Stuck spark plug - Dodge Durango Forum and Dodge Dakota Forums
Go Back   Dodge Durango Forum and Dodge Dakota Forums > Engine-Specific Forums > 4.7L/4.7L HO/4.7L Gen II Engines
  #1
Old 01-25-2010, 01:27 PM
Delta Dog Delta Dog is offline
Vehicle: 2002 quad cab 4x4, 4.7L
Reputation: 10 Delta Dog is just getting started
Stuck spark plug
Hey All,
This is my first post here and am excited to have found this place!!!
Of course I found this while in search of answers about my 2002 quad cab 4x4 with the 4.7L engine.........so here it goes.........
You know that little rubber insert inside the spark plug socket that grips the ceramic?? Well....it is stuck (rammed, wedged) down around the hex part of the plug so I can no longer get the socket on to twist it out.
The plug is easy to get to (#8) but not easy enough to see into the hole. I have tried picking the rubber piece out with a dental pick with no luck. There is MAYBE 1/16" between the side wall and spark plug hex. It seems i need a 5/8" socket made out of sheet metal or something thin that will cut into the rubber and grab the plug.........I need ideas..........
Do they make any special tools or gizmos to address something like this?? How do people get out plugs that have stripped the hex part off their plug?? Please help!!!!!!!
  #2
Old 01-25-2010, 02:29 PM
Jecht's Avatar
Jecht Jecht is offline
Mods Addict
Vehicle: 03 Dakota QC
Reputation: 137 Jecht is a glorious beacon of lightJecht is a glorious beacon of light
Take the plug out. Take rubber boot off plug. Now put plug back in the get it started. Stop take off the rubber and tighten all the way. What I do my socket is worn out.
  #3
Old 01-25-2010, 02:47 PM
RJ_Hythloday's Avatar
RJ_Hythloday RJ_Hythloday is offline
99 Durango 5.9 part out
Vehicle: 99 Durango R/T
Reputation: 34 RJ_Hythloday must have done something right
He's saying he can't get the plug out. If it's going to be replaced anyways, I might try a pair of vise grips on the tip, it shouldn't be in there that tight to begin with.
  #4
Old 01-25-2010, 02:54 PM
Rebel13 Rebel13 is offline
Mods Addict
Vehicle: 2K R/T
Reputation: 297 Rebel13 is a splendid one to beholdRebel13 is a splendid one to beholdRebel13 is a splendid one to behold
I want pics, I picture what he is doing-did? All you do is pull the wire boot off and loosen the plug? If boot sticks and breaks, get pliers or vise grips to pull off remaining junk and then loosen plug?
  #5
Old 01-25-2010, 03:16 PM
He's talking about the piece of rubber inside the socket
It came off and got pushed down, so that it's blocking the hex where the socket would grab.
I'd still give the vise grips a shot, if not, maybe one of those gator sockets?
  #6
Old 01-25-2010, 03:28 PM
durango2001's Avatar
durango2001 durango2001 is offline
5 Door Whore #215
Vehicle: 01 Durango, 02 dakota r/t
Reputation: 15 durango2001 is just getting started
he has the 4.7 you cant grab the spark plug with vise grips or pliers it down in the head
  #7
Old 01-25-2010, 03:46 PM
That sux, not even needle nose vise grips? Is there a heat shield that can be removed? My neighbor has a 4.7 but I haven't spent much time looking under the hood.
  #8
Old 01-25-2010, 04:30 PM
That cylinder bore in the head, for the spark plug, is JUST big enough for the spark plug and a standard socket. I have consumed the space for the socket with the rubber socket insert.........mashed it down in there REAL good!!
I MAY be able to get a needle nose vise grip in there but was hoping for a less (possibly) destructive method.......to begin with at least. Right now the truck runs fine so I don't want to make the problem worse or the truck inoperable just yet.
If i do go the vise grip route..........do you think it would be OK to soak the plug/hole with PB blaster??? Hopefully a little bit would get past the rubber piece and to the threads. That one plug has been in for 144K so it might very well be a tight one.
  #9
Old 01-25-2010, 04:44 PM
gocartone's Avatar
gocartone gocartone is offline
Vehicle: 2001 Dakota 4x4 R/C
Reputation: 54 gocartone has a spectacular aura about
How did you go about doing this?? The rubber insert should fit right back into the spark plug, if it doesn't just slowly rotate the socket while pushing down hard til it clicks down onto the hex. If that doesn't work just get a long skinny knife or screwdriver to cut the rubber so it's not all the way around it, then blast it out with air. I don't really get how you got the rubber stuck on there to where you can't get the socket back on by pressing hard though.
__________________
2008 Corvette 485whp
2001 RC 4.7 5-Speed 4x4
2004 Honda 450R
  #10
Old 01-25-2010, 04:53 PM
From what I remember it was pretty easy!!! It went like this.........
Put socket on plug.......realized it was loose........took it off and realized the rubber thingy was not on.........got another rubber thingy from another socket and went back at it. Couldn't get it to seat right so "worked" at it with a little force.........THIS is when I realized the rubber thingy that I thought I lost had fallen out of the socket the first time I put it on the spark plug........I think it was old and shriveled cause it was always falling out of the socket anyway......
So.......as I "worked" on getting the socket with the 2nd rubber thingy on the plug I was smashing the other one down in the space between the cylinder wall and the plug hex part.........and did a dang fine job i might add!!!
  #11
Old 01-25-2010, 06:08 PM
gocartone's Avatar
Smooth one...just try to cut it with a thin long screwdriver and blow it out with the air.
__________________
2004 Honda 450R
  #12
Old 01-25-2010, 06:20 PM
I just picked up a stamped plug wrench for a homelite small engine......fit the new plug just fine. I might have to grind the outside edges down to reduce the wall thickness and make them "sharper" to hopefully cut into the rubber. Might even heat up the new tool to try and melt the rubber and let is squish up while I tap it down on the plug..........
I did make it to church yesterday so hopefully between that, all the planets aligning and a quick witches potion ........all will be well!!!!!
  #13
Old 01-25-2010, 08:16 PM
WestCoastKevin WestCoastKevin is offline
Vehicle: 2002 Durango SLT+ 4.7L V8
Reputation: 15 WestCoastKevin is just getting started
Do you have a small o-ring pick/hook set? That should do it.
or
Take a wire coat hanger and bend the end of it and sharpen it to pierce the rubber. Try to hook it up
Try to get it up before cutting it into pieces. You do not want pieces of it falling down the plug hole.
Good luck,
Kevin
  #14
Old 01-25-2010, 08:47 PM
Mods Addict
Vehicle: 2K R/T
This thread is funny!
  #15
Old 01-25-2010, 09:36 PM
bigjv123 bigjv123 is offline
Vehicle: 2000 Dakota Sport 4.7
Reputation: 12 bigjv123 is just getting started
x2!!
__________________
home-made CAI, superchips 3715, dynomax home-made cat back, autolites, brush guard w/lights, sony xplode head unit, infinity kappa componants, 2 10" MTX subs
You may not post new threads
You may not post replies
