Oil pan removal - Dodge Durango Forum and Dodge Dakota Forums
Go Back   Dodge Durango Forum and Dodge Dakota Forums > Model-Specific Forums > Gen I Durangos
  #1
Old 01-27-2010, 10:23 PM
homie3186 homie3186 is offline
Vehicle: 1999 durango
Reputation: 10 homie3186 is just getting started
Oil pan removal
hey how hard to it to remove the oil pan on a 99 durango 5.2l 4wd thanks
  #2
Old 01-28-2010, 12:50 AM
RJ_Hythloday's Avatar
RJ_Hythloday RJ_Hythloday is offline
99 Durango 5.9 part out
Vehicle: 99 Durango R/T
Reputation: 34 RJ_Hythloday must have done something right
Very, you'll need an engine hoist, disconnect the brackets holding the motor to the drivetrain. Expect a whole weekend if you're mechanically inclined and have the proper tools. Longer if not.
  #3
Old 01-28-2010, 01:25 AM
i will be using a lift the book says disconnect exhaust unbolt starter and lift the motor up on blocks. that seem simple enough
  #4
Old 01-28-2010, 02:45 AM
Adobedude Adobedude is offline
Vehicle: 2001 Dakota R/T
Reputation: 59 Adobedude has a spectacular aura about
__________________
11.65 @ 114.84 All Motor on Mars.
Street racing is gay.
  #5
Old 01-28-2010, 05:55 AM
petrock's Avatar
petrock petrock is offline
The Anti-RUB
Vehicle: 4.7L '03 Durango SLT
Reputation: 34 petrock must have done something right
Easier said then done...
__________________
K&N FIPK
  #6
Old 01-28-2010, 02:13 PM
I didn't do any thing w/ the starter, or the exhaust, there's a lot of movement. If I were trying to do that again, I'd remove the bolts from the fan shroud so it would move up w/ the fan, that's what was limiting me in upward movement. I'd also try and get a piece of ply wood between the fan and the rad(punctured my rad removing engine)
What is it you need to do w/ the oil pan off?
  #7
Old 01-28-2010, 04:22 PM
suprchgd99rango's Avatar
suprchgd99rango suprchgd99rango is offline
Pre-Teen Giggle Brigade
Vehicle: 99 dakota r/t
Reputation: 130 suprchgd99rango is a glorious beacon of lightsuprchgd99rango is a glorious beacon of light
Send a message via AIM to suprchgd99rango
mine also needs to be removed. mine leaks pretty bad. i just filled my oil last week and its already below the add line. sucks ass.
__________________
Originally Posted by Hustlajustin View Post
Dont put the Pussy on a Pedestal! J/K it is the best, now that I think about it, its like a snuggie for my penis
  #8
Old 01-28-2010, 05:22 PM
If you're removing the pan to replace the gasket you'll kick your self for not replacing the oil pump while you're there. Go standard volume, and the pick up screen is probably fine. The plenum plate is the worst known offender for these engines "burning oil". sprchrgd99 is your's a very visible leak?
  #9
Old 01-28-2010, 05:25 PM
yessir. thought maybe it was the oil filter since theres was shit all around it so i cleaned it all up and put in a new filter and made sure it was tight and still leaks so i know that wasnt the culprit.
i was also told that it was prolly the pan but i figured id try the easys hit first lol.
__________________
  #10
Old 01-28-2010, 08:53 PM
It's really not that easy, any chance it could be the rear main seal?
  #11
Old 01-28-2010, 09:11 PM
just had the trans off. my mechanic said it looked fine.
__________________
  #12
Old 01-28-2010, 09:58 PM
That's a good start! how many miles on the motor?
  #13
155k
__________________
  #14
Old 01-29-2010, 12:03 AM
155k
Not bad, bought mine w/ 104k blew a main cap at 105k.
Is the OP even around anymore?
You may not post new threads
You may not post replies
