bumper cover... Pretty much stock...
Send a message via AIM to V6KotaRT
Exclamation V6 to V8 Swap
Yeah yeah I know there are many threads posted about these swaps but getting info from all these different forums and getting things right can be difficult when there are so many scenarios.. I just bought a donor its a 1998 Durango with a 360 of course factory with an automatic. I have a dakota with the 3.9 and NV3500.. I plan on keeping the NV3500 with the swap. I need to know what all needs to be done to the 360 and the NV3500 for the swap.. I have read all these threads about internally and externally balanced cranks blah blah blah.. Then I read about the flywheel and which one you needed but have become more and more confused as I read from these different forums.. As I mentioned above I have the complete durango so I have wiring harness, engine, ECM etc..... I couldn't beat the deal.. I only paid $100 for the complete durango with somewhat low miles. Planning the swap this spring which is right around the corner... Need to hear from the ones that have "actually done the swap"!!!!
I've got two guns... One for the both of you......
2000 Dodge Dakota R/T Clone Bright White RC # 132 ,V6 to V8 conversion with 5 speed NV3500, Durango leather seats, R/T Wheels, 2-3 Drop, garage made CAI and more to come. To be track truck....
2001 Dodge Dakota R/T Bright White CC #205... 3-5 drop, roll pan, Stillen bumper cover and Cervinis SS Hood...
V6KotaRT is offline
post #2 of 6 Old 01-30-2010, 05:51 PM
AmberFireDaK
AmberFireDaK's Avatar
Vehicle: 2000 Dakota R/T
Quoted: 2 Post(s)
Send a message via MSN to AmberFireDaK
It's not that complicated really...
The 360 is externally balanced, while the 318 (5.2) and 239 (3.9) are internally balanced.
You want to keep your 5 speed so you will need the flywheel for a 360.... automatic ones like in the durango have a flexplate and a torque converter.
IIRC you need to find a flywheel from certain year Ram's that came factory with 360/manuals
- Justin
AmberFireDaK is offline
post #3 of 6 Old 02-09-2010, 11:09 PM
nhead0802
nhead0802's Avatar
Vehicle: 2001 Dakota SLT
Send a message via MSN to nhead0802 Send a message via Skype™ to nhead0802
I am in the exact same situation but I have a 5.9 liter to swap in. I've heard that the NV3500 will bolt up to everything you will need/have to swap but the tranny will not hold for very long up to the 5.9. I am uncertain if it will hold up with the 318 but i would look into before you get elbows deep in work and realize it won't hold. I've found two trannies that will hold up but do not fit in the stock tunnel and they both require at least a 3 inch body lift. (T56 and the NV4500) I do not know whether this information is solid but it's what i've been told from numerous guys on the forum that have done the swap
nhead0802 is offline
post #4 of 6 Old 09-28-2010, 10:45 PM Thread Starter
V6KotaRT
V6KotaRT's Avatar
Got a pilot bearing issue... The clutch set and flywheel I bought for my Dak (94 Dodge Ram) came with a pilot bearing.. The Crank is pre drilled to accept the pilot shaft, but the bearing seems like it it too big for the hole.. I thought I had read something about a Mopar Performance bearing I had to use but have not seen it again.. Maybe I missed something. But if anyone who has done the swap could give me some info it would be greatly appreciated as my truck has been down for almost 3 months now!!! Just to let ya know I have pretty much everything I need..
V6KotaRT is offline
post #5 of 6 Old 05-21-2014, 04:12 PM
Truck nut
Engine Swap
Hi; I have an excellent running 1999 4x4 Dodge Dakota with 318(5.2L) V8. but the body is junk!. I also have a really good bodied 2002 4x4 with 3.9 V6 which runs good but performance sucks!
I am thinking about swapping out the drive line, engine, etc, from the 1999 into the 2002 V6 truck. Can it been done and what if any problems would I encounter. For instance do I need to change transmissions or transfer case, radiator, etc?
Truck nut is offline
post #6 of 6 Old 05-29-2014, 07:55 PM
87DakBuilder
Stroked 91
87DakBuilder's Avatar
Vehicle: 87 Dakota, 05 Durango
Modifications: 390 Stroker with N20 coming real soon
Quoted: 8 Post(s)
Send a message via Yahoo to 87DakBuilder
Truck Nut,
provided both trucks are Automatics, you should have no issues with the swap. It is simply plug and play, in terms of swaping. You may have to swap out the instrument cluster and under dash wiring, as Chrysler did some wierd stuff in 02. The trans should be the same. Have fun and do the swap.
13 Durango R/T
02 Dakota Sport 3.9 Daily
91 Dakota Ext cab4/4 Drop
390 Stroker W/TKO 600 finally in truck
87DakBuilder is offline
