Heat Cold At Highway Speeds - Dakota Durango Forum
2.5L/3.7L/3.9L Engines Questions regarding the I4 and V6 Engines
post #1 of 35 Old 01-21-2010, 12:57 PM Thread Starter
zidane
Hey guys,
I;ve been looking all over the place for an answer to this, but it seems people have the opposite problem where the heat is cold/ luke warm at idle/low speed and gets better at high speed. When making my commute back home from Long Island (about 7 hour ride) my heat just started blowing cold air at about 75 mph. I rode home frozen to the steering wheel the rest of the way and replaced the thermostat. Backflushed the heater core, before winter hit, but the problem still developed. I have tried blocking the radiator off, pipe insulation around the heater hoses. Nothing really seems to fix it or improve the quality of the heat. I have to drive it around for about 30-40 minutes for it to blow luke warm heat at city speeds. Any ideas? I wanted to get opinions before I take it to the shop and shell out cash for a new heater core or something. Thanks in advance for your help.
Zidane
1999 Dodge Dakota Sport 4x4
3.9L V6, Auto
V8 Throttle Body
Westin Grille Guard
2" PA Body Lift
32x11.50 BFG A/T's
Taurus E-fan
zidane is offline
post #2 of 35 Old 01-21-2010, 01:15 PM
Jarheadoo7
don't feed the bears
Jarheadoo7's Avatar
Vehicle: 2001 Dakota
what degree thermo did you put in it?
Jarheadoo7 is offline
post #3 of 35 Old 01-21-2010, 04:06 PM Thread Starter
zidane
195. Up to the point in my trip where the heat stopped working you could watch the temp fluctuate to the temp the t state would open then the temp would drop, then suddenly the temp drooped and stayed low, like 160 or so, so I thought the t stat was stuck open. Didn't seem to fix the problem though.
Zidane
3.9L V6, Auto
V8 Throttle Body
Westin Grille Guard
2" PA Body Lift
32x11.50 BFG A/T's
Taurus E-fan
zidane is offline
post #4 of 35 Old 01-21-2010, 05:12 PM
polecat
5 Door Whore #176
polecat's Avatar
Vehicle: 2000 durango
sounds like the heater core is leaking mine was doing the same thing never ended up in the cab though it was draining through the drain hole in the heater box do you smell coolant at all with the heat on?
polecat is offline
post #5 of 35 Old 01-21-2010, 07:21 PM
bwdakrt
Posts: n/a
Quoted: Post(s)
Sounds like a bad radiator cap and it's releasing the pressure in your cooling system too early.
post #6 of 35 Old 01-21-2010, 07:56 PM
6shooter
Resident Craigslist Whore
6shooter's Avatar
Vehicle: One with a bowtie
my 98 was a 4 banger, and it did it to me sometimes. i just figured it was the simple fact that at 10 degrees outside and 75 mph, that little 4 cyl didnt make enough heat to keep the coolant system temp up high enough for adequate heat. basically the cooling system was just too efficient in super cold temps.
Hi, my name is Brad, and I have an addiction to Dakotas.
6shooter is offline
post #7 of 35 Old 01-21-2010, 10:34 PM Thread Starter
zidane
I was concerned about the heater core, but I haven't been losing any coolant, the level as been constant in the radiator and in the overflow reservoir. I'm liking the radiator cap idea, since its just a tad cheaper than the heater core. I've been watching the passenger floor mat for wetness but nothing there either. I'll give the radiator cap a shot, it's never been replaced. Thanks for the advice, I'll report back after.
Zidane
3.9L V6, Auto
V8 Throttle Body
Westin Grille Guard
2" PA Body Lift
32x11.50 BFG A/T's
Taurus E-fan
zidane is offline
post #8 of 35 Old 01-21-2010, 11:09 PM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Modifications: Lots 'O stuff
Quoted: 190 Post(s)
Sounds like maybe your blend door isn't working properly. Either a broken vacuum line or just a bad solenoid for the door.
hskrRT is offline
post #9 of 35 Old 01-21-2010, 11:43 PM
bwdakrt
Posts: n/a
Quoted: Post(s)
Guess you didn't read post #3.
post #10 of 35 Old 01-22-2010, 01:00 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 190 Post(s)
Okay??? He changed his t-stat and it didn't fix it.
hskrRT is offline
post #11 of 35 Old 01-22-2010, 01:08 AM
bwdakrt
Posts: n/a
Quoted: Post(s)
Since when does a blend door cause the temp to fluctuate?
post #12 of 35 Old 01-22-2010, 03:57 AM
hskrRT
nstg8tr
hskrRT's Avatar
Vehicle: 2000 R/T
Quoted: 190 Post(s)
So how does your radiator cap theory fit in here?? You didn't see me jump on your case about that shit, why did you feel the need to post your BS about my suggestion?
zidane, what was the outside temp when it was doing this? And have you changed the t-stat since it started?? Your post was a little confusing. My heater doesn't work all that great when driving down the road, but sit still in a drive through and it warms up as the coolant in the radiator warms up more than when driving and forcing cold air through it. If I stop and pop the hood right after a drive in the 30 degree or colder temps we've been having, my bottom radiator hose is cold, and my heater hoses are cool enough to hold on to.
hskrRT is offline
post #13 of 35 Old 01-22-2010, 05:38 AM
dave2003
Site Supporter
dave2003's Avatar
Vehicle: 2000 Dakota Sport CC
Modifications: 360 Power Shot Intakez, V6 modified TB, HS 1.7 RR's, Superchips
Quoted: 5 Post(s)
My trucks seems to be the opposite. I get great heat when moving and next to nothing when idling.
2000 Dakota CC 3.9L 5SPD Man
180* T-Stat, 360 Power Shot IntakeZ, bwdakrt modded V6 TB, Superchips 3715, HS 1.7 RR's , Black Magic 180 Extreme Fan (Clutch fan kicked to the curb!), Summit 8mm Wires, NGK 4291's, EBC Sport Rotors & Hawk Pads, Infinity Reference 6020CS & 6022SI, AMI Locking Fuel Door, Diamond Clear Corners with LED headlights and LED fog lights.
dave2003 is offline
post #14 of 35 Old 01-22-2010, 05:46 AM
6shooter
6shooter's Avatar
thats your water pump impeller fins bein shot. i had the same problem on a friends yota a while back. took the pump out, the fins looked like a saw blade cause they were corroded right off. your coolant isnt circulating because your moving, its circulating because your at a higher engine rpm, making up for the worn out blades.
6shooter is offline
post #15 of 35 Old 01-22-2010, 06:15 AM
dave2003
Site Supporter
dave2003's Avatar
Quoted: 5 Post(s)
That sucks! I hope its not the case. I changed out my water pump about 35k miles ago. If it is then it is a relatively cheap and easy fix.
dave2003 is offline
