| Register | Home | Forum Extras | Website Features | Garage | Calendar | Search | Today's Posts | Mark Forums Read | Auto Loans |
| Lights Parts Info Links : Clear Corners * Headlights * Headlight Covers * Tail Lights * Tail Light Covers |
Thread Tools | Rate Thread | Display Modes |
#1
reverse light problem
I changed the bulbs and they still don't work what else can i check( and how) to alieviate my problem
| Sponsored Links | ||
Advertisement | ||
#2
maybe check for a blown fuse or something.
__________________
current ride: 06 F250 Crew Cab Lariat Short Bed 4.5" lift sitting on 37x13.50x20 Toyo MT's ![]() |
#3
Blown fuse or disconnected wire maybe cut underneath the truck.
__________________
,Christian 1999 SY CC R/T: 3" GSM headers and Ypipe, Spintech muffler with custom tip, Hotchkis TVS, Flashed PCM, Transgo shift kit, 4:56 Gears, Poweraid TBS, K&N FIPK, Mangacore wires with Accel components, Optima Red top Battery, LineX, Bed Rug, Innovations Tonneau cover, Super pursuit cover with PIAA 520's, Southeast performance body kit, SRT-10 hood, 20" R/T wheels powdercoated Black along with alot more powdercoated, 20% tint on front windows to match factory. |
#4
it's not the fuse , someone eas telling me check where the reverse lights go into the tranny or something like that
#5
oh yeah, notorious problem. I had it in my dak sport. Its a busted switch in your tranny. I just had the dealer do it. Cost me like $80 to fix. 99.9% sure that's the problem. If I did it myself I'd tell you how to do it, but I was fresh out of ideas after changing the bulbs and fuses. So I just had the dealer finish it off for me. Best of luck, hope it works for you
#6
Yeah if u cant find any blown fuses its the relay switch on ur transmission. I just bought one for my truck and im about to install it. the part cost 9.99 so dont get ripped off at the dealer for $80. with no knowledge you could fix it in like ten mins. get the part frist so u know what it looks like, crawl under you truck and look around the transmission. you will see it, on mine its one the side, but there are two other transmissions for a dakota and they have different locations. then unhook it and unscrew it, install the new one and replace the wires. if u still have questions get a haynes and it has a detailed instructions in there.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
| Display Modes | Rate This Thread |
